- Gear/Final Drive Ratios for 05 Tacoma
- The best place to mount a tack?
- Why my '03 4Runner driver's seat does not feel secure.
- 05 Yota Taco Tech
- Tacoma stock height?
- 3VZ-E Head CFM???
- what should I purchase with a dealer 25% coupon?
- Rear hitch adapter
- need advice on body lift install
- Pic Request 3rd gen on 33's.
- exterior trim
- Dana Hubs
- Toyota Transmision
- Body lift with no running boards? Bad or good lookin'?
- ISO Cheap 22RE perfomance mods
- Headers
- Thorley kaput?
- Where can I get a short antennea?
- help: washer fluid light won't turn off...
- light mounting options (light bar)
- temp guage
- Exhaust System Replacements
- Zerk/grease fitting caps
- Custom sway bars
- Where did your fog lamps go?
- Max Tire width for stock P/U
- Source for AN type stainless steel lines?
- stock size tires (pressure)
- Flex pics of the rigs (LOTS OF PICS!)
- Temp gauge swap ?
- Tail Lights. Yay or Nay?
- Need help with hub question
- Need help finding VSS and Reverse Wire
- 2nd gen cargo cover
- Where's my Neutral Safety Switch?
- Trucks dead
- Alignment Question
- how to correctly install balanced flywheel?
- 05 Tacoma: Mounting License Plate...
- High Idle after some offroading and river crossing....
- sucks... I think I blew my head gasket last night
- Exhaust Header on a Taco
- Steering Stabilizer Opinions?
- anyone heard of this???
- 2nd Gen Steering Rebuild Kits
- 17" tundra rims or 17" 4th gen runner rims
- Front hood bug deflectors
- Millenium Silver paint code for 2002 4Runner?
- The Perfect Power SMT piggyback controller
- Sr5
- Yep, sorry, another stupid "what tire should I get" thread
- SCORE!! New rims and tires
- Quick question on manual hubs
- Gear question
- What happened to the old SMT-6 thread?
- xrunner bolt pattern
- modding the steering column on a body lift
- amsoil air filter
- is it safe to put redline mt-90 in my 5spd?
- oem runningboards
- '90 3.0 engine in a '92?
- Running Boards are off!
- Steering Reconnect Problems
- What would this truck be worth to you?
- Opinions on Next Mod - URD or Headers??
- Different OEM rims? (3rd gen)
- OIL in intake hose?
- Will a 84-85 body lift kit fit a 94 pickup
- windsehlid pillar mounted lights
- lucky? might be?
- brake upgrade for 2wd
- Bug deflector
- When does the Winter Gas go away?
- Questions about camper shells, mounting and fitment
- Air Filter?
- 1990 4Runner tails fit what years??
- Trade in modded, or part out?
- Alright men teach this boy how to negotiate pricing....
- 95 4r Speedo stopped working
- Fender Flare!!! :) get it!!
- CEL code P0330 - the saga
- Gas mileage on 88 4runner with 33s(4 cyl. manual)
- Quiet AT tires
- Dealership is Screwed
- Replacing steering spindle bushings
- which wheels fit ?
- Is there much different between a 1st gen supercharger and the newer versions?
- Baby got some new shoes!
- Where are the most Runners?
- Scrap yards for parts
- Interior Light
- Acetone increases gas mileage?
- Going supercharged --> stock: Parts needed? (odds and ends)
- Relay wiring
- Headers not fitting with body lift?
- Improved Gas Mileage
- Tail Lights
- Good Deal on 4Runner?
- Tach problem!
- Question regarding 20/22r intake manifold....
- '88 Arm Rests & Seat Cover?
- Anyone swap a 4.7L iFORCE V8 into a Taco?
- 2nd Gen 4runners/3rd gen pickups. What swaps HAVE been done?
- Where is the check connector??
- 1997 Taco or 4R????
- Woot!
- Chevy V8 Engine swap
- Supercharged and gasoline
- 2nd. gen. steering stabilizer: do i need new brackets?
- Performance upgrades 95 SR5 4Runner
- Downey Skidplate and headers
- 99 Tacoma questions
- remote starters for man. transmission?
- About to buy a 2005 Taco Double Cab 4wd....?'s
- 3rd Generation 4cyl. Gas Mileage
- 91 Stock Rims Backspacing
- Leather seats ?
- Good News!!
- Do intakes really do anything for the car
- Trade my '91 for a '99 straight up? Opinions wanted.
- new car?
- spark plug wire locks??
- main bearing cap removal
- weekend mods
- leaf springs
- 3.0 High Idle
- Aftermarket power windows
- Regular vs. unleaded
- Got a call from B&G, 3 more weeks till new bed!
- limted VS. Sr5 in power-help
- ISR Mod
- First time the Taco went off road...
- 3VZ-E rebuild update (lots of pics)
- whatdya think of black wheels?
- problems with stupid air intake sensor mod chip....
- Dual VVT-i?
- Weight of OEM 16" Wheels
- Will 3rd Gen 15" rims fit a 2nd Gen?
- I never see ne 1st generations
- Color Code for Imperial Jade?
- anyone got ideas for extra din space below head unit...
- New "BruceTS" style 3rd Gen 4Runner rear bumpers
- Equal (tire balancer) experiment failure
- Anybody out there have these???
- Remove The Torch From Your Mapp Gas Now!
- Headlights
- Rare Photo!
- Nice Sounding exhaust
- Upgraded ignition?
- Running 33x12.50 on stock 15 inch rim
- Anybody eliminate the cat all together???
- Pre 85 vs Post 85
- Flomaster 50 Delta Flow, or 60?
- shaky hood
- Where do I find electrical relays?
- 3rd Gen Rear Storage Compartment
- 96 Missing body mount?
- Toyota pictures, cool truck
- bad dent and scrape
- 22R/20R compression ratio?
- Need Light Suggestions
- 2nd Gen Manual Hubs
- 4Runner Liftgate 97 vs 99 in green...are they the same?
- Ever seen a 2.7 tow a ski boat?
- Have you found your intake kit worth the money?
- Where to find oversized altenator
- If you were to buy a 96-02 4Runner
- 3rd Gen Road Carnage...Liftgate w/ pics
- How much Mileage does your engine have.
- 5VZE 3rd Gen 4Runner / 4th Gen Taco Fan Swap
- dealer techs
- Check out this 1984 4Runner that was on ebay!
- 3rd gen glow gauges install
- AllPro disc Parking Brake
- Engine Main Bearings and Rod Bearings
- 3.0 problems
- 4runner tire mileage
- Help...Blown EFI Fuses...
- LSPV and question about bolts
- Go Rig Go...
- Noise in rear end
- When I step on my brakes, my dash lights come on!!
- Need side shot of 1st gen 4runner...
- Advanced Timing and Adjusting the AFM?
- high flow cat worth it?
- Popping...From Exhuast.
- O.C. Titan newbie needs 4runner help
- Replacing tie rods,idler arm, cv axle. advice/suggestions?
- Who's Got a Bentup Rear Bumper on a 96-00 4R?
- 22re A/C Belt Removal
- 1985 Topper removal
- Is there any reason to replace the front coils
- What would you do if Toyota dealer crack the windshield while servicing your 04 4R?
- catback exaust differences 85 and 87 p/u
- Oil weight in Colorado? 5W VS 10W?
- Any Phoenix (west valley) guys with exhausts want to let me listen?
- Rusted Tie Rod Adjuster
- Mattracks Toyota SandCruiser
- Lost out on 1999 4Runner...
- tire width ???
- Need front axle seal info and part#
- 05 Tacoma knock in front suspension?
- 305/70r17 on 7.5 wide tundra rims
- 4Runner Towing Question
- overtightening lug nuts..
- Crutchfield Infinity speaker sale..which of these fit "01 runner?
- I need EMERGENCY help with my 3VZE
- auto tranny question
- Dually Conversion
- Speedometer calibration
- creaking/groaning sound
- Attn Drive line specialists
- Virgin....techie help needed.
- I'm back w/ more tire questions
- 4Runner to Hummer Conversion!
- I'm new!
- FYI: 2nd gen 2wd 4Runner wheel bearing info/write up
- Brake Issue
- Re-torque driveshaft question
- Problems HELP! Low compression and oil burning
- Is this a good deal?
- Rear Aftermarket Bumper for 2nd Gen
- Quick and cheap repair
- Disc brake conversion
- Daystar Bump Stops with Sonoran Steel Brackets Installed - PIC
- mud in tires?
- Best off road lights/cheapest prices
- jerking during acceleration
- 1985 22re EFI Engine Problems
- coolant pipe on intake/22re
- SkyJacker 1st gen lift kits
- Any deckplate modders get water in airbox?
- How long Bils supposed to last?
- Pickup Body Panels
- Now I'm confused
- Rear view mirrors with map lights
- I found the problem
- 3.0 getting slower
- Valve cover washer seals
- I need details on howto change Tacoma 3rd out
- To sell or part?
- Help please.
- Attention newbies-State your question in the title and put it in the right section!
- Cold Start Problems
- 22 re oil leak problem
- power steering failure
- 73 Landcruiser FJ-40 on eBay... Gorgeous
- Transmission install tricks?
- 3rd gen roof leak
- rs3000 install help
