Addco Sway Bar for Tacoma
Old Jan 29, 2011 | 01:18 PM
Taro's Avatar
I just purchased a Addco 1 1/8" bar for my 04 Taco. I searched and found a limited amount of info on Tacos and a lot of stuff is years old.
I'm trying to find replacement end links. The factory end links don't have enough thread on the bolt that mounts to the new thicker bar. I can't seem to find anyone that sells aftermarket endlinks. Addco's website is junk and doesn't give any information.
I would like a set of disconnects if I could find them.
I also need a different frame bushing. The including bushing did not come with a bracket and doesn't fit in the stock bracket.
All my searching found some info that suggests aftermarket frame bushing/bracket kits are weak and can break. But that was years ago. Is this still an issue?
Any help is appreciated.
Old Jan 29, 2011 | 02:08 PM
okie81's Avatar
Why don't the taco kits come with endlinks? I had the same prob with the frame bushing and energy suspension made a bracket for the larger size.
Old Jan 29, 2011 | 03:32 PM
Taro's Avatar
It came with frame bushings that doesn't fit the factory bracket and 2 end link donut bushings. That's it. No instructions either. If I needed new end links I would have liked to know in advance of attempting the install. Same goes for the bushings.
Old Jan 30, 2011 | 01:43 PM
courtgordon's Avatar
thats why i said screw it and just took my front sway bar off its better for offroad and i like the lean it has now through corners. ide see if you can run without one safely then you dont have to ever deal with corroated bushings or broken end links
Old Jan 30, 2011 | 01:59 PM
4Crawler's Avatar
Many auto parts stores carry generic end link kits, I know Pep Boys and Kragens/O'Rielly carry them. Or just get a longer bolt for the ones you have if it a simple version with a bolt, sleeve and the bushings/washers.
For disconnects, here is an option:
- http://www.4crawler.com/4x4/CheapTricks/SwayBar.shtml
Old Jan 30, 2011 | 02:12 PM
Taro's Avatar
This is not an option
Old Jan 30, 2011 | 02:20 PM
Taro's Avatar
I am open to all options and if this works ill do it.
My links have 90 degree ends on both sides. Forgive me but I don't understand the universal stuff would work.
punks_is_4x4
May 31, 2016 06:03 AM
choppe777
May 16, 2016 08:00 AM
mirabile4runner
Sep 3, 2015 07:15 AM
mistershmi
Aug 31, 2015 03:44 PM
bobjohnson2121
Aug 28, 2015 04:02 AM
