PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Are Tacoma and 4runner Steering wheels interchangeable?
  2. Steering noise
  3. Diesel 3.0 TD engine, information
  4. New on forum
  5. OEM Brakes
  6. Irbis bumper pics?
  7. Sleeping platform blueprints
  8. I need help to clear 285s for cheap
  9. lighting question
  10. 3rd Gen cut-out fender flares?
  11. IPT / Valve body experience
  12. 5spd Tranny oil - Recommendations
  13. 99 3rd gen. heater core removal
  14. Replacement GEN I Supercharger parts?
  15. pics needed of 3rd gen. 3"susp. and 2" body
  16. Champion vs Nippondenso Spark plugs
  17. Supra throttle body
  18. BudBuilt skid plate question
  19. Shifting Problem
  20. Possible problem leading to the Bank 1 too Lean code.
  21. ? about rear speakers
  22. New Wheelskins cover...
  23. Phase 1: Lift: Complete
  24. Atrac?
  25. Fog Light Help
  26. Replacement Spark Plug Boots
  27. New Project in progress - skid plates...
  28. Fun with Herculiner and my new to me yota!
  29. 2007 Yotatech Calendar
  30. Quick Q. Remote Starter - Keyless entry w Factory Alarm
  31. 7th injector question
  32. Brake Rotor Opinion
  33. Limited slip for 96 4Runner rear...
  34. looking at 3rd gen - Q on driveline options
  35. Pics: 295's and 1" BL, + concern update
  36. Rear Axle Issues
  37. Rear Diff question
  38. how often do yo u guys clean the MAF sensor and TB? Also NGK standard plug gapping?
  39. steering wheel has quarters in it
  40. starting problems
  41. LT 3rd gen. rear suspension
  42. :-)
  43. My girl has new shoes and a lift *pics*
  44. possible to convert from auto 2WD to auto 4WD?
  45. 225/70/15 to 265/75/16 - regear?
  46. 3rd Member question
  47. OME Shock Question
  48. 4WD Actuator 3rd Gen.
  49. Bad Luck with O2 Sensor
  50. Rear drum brake leak
  51. body lift installed... ride is different???
  52. Differences between stock 4Runner springs/coils?
  53. 1996 4Runner Engine Rebuild?
  54. Headlamp Protection?
  55. Fuel injector wires question....
  56. Please help URD FTC wire color question.
  57. pics of my lift...
  58. Turbo Diesel in a 4Runner?
  59. Help URD install in RH Drive
  60. Just got some Tokico Blue Struts
  61. Coil Spacer Questions
  62. APO Front Bumper
  63. Ordered URD 190lph fuel pump...how difficult is it to install?
  64. Slight Brake Noise
  65. Dealerships
  66. New ( To Me ) 16" Wheels and Tires
  67. Is this smoke a bad thing? VIDEO
  68. Front End Squeak
  69. need pics of the tjm-17 with limited fender flares
  70. Driveshaft ?s and fitments from other models
  71. Carbon Fiber Ideas for my '99 T4R
  72. Ideal Slider Length
  73. Manual hub conversion kit for 03 tacoma
  74. touched up my sliders and started on my hitch...
  75. Clicking - Moved Ground
  76. Auto UP window goes up, then back down?
  77. Slider length
  78. cat conv o2 help 00 runner
  79. Bi-Xenon HID Conversion
  80. Which shocks to replace OEM (no lift)?
  81. 4R Shock Choice
  82. P0171: trouble root causing
  83. Lexus Badge Sizes?
  84. 99-02 headlight assembly on a 96-98 possible?
  85. CRAZY brake prob!
  86. Trailer Wiring Harness Support Part Number
  87. Grill-mounted High-beams finished
  88. shocks struts???/ Possible lift
  89. HID retrofit completed
  90. Stole Ebelen's Jaos bar...
  91. Moto-Carrier and effect on 4runners
  92. TRD/OME lift, which shocks?
  93. emergency brake probs, searched.
  94. Anyone using a Warn XD 9000i ???
  95. tundra lift gone sour
  96. excessive clicking, no starting
  97. Coil Spacers
  98. got 295's. body lift, yes or no? poll
  99. Please identify this part and tell me if it bent!!
  100. How much oil should a 5vz-fe engine consume between changes?
  101. Spark Plug Boot
  102. 4Runner: LED Blinker moved to Aux, Driving light installed in Blinker spot
  103. toyota oil filter
  104. 1999 2.7 liter engine Pre-Runner questions
  105. Replacment of Leaking PS Rack
  106. Ever completed a "top and tail" cab swap?
  107. Write-up for polishing/sanding dulled headlights? can't find it
  108. 4runner rear susp. Q
  109. whats the harm in running 1 rear wheel with much lower Backspacing?
  110. BBS FJ Cruiser wheels on a 3rd gen?
  111. codes for a 3rd gen
  112. clutch kit replacemen - help
  113. Gear Shift Movement - 2000 4 Runner SR5
  114. Not another slider thread
  115. New Member (Pics + Mods)
  116. Weird brake failure
  117. The wait is finally over! Pics from INSIDE my camper! (low BW, grab some popcorn)
  118. Severely-corroded rear heater pipes - 4Runner
  119. Lovger cv boot/ R&P bushing
  120. Lights on a Stock front bumper
  121. PS steering pump 3rd gen
  122. panic button makes remote starter/alarm install expensive?
  123. RE:2003 Tacoma DRL
  124. sliders
  125. 90k mile service quote
  126. help on ABS light
  127. chop exhaust pipe?
  128. Cruise control disengages
  129. A long time coming... HID Projectors
  130. My Yota is totalled... :( Worth repairing?
  131. Ivan Stewart Rims/Tire Size?
  132. Stock Alarm question (disabling)
  133. Poly bump stops
  134. 3rd Gen 4runner Front Lift
  135. Oops! Time for a new fuel tank?
  136. How do you check engine problems without a CEL?q
  137. why leafs
  138. Help..... Misfire on #6 cylinder code P0306
  139. Where are my 95.5-04 Exhaust experts?
  140. $375 to detail my 3rd gen.?!?
  141. Few questions on DIY front brakes....
  142. Supercharger install/removal write-up?
  143. Aftermarket Sunroof, Would I be doing a stupid thing?
  144. arb, tjm or similar w/ fog lights
  145. rear shock bushing size?
  146. 96 4Runner - possible tranny problem?
  147. Passenger Airbag Indicator Light Problem
  148. OEM leather replacement options?
  149. Leaking Coolant - Cant find Leak
  150. Rear Wheel Bearing replacement - how?
  151. 98 4Runner Door Trigger Wiring
  152. 96 Tacoma 4wd: drivetrain click/ping sound
  153. bushwacker question
  154. Rear diff fill plug rounded off
  155. Help needed with part number for tonneau cover
  156. 5VZ Stroker Kits ????
  157. Unorthodox Lightened Crank Shaft Pulley
  158. grey wire locker mod?
  159. 3.4L Supercharger: Which injectors fit?
  160. RE-TAPPING a 3.4L TRANSMISSION PAN DRAIN PLUG
  161. New muffler installed, low end torque lost. questions.
  162. Reorganized and redesigned 4Runners.org website
  163. 96 runner with sagging rear coils
  164. bobbed/trimmed mud flaps, thought i might show yall
  165. TJM and 2" body lift
  166. towing with '98 4Runner (manual V-6)
  167. Aftermarket lighting
  168. Question reguarding OEM wheels
  169. help! - Alarm shut off the vehicle
  170. Tensioners?
  171. Oil pan removal-Which way is best???
  172. alignment ,tampa?
  173. my cheap alternative to the husky floor mats
  174. stock tacoma lift upgrades?
  175. Clutch troubleshooting manual (online)
  176. Pricey lifts
  177. Oil pan gasket/change
  178. Anyone have pics of a ARB winch bar on 96-98 and 99-02 4Runners?
  179. Valve Cover gasket replacement-Job for amateur??
  180. New clutch - recommendations
  181. Got Custom Traction Bars....A Necessary Mod IMO
  182. Noise from dash should i worry?
  183. Did anybody upgrade tire/wheel from 225/75/15 to 265/70/16?
  184. diffarential lowering kit
  185. 98 tacoma V6.valve adjustment ???
  186. Cleaning MAF
  187. Black residue all over interior
  188. Front Coil Springs-'98 on '00-will they fit??
  189. Tranny / Clutch Problem
  190. Rear Brake Line Replacements?
  191. Death to TRD S/C :(
  192. 4WD Light Blinking
  193. Front Stabilizer Bar Question?
  194. door panel replaceents
  195. need list of airbag companies
  196. identify two parts and their purpose please (under chasis)
  197. Girlfriend wrecked my runner
  198. Tire/rim question!(Tacoma)
  199. Rear End shocks to match the Tacoma Tokicos up front...
  200. Fan Under the Passenger Seat
  201. 96 Tacoma 3.4L 4x4 - Belt Replacement Advice
  202. cheap way to build a spare tire carrier for te stock roof rack
  203. Write-up on swapping 01+ tail lights for 96-00?
  204. Pinging or knocking noise 98 V6
  205. Oil Pan Gasket Leak - Questions+Picture
  206. Can't find a strut/shock replacement write-up?
  207. Functional Fiber Scooped hood available?
  208. Need help with rough-running 1998 4Runner
  209. Dash lights not working - Boost Gauge Install??????
  210. Would you consider a 3rd gen 4runner with 300k miles?
  211. another PO171 code...
  212. Ok, I said I wouldn't but S/C my 98 with 131k ???
  213. 4wd not engaging
  214. Still getting a Thud / Knock !!
  215. tundra calipers - man did I get a deal!
  216. 2.37" Pulley = 5psi?? Help!
  217. 4Runner Stalling Problems
  218. Is replacing the MAF really worth it?
  219. what else do i need for my lift?
  220. I hate my luck rolled the runner
  221. Grease from CV joints after lift adjustment?
  222. changing out the rear shocks
  223. Magnaflow 5x11x28" 1st week impressions
  224. Traction Bar For 02 DoubleCab
  225. 4wd will not disengage '00 4runner limited
  226. Tundra Brakes & ABS - ???
  227. Thinking of modifying MAF. Need your input please...
  228. my rear dome light isnt working right
  229. replacment parts
  230. who has 285's on a SR5
  231. Bad "Bucking" When Accelerate In Sand?!?!
  232. Elbow Intake mod (alternative to the deckplate)
  233. Difference in rotor size from 4runner and Tacoma?
  234. fix for tight fitting true flow airfilters---round off the top corners
  235. replacing synchronizer ring (synchro) + replaced clutch + grinding noise?!?
  236. New injectors: Help needed ASAP!
  237. Correct rear drum adjustment?
  238. Starter Problems
  239. 02 4runner shifter after 2" BL
  240. valve lash for EB 268 cam?
  241. Temporary CV boot fix?
  242. Belt squeel resulting in blown AC fuse
  243. High pitch noise when using signal
  244. 4Runner recall on rear springs
  245. Addco Sway Bars
  246. Inner diameter of OEM transmission hose
  247. Parking/Hand Brake Problem... I think
  248. Side or Rear exhaust on a '99 4Runner...
  249. Brembo rotors slotted and dimpled for $220, are you interested?
  250. Car alarm and door locks intermittently dont work
