- Grinding/Roaring noise from rear third
- You've been doing it wrong. Seafoam injection port
- any pics of a 3rd gen w/ ARB & Bug Deflector
- Clunking on Rolling Start, Deceleration to Stop
- steps up to roof
- how to raise the voltage to 14.8v?
- Front End Vibration Mystery
- Replace those tailgate cables NOW
- Dual exhaust
- Tie Rod Failures
- Power locks only unlock
- Speedometer always reads 5mph slow
- Squelling/Howling Sound
- Lift Question
- o-ring problems
- Just upgraded to an 01 4runner, Mods?
- choke sticking / process to clean choke / recommendation for brand
- Broken Connecting Rod Bolts
- newbie*** 95 taco 4wd not engaging is these ADD STYLE?
- Preventative Maintenance 96 4X4
- Cv boots rubbing after 1 3/4 inch suspension lift installed.
- JerryRig Tie Rod fix?
- Tundra Coil/LC coil lift advice
- Extra TRD Supercharger Dynamic Tensioner Bracket?
- transfer case
- Crazy starter issue (maybe contacts?)
- old pinion new ring
- Low start idle & low power 45-60 mph
- Key wont turn in door, and wont lock/unlock, plz help!
- Paint 3rd Gen Limited Fender Flares
- Can anyone guess (or know) how much ATF the cooler holds ?
- NwRunners Runner Resurrection
- Alarm bypass for a 1998 4runner? what do you guys use?
- 00 Tacoma CV Boot Replacement
- Slight Hesitation During Start
- Moving to CO: any high altitude mods needed recommended
- glove box light switch, where is it?
- 98 V6 4runner Engine Ticking, any thoughts`
- Which way does the orange and black check valve go back on?
- Turn signal issues
- coil over not lined up
- 3.4 enine wiring harness
- 1997 4 runner has a misfire
- Question and possible answer for P044x codes
- auto trans flush
- Suspension SOS!!
- 2001 4Runner Light bulbs question ?
- Brainstorming: 3rd gen w/ removable top
- miss fire, no codes.
- Passenger headlight not working
- Head Gasket Dilema?
- P1135 A/F sensor code
- Front bumper for a $850 budget, 04 Taco
- Forward shift r150f
- Torque for fan bracket (fan clutch)?
- HELP!! stupid alternator connecter
- 01 rear diff lock
- 03 Tacoma clutch engagement range
- ABS Disable Solution...
- Bizzare icing problem caused by hood-scoop
- Removing Rear Differential Carrier
- 2000 tacoma prerunner 3.4L wont accelerate
- Rear coil spring removal/install
- Headers for 98 3.4 4Runner
- Rear brake/ebrake adjustment
- 4Runner P0420
- 97 Ltd. 4WD stuck in Neutral
- Paint Matching Technical Advice Needed (California)
- 3.4L heating issues
- Cylinder 5 & 6 Misfire and multiple misfire..:(
- HID retrofit PART TWO! (new shrouds, CCFLs)
- snugged up all throttle body cable slack, it is like a new rig
- 3vze in 98 4runner???
- Where is the alarm beeper?
- Help: MPG drop after T-belt, WP, t-stat, etc.
- 02 4runner alarm problem
- Aftermarket liftgate shocks - have you used some??
- dead master cylinder?
- Replacing CAT Converter in Ca
- rough idle right at start
- What are possible causes for howling from the front?
- replacing drivers air bag?
- 3.4L Oil Capacity Differences?
- E Brake light
- Several Misfire codes, fuel pressure issue?
- Pulling car on tow dolly '00 4Runner
- Need to upgrade my air intake/filter.
- replacement fuel pump
- What is a typical Mass Air Flow (MAF) Sensor response
- 3rz Coolant loss
- Putting Taco Diff lock in 4runner.
- 3rd Gen 4runner rims: which one?
- 3rd Gen Traction Control
- fiancee's 98 runner bad injector?
- FOR SALE! OBX headers for 2000-02 3.4L tacoma
- Officially change the color of your 3rd gen 4runner clock
- Different size spark plug?!
- Gadget's prototype URD supercharger for the 3.4?
- whining drivetrain noise?
- disabling headlight flash during alarm
- Addco Sway Bar for Tacoma
- 98 tacoma tach wire lead?
- fuel filter?
- whining sound when coming to a stop in first gear
- No CEL, but code pending and Transmission thunk.
- Do I Need Spacers
- 4Runner 8" or 8.4" diff
- to prevent "strawberry milkshake"
- P0505, P0110, and P0120
- 2001 4runner SR5 nothing on # 2 ?
- 1998 4Runner rear sagging but I do not want a lift
- 3.4L Bogging down and chugging at idle?? Help?
- Brake issue...PLS HELP
- Buying A Radiator... New v.s. Salvage
- A few problems with My 95 Tacoma
- 99 limited 5-speed swap
- '99 4WD V6 4Runner - Transmission resistance and hesitation
- P1121 APPS need help with this dilemma
- Transfer case won't shift!
- OME60028 dimensions?
- Koyo A1998 Radiator
- Auto tranny Stuck in Neutral
- 5mph with RR DIFF LOCK on?
- Need some help diagnosing a diff / oil leak
- And another strawberry shake!
- odd whining noise
- Tacoma Camber Limit
- 2001 V6 PreRunner won't start after cleaning throttle body.
- Cracked Windshield.... now what???
- Valve Cover Gasket Replacement Help
- recent maintenance
- difference between taco and 4runner RR diff lock ECU
- auto trans i need help!
- Timing belt, Water pump replacement parts
- Rear (After-cat) o2 sensor & fuel.
- Question about greasing propellor shaft and U-joints
- Speedometer going haywire.
- Rear Main Seal Replacement and More
- Somebody mentioned have a spin on filter for their trans
- help. trying to put buckets in the back of dc taco
- Mouse in Engine Bay
- Flickering Fog Lights
- 98' 3.4 and 01' 3.4 differences
- Anyone else replaced oil seals in txfer case?
- What are these? 3.4 Intake tube
- So I've made battling the Strawberry Milkshake my personal conviction
- Yet Another Tundra Big Brake Upgrade
- Name that part #!
- Help Blending Paint/clear coat help?
- My upcoming work
- Nuts rusted off, problems installing O2 sensor
- How long should Bilsteins last?
- Post your pics please
- another o2 sensor question
- 1998 5VZ-fe tick/knock advise needed
- check out my 3rd gen runner
- Replaced my fan clutch...... WOW.
- Milkshake aftermath radiator problem,need help!!
- Interior light problem, HVAC question
- Drivetrain problems!!! Help!!!
- 4WD not engaging (but light is on!)
- Left rear brake sticking
- 3rz from 01 4runner into a 97 taco
- Question about 4runner with blown HGs
- Hunting with the 4runner...
- 98 dooor lock problem
- valve adjustment
- Front Differential Oil Seal Stuck
- new clutch going in
- Grinding noise?
- Cruise control quit engaging
- what to do? power steering pump.
- Jerry Can Mounting Ideas?
- 98 taco 3rz- odd "ticking" at idle when warm
- Poser pics of my new to me Tacoma
- best gears with 32" tire?
- 296,700 Miles Now Equals 0
- 2rz-fe 2wd swap
- 1998 Toyota 4Runner Timing Belt and Water Pump Replacement
- Can't get out of park need help!!!
- what selectible front locker?
- 2000 4runner limited, fog lights don't work!
- 97 4 Runner 3.4L Engine Noise
- FJ steelies & 255/75/17 Hancook AT
- 700 Grizzly vs 01 Taco
- Oil leaks Oil leaks and more leaks in Virginia
- axle question?
- Weight of stock '99 - '02 front bumper?
- I've been hiding something
- rear diff
- Factory transmission cooler capacity...?
- Jumping diag. connector steps needed 99 runner
- Balancing tires on 96-02 Haweka vs Hunter flange adapter?
- lack of power and increased fuel consumption
- Panhard Bar / Track Bar Bushing?
- OME 891's - what kind of additional weigh?
- Did some fiberglassing over break
- Coilover Questions
- 1996 4runner diff lock not engaging
- Cylinder 3 misfire
- 1996 4runner RPM gauge needle going crazy
- Throttle Cable - where to find?
- misfires in bank 1! HELP!
- Finding Rear locker electronics
- New and need some direction
- Will a 4wd 97' Auto Harness work in a 2wd 99' Auto 3.4
- suspension upgrade job
- hanger rusted off exhaust
- Aftermarket Flares, Picture request
- trailmaster to fabtech swap
- Not your average-run-of-the-mill heating issues!
- Battery Draw?
- 99 Limited - Keyless entry is driving me crazy
- Door lock replacement 96 runner
- 03 Tacoma 5 spd trans interchangeability
- 2000 4Runner transmission issue
- Random rear brake lockup
- Washer fluid bottle relocation?
- 2000 4Runner 4WD light won't turn on....
- Picture Request - 4WD ADD Vacuum Can
- Misfire under light load
- OME front Strut install Screw Up
- 4x4 vibrations
- Transaxle Actuator Alignment
- Center Differential
- 96 Tacoma a few issues
- Help install Toytech Coilovers
- 5vz-fe Stripped top idler pulley
- Sluggish after tranny cooler install
- '95 2wd Taco rear-end interchangability
- 3RZ radiator hose temp question
- Eaton M62 Supercharger question...
- CV boot barley touching
- '98 4runner that runs rough than stalls in gear
- power steering pump noises
- Burning clutch smell in engine?
- Family of 4Runners
- Smog check ordeals
- Broken wiring under hood
- TJM T-15 and winch, please post pics
- Code P0171 Air Flow or Oxygen Sensor??
- Diff Drop spacer on stock skid plate
- Automatic Transmission leak (rear)
- Fitting a Tacoma ARB onto 4Runner
- Strange Transmission Issue
- P0136 and P2238
- Help Diagnosing a Noise
- 2001 Wiring Diagram Needed
- Tundra Bilstein 5100 Adjustables on 3rd gen?
