Weight of stock '99 - '02 front bumper?
Old Jan 7, 2011 | 10:14 AM
aowRS's Avatar
I'm interested in purchasing a basic Shrockworks front bumper for my '01 4Runner, but want some assurance that the truck will keep its current stance ('99 coils & Bilstein HDs). Does anyone know what an entire front bumper assembly from the '99 - '02 model weighs?
The Shrockworks bumper w/o hoops weighs about 98 lbs.
Here is the version:
Andreas
Old Jan 7, 2011 | 10:21 AM
badattitude's Avatar
Good question, I've wanted the answer to that question as well.
Old Jan 7, 2011 | 10:28 AM
waskillywabbit's Avatar
Can't be more than half that if that.
If you add a winch, then you might notice some sagging.
:wabbit2:
Old Jan 7, 2011 | 11:38 AM
scuba's Avatar
Stock plastic is about 20 pounds. It will sag with the weight of a heavy plate bumper.
Old Jan 7, 2011 | 11:40 AM
aowRS's Avatar
20 lbs? Top trim piece, chrome portion, lower valence & brackets. Really?
Andreas
Old Jan 7, 2011 | 01:38 PM
I think the whole thing is closer to 50lbs
Old Jan 7, 2011 | 01:58 PM
fireball's Avatar
Andreas,
I do not know what the stock bumper weight is, however the front of my vehicle sagged less than 1/8" after installing the SW bumper. I do not have a winch, and have the single hoop bumper with a set of fogs and a set of driving lights installed.
I have the "Tall" springs on my Highlander edition, so perhaps that is helping things out. I was pleasantly surprised that A) the SW bumper wasn't all that heavy and that B) there was no noticeable sagging.
Height with the stock bumper, etc was 35 1/2. With SW, it now sits at 35 3/8. Might be 35 5/16.
Hope that helps.
Old Jan 7, 2011 | 02:29 PM
aowRS's Avatar
Originally Posted by fireball
Andreas,
Hope that helps.
Ball of Fire,
That helps - thank you! I installed a fresh set of '99 coils & Bilstein HDs more than 7 years ago, so I'd be starting with the same stance as yours.
Although the sag was minimal in your case, do you notice increased bounce when hitting dips in the road?
Could you post a pic of how the bumper looks on your truck?
Andreas
Old Jan 8, 2011 | 05:09 AM
fireball's Avatar
Sorry I don't have very good photos of it. Front quarter shot and then some close-ups. The tolerances and gaps are perfect. Fit and finish are top notch.
Old Jan 8, 2011 | 05:12 AM
aowRS's Avatar
Super nice!
Andreas
Old Jan 10, 2011 | 07:43 AM
Bandit Runner's Avatar
My stock bumper from my 2002 weighed about 50 pounds. When I replaced it with my custom bumper weighing about 100 pounds, the front sagged only 3/16". (I measured very carefully, before and after, because I was curious too.) This was with my stock front springs. Hope this helps.
Old Jan 10, 2011 | 07:45 AM
aowRS's Avatar
Excellent - thank you.
I'm curious if one could add some sort of 'trim packers' directly above the strut bushing to regain the lost height? In other words, shimming the entire strut assembly down.
Andreas
Old Jan 10, 2011 | 08:37 AM
sabre's Avatar
Sort of off topic but my front bumper chrome piece is rusting and would like to replace it with a stock one in if anyone here has one in good shape they want to get rid of. I would replace my back piece also if anyone has that as well. Thanks
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
Vargntucson
Jul 4, 2015 12:15 PM
