auto trans i need help!
Old Jan 20, 2011 | 07:48 PM
toykidd's Avatar
ok so i have had this recent problem and i have looked through lots of threads and cant seem to find any about the problem i am having. ok so its kind of hard to describe but when im driving at highway speeds and i get to an uphill part of the road my trans seems to slip momentarily then catch this will happen 2-3 times until i speed up a bit and i cant seem to pinpoint what would cause this so any suggestions would help
thanks in advance
Old Jan 20, 2011 | 09:23 PM
weaselman's Avatar
1st. we need more info.
what year truck? what trans? what engine? etc.
i am assuming the truck in your sig? but you never know.
Old Jan 20, 2011 | 09:38 PM
vital22re's Avatar
totally a bro
have you checked your transmission fluid? How about your radiator fluid? Its common for the trans cooler in the radiator to fail and you end up with a strawberry milkshake and a failing transmission. Many threads on this.
Old Jan 21, 2011 | 11:12 AM
toykidd's Avatar
yeah the truck is exactly whats in my sig checked my trans fluid right when it happened the first time and everything seems fine... and i dont think its the strawberry milkshake because im not getting any over heating temp is right in the center the whole time... could it still be?
Old Jan 28, 2011 | 05:39 PM
rbarthol's Avatar
might be your overdrive, disengaging and not engaging quite right.
maybe a shift solenoid for od? or that gear?
Old Jan 28, 2011 | 05:53 PM
Kiroshu's Avatar
Sure its not low on fluid? Slipping on an uphill seems to me like its a lil low on fluid. You know you have to check trans fluid with the vechile at operating temp and running.
Old Jan 29, 2011 | 01:35 PM
Ohio4R's Avatar
What gears are you running? Seems pretty normal to me when running oversized tires on stock gears unless you have 4.56 gears. I run 4.10 gears with 285/75/16 and it seems like it slips going up hill sometimes.
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Lcb98toy
11
Aug 26, 2015 05:28 PM
this_guy
Jul 31, 2015 01:27 PM
D.B.T. 87 4x4
Jul 20, 2015 04:51 PM
andrewtexas123
Jul 14, 2015 04:29 AM
