98 V6 4runner Engine Ticking, any thoughts`
Old Feb 13, 2011 | 04:11 PM
chris383's Avatar
Hey, I just bought my 3rd 4runner, a 98 sr5 with 260k kms on it. Runs great, except the is a ticking from the engine, and its frequency goes up with the RPM. Does this sound like common valve noise? Not sure if its a related problem, but I can hear the ticking intermitantly through the speakers.
Any thoughts would be great
Thanks
Chris
Old Feb 13, 2011 | 04:40 PM
survivorman97's Avatar
You know I thought I heard ticking once through my speakers too. I didn't really have any loud engine ticking noise but the ticking in the speakers was definitely at the same rate as engine rpm, but it was only for like an hour or so one time. Maybe your wires are bad and a little of the spark is arcing?
Old Feb 13, 2011 | 05:07 PM
prorunner's Avatar
Ticking from the engine? I'd check the oil.
Ticking from the speakers? Could be some bad grounding on your head unit.
Old Feb 13, 2011 | 06:55 PM
ntoracn's Avatar
bad plug wires can cause RF noise to be heard from the radio system. AM radio is REALLY sesative to these RF signals. Check your wires for arking with the engine on in a VERY dark place (no lights). Your looking for tiny blue spark leaks from the plug wires.
Old Feb 14, 2011 | 09:42 AM
chris383's Avatar
Valves
Thanks, I'll check the spark, although my old 4runner had this arcing issue when I bought it, and this doesnt seem to be the same. Sounds to me more like valves. anyone have exteriance with the vale ticking issue?
thanks
Old Feb 14, 2011 | 08:31 PM
ntoracn's Avatar
what engine do you have? excessive valve lash, exhaust leaks are most common source for ticking noise. Some noise has been associated with part of the fuel evap system. make sure your oil is full of clean oil and you have a good oil filter. does it make the noise most when hot or cold or both?
Old Feb 15, 2011 | 05:02 AM
cordrayj1's Avatar
make sure all ur spark plugs are snug. you can damage the motor if there is a loose one. also, sounds like your electrical needs to have the grounds checked.
Old Feb 15, 2011 | 07:24 AM
4biker's Avatar
I've done some checking on this, and found that some of the earlier 3.4's have a tick. Mostly it's '97's from what I understand (like mine) - although some with '96's and '98's have reported it too, and it's pretty benign. I've read up on adjusting the valves, and it seems to be extraordinarily difficult on this motor for some reason, and doesn't even always cure the tick. Mine has ticked for as long as I've owned it, and it's never gotten worse (wasn't too bad to begin with, it's just faintly there in the background). If you find anything else out, let me know - I certainly don't want to promote inaction if damage is occurring. Best of luck, and welcome to Yotatech!
Old Feb 15, 2011 | 12:09 PM
chris383's Avatar
ntoracn: I have the 3.4. The ticking seems to be consistent hot or cold. Oil is fresh, and at proper level.
I'll check the spark plugs tonight
Old Feb 15, 2011 | 12:40 PM
my 97 3.4 has a bit of an intermittent tick too. It's done it for about 100,000 miles now and never really changed.
Old Feb 15, 2011 | 01:37 PM
spokane.yota.man's Avatar
My 98 just recently picked up a tick from the charcoal canister. Only does it when cold, like 20 deg or less outside, and only at idle. Buy a mechanics stethescope, they work wonders when tying to find noises.
Old Feb 15, 2011 | 05:06 PM
ntoracn's Avatar
OK, the oil level is good. when standing in front of the vehicle while its running, what general area does the noise seem to be coming from? I wouldn't be concerned about causing more damage just yet, lets try and narrow down the source before we determine if its a real problem or just a "normal" 3.4L noise.
Old Feb 17, 2011 | 05:53 AM
drift_king's Avatar
my truck recently started ticking, then it turned into a knock, pretty sure its a rod
Old Feb 17, 2011 | 05:55 AM
Team420's Avatar
Ur injectors r prolly dirty... They tick even when new, so unless it's a knock, I'd just turn the radio up, and call it a day
Old Jul 11, 2012 | 10:06 PM
Cheb's Avatar
You guys are serious ,plugs, i think my engine is done now and its too late ,im going to check tomorow for the plug, maybie i ˟˟˟˟ed up went i instaled it.
Sorry for my english im french from montreal
Quebecois
Team420
Jan 12, 2021 04:57 PM
Ichneumon
Sep 27, 2015 04:21 PM
noahstancik
Jul 10, 2015 11:18 AM
njomba
Jul 9, 2015 04:21 PM
Old Red 94
Jun 16, 2015 08:32 PM
