PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. 87 tailgate handle??
  2. Ignition retard on s/c 3.4
  3. frozen antenna
  4. Questions about my 4Runner
  5. when you put on the Supercharger, do you install header and exhaust ?
  6. question regarding the Magnaflow muffler 14 inch and 24 inch
  7. my body is uneven
  8. best exaust for power?
  9. Check out this new background I just made.
  10. 2nd gen rear suspension ?'s
  11. Thermal Vacuum Valve
  12. A/T ECT question
  13. more opinions
  14. Front end noise in Cold - Manual Hub Fix
  15. Inland Trucks
  16. Pwr Antenna Died
  17. steering shaft
  18. whats the secret to timming
  19. Quick Question
  20. Which rig is best for me?
  21. engine swap questions
  22. Wet Okole Installation
  23. 96-96 4runner turn signals as Daytime Running lights??
  24. Looking for feedback on anyone running 17s on a 3rd gen
  25. Pics of my truck :)
  26. 3.4L Radiator Flush
  27. Fuel injector needed! Where from?
  28. TJM turn signal lens screw
  29. What should I pay for this Tacoma?
  30. Stock Steering Stabilizer Recommendations
  31. P0127 CEL issues, resolved!
  32. Outback Mod (?) Clear Corners, 02 heads (pics!)
  33. Poeple Need To Learn how To Drive
  34. Tuff Toyota Truck Tales
  35. 2004/tire Presure Light
  36. TJM or ARB Help me decide
  37. Do I really need the deckplate?
  38. I think I have really done it this time.
  39. Electrical
  40. reasons why photochopping helps us all
  41. Hail TJM
  42. cornfed vs old man emu
  43. Transmission Drain Plug
  44. Stock tailpipe size for V6
  45. Auto Trans Noise/Slipping/Hard Shifting - Dealer says wrong ATF used
  46. TRD stuff, junk, and Accessories
  47. Another 3rd gen on 35x12.50s
  48. California Smog - Need some quick answers!!
  49. time for a lift soon..help the newbie
  50. Stock ' 85 - Is it a waste?
  51. 22r head trq specs?
  52. heated seats
  53. Anyone have experiece with NWOR heavy duty rear springs?
  54. Its Falling off!!!
  55. Sqeeky Stearing wheel
  56. different catalytic converter
  57. coil dilemma
  58. front end aligning plate?
  59. My "new" 2004 Tacoma
  60. --------Power Steering Leak---------
  61. Supercharger install question
  62. Automatic Transmission Slipping
  63. Do the automatic steps work?
  64. arizona vs California
  65. Custom supercharger on ebay ??
  66. Anyone pull an oil pan gasket out on an 89 4wd V6 pickup
  67. Spring over axle?
  68. Dash Brake Light on 2nd Gen. 4Runner
  69. wood floor vs. metal floor...
  70. Tacoma tailgate check
  71. 3.0 Swap Over
  72. Seat cover for my dogs (3rd Gen '01)
  73. Pic of my "new" '88
  74. Got my Yota stolen
  75. pic of uca for a 4x2
  76. Lift types?
  77. a couple new mods...
  78. Gas smell in the crankcase
  79. What Plug??
  80. Aisin who can tell me what these parts are
  81. Swap bucket seats for stock bench...
  82. Dramatic Mods...
  83. How many miles?
  84. bad news
  85. for Downey header, should I get the Nickel-Chrome Plated or Ceramic Coated ?
  86. Pedal Extensions?
  87. 3vze
  88. Can you wire in the SS FTC before installing injectors?
  89. Disconnecting the fuel line
  90. Diagnostic Code Question
  91. Backspacing and offset????
  92. My cab WILL be SILENT!!!!
  93. ASA TRS Wheels
  94. Which wheels would look better?
  95. a few pics of my 4runner
  96. How pissed would you be if your Taco looked this bad!
  97. Figured out dome light
  98. 1st gen A/C install, EZ or hard?
  99. tell me what you guys think... doing a head swap
  100. PLEASE HELP. 85 4runner throwing oil EVERYWHERE!/ IM DESPERATE. PLEASE HELP
  101. REPAIR HELP - 97 4Runner Limited
  102. oil smells like gas in 87 22r, possible causes.
  103. Tps
  104. Replacement shocks
  105. Is synthetic better in the cold months
  106. I Have Back Up Lights Now!!!!!
  107. Recall site
  108. Another One Bites the Dust??
  109. Starter issues
  110. AFM diameter
  111. what could this be?
  112. 2nd gen head gasgets
  113. Headers
  114. is it worth the money and time to install Electric fan on 4Runner ?
  115. removing top on 1st gen...
  116. Kevin Scored 3.4L Headers!
  117. need a knock sensor
  118. do I have a lift??
  119. My new 4Runner :)
  120. Changing power steering belt
  121. brake bleeding experts---HELP pictures
  122. removing trapped air from the cooling system
  123. Torque spec for 3rd gen wheels
  124. Temporary fuel pressure metering?
  125. Tapping into headlights help
  126. Clutch replacement: 1984 2wd pickup
  127. How 'bout these tires?
  128. What a week---PICS!
  129. digital clocks
  130. fuel pump?
  131. Proper way to check trans fluid?
  132. Flowmaster and the 22re
  133. clunk noise
  134. The Follow up
  135. User Tires shops in Bellingham, WA
  136. How do you reach the front driveshaft bolts closest to the transfer case??
  137. door weatherstrip
  138. 4runner antenna replacement?
  139. What brand/grade oil do you use?
  140. 02 sensor?
  141. Anybody watching Pimp My Ride(right now)
  142. making new out of old drive shaft
  143. Camshaft?
  144. 95 Tacoma trailer lights
  145. I was thinking of putting 04 tundra rims on my 97 runner. It should work right?
  146. Near head on collision. Need parts.
  147. Help ! My 4runner takes to long to warm up .
  148. Repair manual for 99 4runner...3 hours left
  149. 22re...what's the deal
  150. Slotted rotors...which way do they go?
  151. how to install new corner lights?
  152. 3.4 v6
  153. free clutch play
  154. how safe is 4Runner during high speed crash on the highway ?
  155. headlight ?
  156. Door with Yakima Racks LEAKS
  157. Can you install an anti-lock brake system?
  158. Spring Shackle Question
  159. Installed my latest mods!
  160. Another 4WP complaint list
  161. ARB Winch Bull Bar for 2000 4runner
  162. is there a difference between a 91 and 94
  163. Instrument panel kits
  164. Head Gasket Paranoia '88 4Runner
  165. Grinding and Clankiting....
  166. looking for bed
  167. 200k
  168. Hella Rallye 4000 Compact!
  169. Another Help Thread - Parking brake light on 85 runner
  170. Need Help with Rack & Pinion *Newbie*
  171. Project Dechrome/Body Mods - Warning: No Off Road Value!
  172. In cab tire deflation / inflation..
  173. 1st gen fuse diagram?
  174. Building my own exhaust system
  175. For all Canadians and other cold/snow dwellers....
  176. my 95 4runner is slower than the rest
  177. Speedo works when cold outside but not warm: Gauges or VSS?
  178. Stock Taco + 265/75s?
  179. how does this sound?
  180. Toyota Concepts
  181. need advice please
  182. Cheap susp lift, 84 pickup
  183. Proper way to clean the K&N filter?
  184. 22RE Spark Plugs?
  185. Daystar winch bumper for 3rd gen??
  186. Auto hubs heading south?
  187. 3 Pics .... Two Questions
  188. removing stock fan
  189. new light bar all hooked up
  190. 3VZE Knock Sensor
  191. 3vze EGR temp sensor question
  192. Should i use this air scoop?
  193. winch mount
  194. What are the best products to use?
  195. lsd swap from a supra into a 2wd yota
  196. which spark plug gives the longest life ? Platinum or Iridium ?
  197. 2nd gen owners w/ factory alarm. Questions
  198. Roof tar on paint
  199. Stinking damn EFI fuse
  200. Newbie now has a 4runner
  201. Another Yota is history
  202. Pic of my Truck
  203. do your tacoma's "pop" out of 4wd???
  204. ADD Hubs to manual hubs
  205. 83 PU carb wiring question
  206. Darn fangled antenna!
  207. Suspension Q.
  208. 97's rear end is to low update
  209. Euro style parking-lamps for '84-'88 Hiluxes. Where to get them?
  210. Mtr's or Revo's?
  211. What is your average MPG on the 3.4L ?
  212. Cool site to compare current yr Toyota's to others
  213. looking to buying my first 4x4 Toyota
  214. 3VZE Can't Keep Rear Seals In Engine
  215. air sensors in tires
  216. 1985 Frame 4x2 IFS
  217. Lifted 2nd Gen model on Ebay
  218. biggest tires with IFS?
  219. Loud Grinding ABS??
  220. whose badass rig?
  221. Tires,Tires,Tires....
  222. No Vroom Vroom!!
  223. who has a stock vinyl? (1st gens and pickups)
  224. Running board install
  225. Wrecked my 4Runner, what to do now?
  226. Good deal on TJM?
  227. Surging idle 22re
  228. Just back from the North American International Auto Show
  229. will a Scion badge fit?
  230. can anybody post a pic of a 3.0 crankshaft...please!
  231. Those of you running clear corners and bumper lenses
  232. 2nd gen with auto hubs
  233. Instrument cluster light problem???
  234. depress the clutch to shift to 4wd?
  235. Center brake light - Pickup
  236. Tail light condensation
  237. weird idle
  238. I've Converted
  239. factory fog trouble.
  240. After a balance, what would be considered alot of added weight on a wheel?
  241. battery and Ebrake light
  242. S.o.s.
  243. collision/insurance question?
  244. Valve job ?
  245. Average factory battery life?
  246. Bored
  247. Knowledge roster: Best way to touch up paint?
  248. valve cover gasket
  249. Toyota Truck & Motorcycles
  250. URD Fuel Kit Upgrade Installation
