3rz Coolant loss
Old Feb 2, 2011 | 08:10 AM
FUNrunner87's Avatar
3rz Coolant loss
I have a 99 tacoma 3rz that has about 135k on it. I have been loosing coolant for the past 6-9 months. I can not find the leak. I can run a tank of gas threw the motor and go from having a full resi to just a few drops. I dont see water leaking anwhere. Is there any common places it could be leaking that im just not seeing? I want to do a Compression test but cant find my tester... would that be a valad way to check the HG? I see the normal white smoke on cold starts, it goes away after a few miles though. I see some water dripping from the exhaust once its been running a wile (5mins +) but thats normal correct? I have pulled the dash and inspected the heater core even though the passanger floor was dry. It looked brand new and I cant see anything pointing to it leaking. I dont really know where to start from here.. I need some pointers. Any help is great!!!!!
Old Feb 2, 2011 | 08:36 AM
brian2sun's Avatar
I would do a compression test like you mentioned, and if that doesn't give you anything to go on, you can do a leak-down test too. A cooling system pressure test can be done also. Is the engine missing/stumbling or have you lost power?
Old Feb 2, 2011 | 08:59 AM
The engine does not miss that I have heard, but I have not been listening for it. It still has the same ole power as before. I dont have any codes and the Cel light works (per key turn test)
I Dont find any coolant in the oil. If it was a leaking head gasket it would bubble up in the radiator correct? I should be able to take the cap off once its cold and let it run at idle. Once the thermostat opens I should see bubble if thats the problem.. Correct?
Old Feb 2, 2011 | 10:19 PM
NwRunner's Avatar
Ive been having the same issue in mine for about 2 years now. although not as rapid, ill lose about a resi every 2 weeks. I ended up changing my HG because of it but it didn't fix anything. Try looking at your water pump, I mean really looking at it. a slow leak from there could.
Also check the water return pipe located on the back of the motor between the head and the firewall.
Old Feb 3, 2011 | 07:30 AM
profuse007's Avatar
radiator crack are hard to find. I would start there.
Old Feb 3, 2011 | 07:45 AM
Is there any place they like to crack, or is it a random thing? what are some ways to check it in the truck??
Old Feb 3, 2011 | 08:20 AM
snobdds's Avatar
Pressure test your cooling system. That should show where it is leaking from. It that is normal, then I would do a compression test. Those two test should tell you what you need to know.
Old Feb 8, 2011 | 06:32 PM
A small update on progress. I pulled the radiator cap and let it run for a wile. I watched for bubbles. The coolant level slowly came up and slowly started to run over. I saw one or two bubbles but nothing that looked wrong. I pulled the plugs to see if maybe if one plug looked clean showing signs of a leak. All 4 where nice and tan and looked great. I guess the next step is to find someone with a pressure tester.
puddlepirate
Jul 30, 2016 06:29 PM
alexcarey
Oct 14, 2015 06:05 PM
shredder4286
Oct 1, 2015 01:09 PM
puddlepirate
Sep 29, 2015 08:02 PM
Shagool22
Sep 28, 2015 07:53 PM
