CV boot barley touching
Old Dec 26, 2010 | 10:04 PM
Tracmstr's Avatar
I cranked my Knig coilovers so the CV boot is about 1/16 of and inch from touching is this mproper or should i lower the height a little i was told as long as the cv boot does not touch that it would not damage my cv's is this correct or do i need to lower my coil overs Thanks
Old Dec 27, 2010 | 06:28 AM
Yota Runner's Avatar
You should post up some pics....
Old Dec 27, 2010 | 06:30 AM
BajaRunner's Avatar
What are they 1/16" of touching!?
Do you mean that the clearance between the fins are 1/16"?
If you've never changed your boots, chances are they will blow. The actual CV joint will not be destroyed though.
Once you get new Toyota boots on, they will last for quite a while with that angle. I'd probably tone them down to as little as possible though. Are you rubbing or just want extra height? If its the height you want, throw on a 1" BL or something!
Old Dec 27, 2010 | 11:08 AM
cordrayj1's Avatar
do they make the boots like the older yotas had with the fins being farther apart?
Old Dec 27, 2010 | 04:27 PM
Tracmstr's Avatar
fins on boots
They r not touching just close to touchin g but i thought as long as they arnt i would be fine, i just put a OME 891 with OME shocks on rear and i wanted to get a little extra height in front i had not really cranked on my Kings and i did now and it sits slightly higher in rear which is what is wanted but i just wanted to know how far i could push it on the coilovers the ride still is nice but the fins r about 1/16 away from touching and dont want to mess up my boots
Old Dec 27, 2010 | 06:02 PM
nv4runner's Avatar
The more angle the CV joint has the harder it is on the boot[period] Eventually all CV joint boots fail due to age and deterioration[comma] but doing things like installing lifts without dropping the differential will increase how far the boot has to stretch[period] The more stretch the sooner it will split and the sooner you[apostrophe]ll have to replace the boot[period] On the other hand[comma] you could just let the boot split and keep cleaning and greasing the joints a couple times a week and not have to worry about it[period]
Old Dec 28, 2010 | 09:18 AM
Is this turning into an english lesson?
Old Dec 28, 2010 | 08:53 PM
Tracmstr's Avatar
all pro diff drop
Just got the diff drop and installing tonight that will help so i can keep the hieght and sav the boot
4banginRunner
Nov 13, 2015 05:23 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
89YodaRunner
Sep 30, 2015 02:18 PM
Odin
Sep 26, 2015 06:56 PM
Rcbc92
Sep 26, 2015 03:00 PM
