Voltmeter issues
Old Jun 2, 2004 | 07:16 PM
mp101v's Avatar
Voltmeter issues
I have a 93 truck, 22re, 5 speed. Recently (2 or 3 days ago) my voltmeter started moving ALOT. It would be around the 12ish area, but now it moves from 12ish to 9 or so then up to 13 or 14. it moves back and forth all the time while driving. Anyone have any ideas? Thanks. :wtf:
Old Jun 2, 2004 | 07:58 PM
terky's Avatar
Alternator going out maybe? Or the belt is slipping so the Alt isnt spinning. Id say thats a good thing to check.
Old Jun 2, 2004 | 08:10 PM
toy283's Avatar
It should hang out right at 13-14 all the time. Being that it varies below this, I would also check for loose and/or corroded wiring. Usually if a voltage regualtor goes bad, voltage runs high, like 17-18 or so. A low voltage could also be indicative of a bad alternator or a bad battery. Start cheap and check out wiring first and then go from there.
Old Jun 3, 2004 | 05:17 AM
98 Joes's Avatar
I still think it could be voltage regulator. When mine died, voltage dropped to around 9 volts. The cause was worn slip ring brushes. Weak contact inside the alternator = low voltage. A bad winding in the alternator will cause low volts also, but since yours jumps around so much, I'd check the wiring first then the alternator for poor contact.
Old Jun 3, 2004 | 01:50 PM
mp101v's Avatar
thanks for all of the help.
80Truck
Oct 12, 2025 07:25 PM
bigjstang
Jun 2, 2025 03:56 PM
nvdesertrunner
May 11, 2020 08:18 PM
crammit442
7
Nov 29, 2017 12:30 PM
rjtrials
Aug 6, 2015 07:25 PM
