Exhaust Dump Location
Old Jun 4, 2004 | 05:32 PM
terky's Avatar
Is it ok to have the end of the exhaust dump in front of the back tire instead of behind it? If the turndown pipe sticks out a little bit farther than the body it should be fine right?
I just want to know before i cut anything
Thanks
Old Jun 4, 2004 | 05:35 PM
HarrisonP's Avatar
Not sure, but my dad's old 96' F-150 had the exhaust exiting in front of his rear right tire (from the factory).
Old Jun 4, 2004 | 05:39 PM
terky's Avatar
Ok good enugh for me. I just dont want fumes to be able to gather in the cab and stuff like that. If automakers can do it so can i.
Old Jun 4, 2004 | 06:14 PM
rimpainter.com's Avatar
I agree, this should be ok. I was going to do the same mod until I ran into the problem of smashing my exhaust pipe while off-roading. There is just no good place to go under the frame without losing some clearance, for me anyway.
Old Jun 4, 2004 | 06:37 PM
3.4v6's Avatar
just make sure the turn down doesnt dump the gas fumes onto the rear axle. i need to get mine re-routed.
Old Jun 4, 2004 | 06:59 PM
terky's Avatar
i was thinking having it point straight out the side, use like a 90* bend.
Old Jun 4, 2004 | 07:24 PM
Just remember, the less bends the better.
Old Jun 4, 2004 | 11:47 PM
jimbo74's Avatar
the rule with exhuast according to US DOT mandates are that on a vehicle, the exhuast exit must be behind the passenger cabin, or at or behind the rear axle.... on an suv, where the cabin goes all the way back, the exit has to extend at least to the rear axle or farther back.... on a pickup, it can exit anywhere behind the cab area....
Old Jun 5, 2004 | 01:05 AM
Bigkahuna808's Avatar
Yep the exhuast has to be behind the last operable window for a passanger vechile. Basicly means that is must be behind the the furthest back passanger seat.
Old Jun 5, 2004 | 12:45 PM
terky's Avatar
Sweet, thanks alot guys!
Old Jun 5, 2004 | 12:52 PM
bike4miles's Avatar
Baised on this you couldn't put the pipe in front of the rear wheel on a 4runner.
Team420
Dec 30, 2015 01:31 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
raptor510
Aug 19, 2015 02:15 PM
ToyoToler
Aug 8, 2015 08:43 AM
Dakotaneu
Jul 27, 2015 12:03 AM
