front spool locker 3rd gen problems??
Old Oct 20, 2011 | 11:37 AM
drkblu4runner's Avatar
im in the process of 5.29s/35s Detroit rear. i want to lock the front,
was thinking about Lincoln locking the front. but im worried about the extra spinning driveshaft causing the 4runner to pull to to the passenger side.
spool and lockrited will do the same thing. does anyone have ether that can share there experience?
not really worried about braking anything since i mostly snow wheel. and i will be wiring the add to a switch in the cabin. has any one done this with a spool?
thanks for the help
Old Oct 20, 2011 | 12:08 PM
xxxtreme22r's Avatar
Can you explain to me how a spool and a lockrite will do the same thing and what's this extra spinning driveshaft you speak of? You mean the locked side of the ADD and by driveshaft do you mean axle shaft? Regardless if your locked up front or not 1 shaft spins permanently unless you have manual hubs.
I could be completely off base though as I don't know much about the 3rd gens and up. But I believe the concept is the same.
I hope this truck isn't gonna see pavement wet/dry/snow or otherwise with a front locker. Your gonna loose alot of turning ability with a front locker.
Old Oct 20, 2011 | 02:20 PM
the spider gears just spin when its open. locked (spooled or lockrite) the ring and pinion and drive shaft spins.
(no manual hubs)
i dont plan on doing any turning at all on pavement with the ADD locked
im mostly worried about MPG and power and pulling to the side
Old Oct 20, 2011 | 02:31 PM
scuba's Avatar
It's not gonna pull when you're in 2WD.
Old Oct 21, 2011 | 05:48 AM
GV27's Avatar
Seems like it would still be a good idea to convert a rig like this to manual hubs....
Old Oct 22, 2011 | 12:47 AM
manual hubs would be great if it wasnt close to the price of arbs.
Old Oct 23, 2011 | 12:46 AM
scuba you have manual hubs, when there locked does it pull or lose mpg
Old Oct 23, 2011 | 06:44 PM
scuba's Avatar
For the second time, no it won't pull and no it doesn't pull.
I was actually out on the trail today. From one trail to the next there was a couple miles of pavement between the end of one trail to the next. All I did was take it out of 4WD (hubs still locked) and put it into 2WD. It drove just like normal.
You'll be fine.
Old Oct 27, 2011 | 06:43 AM
k thanks, just wanted to be %100 sure before i started welding up my spider gears
Old Nov 17, 2011 | 12:08 AM
decided to keep it open for now. here are the pics with the 35s
Old Nov 17, 2011 | 12:17 AM
dropzone's Avatar
Fossilized
what size rims? those look tiny for 35's
Old Dec 8, 2011 | 03:47 PM
Procomp 16/8
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Steezy96yota
Jul 6, 2015 10:00 AM
toyoda8488
Jul 5, 2015 10:18 PM
