- Misfire HELP
- Unable to select gears
- harmonic balancer/pulley
- gaskets for timing belt covers - rtv ok?
- Cab Wiring, heelp please..
- Bed Bushings..??
- Trouble after starting Runner, only crawls for first 5 minutes...
- Some snow posers
- engine nosie
- radio interfecence after plugs and wire change? Any ideas?
- Power mirror question
- Rear Control Arm Bushing.
- 2000 tacoma pass. tire fell off help
- Brake help please...
- It's Halloween but...feels like Christmas Eve!!
- Engine Swap?
- checking coil pack resistance
- 5inch lift, thoughts?
- Diff Lock Wiring Questions
- Oil Leak, & Knocking sound?
- New front wheel bearings? Already? ('04 Tacoma)
- Fuel injector HELP
- Clutch advice, opinions
- Posting this up for my brother who's not a member of this site:
- 2000 4Runner 3.4 cranks but doesn't turn over
- Transmission options for a 2000 4x4 auto 4runner?
- two kinds of bilstein shocks
- 99 4Runner Trans Question
- Trip Odometer Stopped
- how do I completely remove a stuck cam/crank seal?
- Transmission noise 98 4runner 2wd v6
- AeroTurbine muffler installed
- Fuel Issues on my 99 V6
- Another Meth addict thanks to Texas Ace!
- Power window issue, just front driver side
- Griffin Radiator cooling solution for 3.4l (5vz)
- 2000 4runner automatic transmission fluid flush
- melted harmonic balancer seal
- Just HOW difficult is it prying headlights apart?
- Sticking caliper pistons. 97 Taco
- 4Runner E-locker axle donor questions
- Re-Flashing ECU for Tranny Swap?
- Rough Idle: 3rz 4 cylinder 2.7L
- towing question
- pro-comp spacer lift
- Diagnostic Issue with my 4Runner - Weird Problem - Any help is appreciated
- Question about rear springs, upgrading from OME 890's, need 1"+ back..
- can someone help translate my Midas receipt?
- timing belt change - factory timing is 15deg off??
- Spider Gears
- spark plug question
- pictures of us towing stuff
- Newb Question - 99 SR5 Brakes
- diff drop recommended with level kit????
- Strawberry milkshake prevention
- Anybody like surf fishing?
- 99 4Runner Limited 4x4 front lift help needed
- Dash lights, orange to green or anything other than orange??!!
- 97 4Runner - Emissions Reset?
- Loose tailgate bolt
- TONS of condensation dripping from A/C Condenser - Why?
- front spool locker 3rd gen problems??
- Seafoam, Marvel Mystery oil, Methanol injection, they really work!
- 12v Power Outlets/Cig don't work?!
- Tie rod removal?
- a343f torque converter question
- Alarm question
- 96 4runner ignition switch
- Changing Lights on instrument cluster
- 1999 3.4L Warm Start issue and code P0171
- Cutting Rear Coils?
- 99 4runner replacing u-joints
- 96 Runner Carpet Replacement
- Body lift noise..
- Turbo 4runner start up, almost done
- Caliper Color Dilemma
- Control arm bushings question
- Rear toe seems to have moved...
- 2002 4R V6 surging on acceleration
- Headlighs dim when heater fan turned on
- Low idle, clicking noise, vibration [video included]
- Starter
- possible evap problem or fuel injector ????
- Transfer Case ?
- Painted my Grille today
- ((HELP)) 01 4runner wont start & dead dash
- Just bought 96 4runner sr5...compression test results please help
- Automatic Diff Disconnect (ADD) modification?
- 4runner steering
- Front diff questions.
- Advice on 96 Runner
- Rough Idle
- Need help figuring out my suspension
- Headlight (HID) Upgrade - "NOTTO" or a better one?
- Burnt coolant smell after driving
- 96 toyota 4runner rear shocks
- Starting issues
- Clockspring - 2003 Tacoma 4x4
- Is stock height of 2wd pickup different from 4wd?
- Throttle plate/linkage will not close unless truck is off!!
- Check Engine Light
- Broken Clock? This Repair Might Help You Too!
- Kevin444's TRD 3.4 SC Dyno Results!
- Tunda Brake Upgrade - Rotors ??
- E-Brake Issues
- Timing belt/water pump write up.
- What you guys didn't tell me about the Tunda brake upgrade
- FRAME RUSTED on your 4RUNNER?
- Roof Rack
- Please help!! Yet another 4wheel drive problem
- Heater Control Valve Cable
- Tube Bed
- New Here with Tire ?
- Swap Tacoma Downpipe Catalytic Into 4Runner 2.7 ?? HELP
- Long shot question
- 97 4Runner Grinding/Vibrating On Acceleration
- 12v Switched power relay & fuse block
- what 3rd member do i have. i need regear
- Rebuilt motor instead of head work?
- 2001 Toyota 4Runner leveling kit?
- 4Runner Engine noise during Acceleration
- 99 toyota engine running badly
- Sudden HUGE drop in gas mileage??
- transfer case compatibilty
- Suspension: Are the Limited / PreRunner 4x4s level from the factory?
- '04 4x4 Tacoma steering rack leak - from the guide
- 4WD conversion ?
- 98 4runner tranny slip
- engine ticking on 1995 3.0
- Need 97 4run rear end replacement advice
- Dreaded 330 325 code Knock Sensor
- Hesitation/No response when hitting gas
- Pictures of 5vzfe water bypass hoses
- Tire Rubbage
- 4runner cylinder head removal
- A/C problems after water pump work
- where to get switched power
- What wheel spacer usually needed.
- Engine whine 5VZ-FE
- oil
- Random Multiple Misfires when hot only.
- Is it my starter? Also ? about keyless entry fix
- towing with moog springs
- Hayden Transmission Cooler
- p0136 with a new sensor
- Just brought home a 2002 D Cab TRD :)
- Something under hood is farting
- Thinking about a 3rd gen, and have a question, roof rack related
- 98 4 runner 3.4ltr 4X4 alt problem?
- diff drop on 3rd gen 4runner
- Cold Start Trans issue
- transmission temp gauge
- 98 T4R Collar nut just would not fit S13WE caliper?
- Crankshaft pulley removal
- Lifting 4Runner with FJ80 coils
- Rear hatch leaking ?
- Taco speed wobble with a load
- Opinions on Belt/ Alternator bearing squeal
- Knocking sound
- **Urgent help needed - oil filter mangled trying to get it off**
- Tick Tick Tick
- 98 tacoma 4x4 wierd front hub ?
- Does your Yota show transmission temperature?
- love vermont hate the rust
- 3RZ Auto to 2TR bell/R150F.. please help
- Keyless entry quit working and rear window wont work with key...
- Just got the 4Runner I have always dreamed of...
- just scored a 96 5spd, elocker, 3.4 4runner for 700!!!
- Do I need new UCA's?
- K&N Installed Now P0171 and P1133 Codes
- 2002 Tacoma 2.7 starting issue
- experienced ISR mod anwsers needed
- Weird Rear End Movement when off gas?
- No complaint frame replacement @ 802 Toyota (Formerly Courtesy Toyota) in Berlin, VT.
- 2001 4runner spark plugs
- Front Differential Noise
- Most miles with supercharger
- 4runner misfire
- Clutch squeak
- 4x4 engaging on its own
- 2wd shifter indicator overlay
- 3.4L V6 Engine wiring harness question
- towing questions
- How to Fix seatbelts & Airbag in a wrecked tacoma
- replaced my recalled tacoma...
- my sas 99 runner on 35s and stock gears VS a stock 3.0 93 4runner DRAG RACE!!!
- Help me find oil leak.
- 3rd gen air intake mod maybe?
- Spring and Shock Replacement
- 97 4 Runner front diff leaking
- 1999 4runner with P0171 and P0303
- 2009 taco trd springs fit 3rd gen 4runner in front
- 2003 D Cab TRD... RUST BUCKET :( arrghh what a waste of a day....
- Engine Error Code??
- need front axle seal help
- Should I replace rear bearing, outer seal & retainers or just inner seal?
- TRD decal removal tips?
- 99% sure Im buying an 03 D cab TRD tomorrow!
- 300,000 mile club!
- Runs rough on start up, lost coolant
- ABS equipped elocker into non ABS 4runner? Complete housing swap.
- diff fluids
- 02 4R Idle RPM?
- Stupid question alert
- TRD elocker swap
- Some frame rust ...your opinions please?
- Learned Something New Today About Dielectric Grease
- "brakes"
- Ongoing O2 Sensor Problems
- Metal Plate inside OEM Bumper???
- How to tell replacement rad
- Tacoma does a 360?!
- 2001 4Runner Jack and Tools Pic Request
- Radiator Leak
- 1997 4runner rack and pinion bushings and ties rods
- Big 3 Upgrade Questions
- Hitch Recommendation for '02 4x4 Xtra Cab
- injectors needed
- 99 4rnr alarm issue, searched searched searched
- problem with 3.4...horrible idle
- Anti-Theft Radio Codes For 1996 4Runner
- rear window goig down at start up
- Possible Tranny, Transfer case, or torque converter problem
- Gas problem, Any help?
- 1999 4runner all black!
- 4.88's or 5.29's Opinions please!!!
- 1998 4runner v6
- Motor Swap, Head Gaskets, etc no power
- What's the best low budget option for getting a replacement differential?
- Which o2 sensor?
- My new truck!!!!
- regular oil filter to filter automatic transmission fluid
- Think I'll need axle shims?
- Gotta spend it! AFR wideband kit
- Drive Shaft/U-joints 96' 2WD Runner
- new idle issue problem P0505
- (First Timer Question) Rear disc brake conversation Vs Tundra Big Brake upgrade?
- More 4Runner help
- intermittent transfer case leak
- 01-04 Tacoma Odometer?
- FJ80 coils AND air bags?
- strange problem
- Loud shrill on acceleration
- Profound loss of power
- Strawberry Milkshake... Is it a worry for Tacomas?
- P0505 Nightmare
- 3.4 spark plug tube grommets
- 99 Runner problems
- P0136 - O2 sensor front or rear?
