Noise in rear end
Old Mar 29, 2005 | 07:54 PM
callmej75's Avatar
Noise in rear end
Since I put my swampers on I noticed a sound coming from the rear end that has gotten worse. When applying gas to it it doesn't do it. when I let off the gas and coast I can hear this "ting ting ting" noise coming from it sounds like the 3rd member. Could this be a broken ring or pinion gear or maybe a missing tooth? If so where can I get 3rd members already put together if this is the case?
Old Mar 30, 2005 | 03:22 AM
callmej75's Avatar
anyone?
Old Mar 30, 2005 | 03:25 AM
jimbo74's Avatar
ting ting ting... is that a metallic clank? it could be anythign really.... side gears, pinion gear, ring gear, bearings, are most likely... pretty much everywhere sells third members already set up with gears... look in the for sale section on here and on marlins buliten board for cheap deals, otherwise its quite expensive....
Old Mar 30, 2005 | 03:28 AM
callmej75's Avatar
thanks jim....do you have the link to marlins board?
Old Mar 30, 2005 | 03:31 AM
jimbo74's Avatar
its the bulletin board off www.marlincrawler.com
Old Mar 30, 2005 | 03:34 AM
callmej75's Avatar
thanks!
Old Mar 30, 2005 | 08:00 AM
callmej75's Avatar
Found problem...passenger side rear shock....nut and bushing missing from the vibration of the swampers. replaced...no noise...thank god it wasn't ring and pinion....but i am looking forward to a locker though!
Daneums
Aug 20, 2015 05:36 AM
razorman8669
Jul 12, 2015 12:13 PM
hangtown88toy
Jul 10, 2015 02:33 PM
akaphilly
Jul 9, 2015 02:18 PM
toyoda8488
Jul 5, 2015 10:18 PM
