PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Problems with starting... stuttering
  2. MAF Removal
  3. So THAT'S why my tailgate window wouldn't go down...
  4. Yota Techers I need your help
  5. Dull clear corner light!!! HELP!
  6. HID conversion on my 97 4runner
  7. R150 3rd gear grinding?
  8. grit and deposits in the block under the oil cap??
  9. temp gauge install
  10. Mixing ATF Fluid with Toyota
  11. tjm t17 on a 3rd generation 4runner without fender flares
  12. What does 200K look like *pics*
  13. Fuel Gauge Problem
  14. Replacing O2 sensor on MT 3rd Gen
  15. Lots of positive camber?
  16. Clutch problem
  17. Rim Size Question
  18. Installed 4crawler 1" Body Lift w/ Pics
  19. Satoshi Grill
  20. 5 Spoke Rims
  21. MAF Cleaned / Before and After Pics / 2000 4Runner
  22. supercharger and trd 7th injector questions
  23. 92 fj80 coils on 00 4runner
  24. Which torque value is correct for caliper bolts
  25. Oiling a K&N air filter?
  26. 02 4Runner Speedometer Lag
  27. BFGs for sale used a good deal/fit for me?
  28. New Exhaust PICS
  29. can i put 265/75/r16's on my factory 2002 taco??
  30. Any of you use Valvoline Maxlife in your tranny?
  31. video of parking light blinker mod
  32. stupid 3.4 power steering pump question
  33. 2002 4runner sagging in rear
  34. I've Searched...Leather Question..
  35. good place to find fender flares
  36. Replacing air fuel sensor?
  37. URD Crank Shaft Pulley Installed
  38. Dreaded axle leak - updated with pictures
  39. improve gas mileage ?
  40. WARNING beware when buying new EAGLE ALLOYS ESP. the 185's!!!
  41. lift options for a 98 runner
  42. Painting your 5-spokes--My Write-Up--Pics
  43. My plan of attack
  44. 4Runner spring rate?
  45. Rear brake adjustment question
  46. Fuel Filter on 2.7
  47. clutch job
  48. 1999-2002 4runner SR5 Fog Light Installation Instructions
  49. Is this the dreaded axle seal leak?
  50. Big loss of power after towing a trailer 1000 miles??
  51. No power, running rich (3.4L)
  52. Tundra DC TRD Coil, will it work on 4Runner?
  53. 2000 SR5 Budget Mod
  54. Better seats in 01 Tacoma?
  55. Pin Clearance w/ Flip Hitch Mod
  56. I need a set of Tundra coils, anyone?
  57. New headunit aerial problems
  58. 40 series delta flow... go or no?
  59. OME Front Trim Packer...Where does it go?
  60. CV Shaft, re-grease or replace?
  61. Advice on rear drums
  62. Should I buy this runner?
  63. The four wheeler's dictionary
  64. 99 or 00 4runner help
  65. Just finished herculined bumper-pics
  66. Mystery Noise in the front end. I'VE SEARCHED. Can't find anything!!!
  67. Urgent opinions needed! Buzzing/Humming?
  68. How many miles on your clutch?
  69. Cause of Roll/sway at highway speeds?
  70. Brembo part number for 2001 4WD
  71. What should I do.. :(
  72. sway bar bushing replacement?
  73. Going e-locker?
  74. Minimum thickness for front rotors
  75. OME 906? Does the bumpstop cone matter?
  76. Wow...
  77. Winch or Locker?
  78. fcc id# on remote
  79. Intermittant engine stopping - 96 Tac. 4X4/2.7
  80. Help me identify these 3.4 TRD Headers!
  81. Brakes acting Strange
  82. Final wire issues with FMU
  83. TJM 15 with Warn XD9000I Will it fit?
  84. 3" Suspension Lift
  85. Tokico Trekmasters?
  86. Performance Products 1" lift kit
  87. 2.5 gallon viair tank
  88. where to get 1" pp springs?!?!
  89. 73k on my '01 - work to be done?
  90. Pro Comp Xtreme MT came today!
  91. Tonneau cover mod - rd gen 4runner
  92. Flowmaster Sound clips?
  93. knock tapping front of 3.4 solved finally!
  94. YotaTech saved me $$$$$$$
  95. all of a sudden started missing, HELP!
  96. Tacoma 5-Speed Conversion
  97. 97 vs. 98 timing belt difference?
  98. Taco Tire Sizes
  99. Seattle Transmission Purchase Suggestions
  100. 4runner Crashed D:
  101. Check out my new wheels!
  102. Power window switch conversion
  103. N86 Shocks installed
  104. Suggestions on getting rid of rust spots?
  105. lost all power
  106. 3rd Gen Project
  107. HELP! truck sputters under acceleration, and check engine light
  108. 2000 4runner tailgate window gremlin
  109. Tundra coils for 4Runner, lowest price???
  110. 2000 4Runner Stalling while Accelerating.
  111. How much lift did you get from OME 881's?
  112. Clunk in rear when braking
  113. ABS problems
  114. Field Monitor Unit - 98 4Runner
  115. Rear window rattle when half-down
  116. CD Player giving error message...any ideas?
  117. Ahhh, A/C finally....
  118. #1 SUSPECT: Plug gaps as wide as, well, use your imagination!
  119. Did bad Gas cause this Check Engine Light?
  120. Trailer light T-connector converter
  121. Installed a 3rd row seat
  122. Need mechanic in Richmond, VA
  123. Trans-Cooler lines burst, so how much for New Tranny?
  124. outer tie rod joint grease, name and where to get it
  125. Outside temp guage?
  126. Rainbow speakers
  127. 2.4l Desiel Performance/Reliability
  128. 3 inch suspension 3 inch body lift pics anyone?
  129. Transmission behaved odly this morning.. worse to come ??
  130. PICS: 1999 Black 4runner
  131. New OME lift... Diff Drop problems..
  132. Help!!! Alarm is stopping me from starting the truck
  133. tail gate problems, latch
  134. Starting delay
  135. Another P0171 Code Question.
  136. Tire/Lift Question
  137. top spacers...10mm?
  138. ISR Mod... a week later, 4Runner woke up.
  139. SR5 Dash for my 2003 SWB 2.4L
  140. fat lip bumper - reinforcement frame
  141. Rear window only moves an inch
  142. lift decisions
  143. Should I sell or keep my trailer hitch off of my 2002?
  144. What's my junk worth?
  145. 99 4Runne4 turn style to a digital thermostat
  146. body lift and tire fitment question
  147. Rim/wheel question
  148. Upholstery
  149. Single cab Upgrade
  150. Bored with a dirt pile / PICS
  151. Broken Antenna - Can I Just Unplug it? (post-search thread)
  152. VCS off, VSC Trac, Check Engine and now 4WD light on???
  153. The 5runner: badges and lights
  154. My doublecab tundra coil swap with pics
  155. Need Specifics on Power Window Switches
  156. New intake and Exhaust *pics*
  157. Baby seat in Tacomas
  158. Is the crank bolt...
  159. COS.Fabrication help?
  160. Driving with 5 lug nuts
  161. shop in dfw area for spring install
  162. 4runner died after flooring it, what can it be?
  163. Saggin PP springs
  164. 265/75 R16 to 245/75 R16
  165. OME 880/906 combo, I'm confused, HELP!
  166. HELP P0172 code won't go away bad ECU???
  167. What OBD 2 do you use and why,
  168. Fixing code P0300?
  169. Need a price estimate from the pros!
  170. Which of these 3 tires?
  171. Please Help, need advice
  172. Anyone ever install a brake proportioning valve?
  173. trailer towing
  174. 97 4WD Transmission won't shift in 2WD
  175. Input
  176. rims clear brake caliper?
  177. Just ordered some stuff
  178. Help with supercharger oil
  179. $12,000 To Spend, What Year??
  180. Door locks
  181. 97 Needs Remote Door Locks/Security
  182. Just got some Fj80 OE wheels... What should I do???
  183. Grinding Wheel Noise
  184. best rotors and pads?
  185. NEW sliders and roofrack, what ya think?
  186. Wheel/Tires...irritating conundrum...
  187. Thorley headers GROUP BUY on CT
  188. Just tried to adjust the valves on 5vz-FE
  189. Tundra / Sequioa brake parts for upgrade
  190. New front suspension problem
  191. Brake booster filling with fluid, what gives?
  192. Transmission Cooler Install Question
  193. ADDCO Anti-swaybar bushing SOLUTION
  194. tellico was fun time to fix some stuff
  195. I'm happy with MPG
  196. Driver Side lower A/C vent dripping cold water...
  197. Battery Rewiring Questions
  198. Trailer lights fried my fuel gauge???
  199. Manifold Torque # 2.7L?
  200. Electrical problem
  201. Thank you YotaTech Community
  202. Going to take a Gander at a 95 Taco.
  203. Should I get this S/C or not...
  204. A Plastic Worm Is Coming Out of My Seat!
  205. Hers and Mine (Pics!)
  206. Gas sender unit gone bad?
  207. Leather seat up keep questions?
  208. LCs installed
  209. Brake Bleeding
  210. Wanted - Stock intake for 96-97 5VZFE
  211. Any spare front-seat parts people want to get rid of?
  212. Keeping Dust Out Of Bed With Topper
  213. Forward Swing Scout Steering Box For SAS?
  214. Anyone tow a race car?
  215. Wrong way to install strut assembly?
  216. Gt Radial Adventuro M/T 295/75/16
  217. To e-lock or not to e-lock, that is a heck of a question!
  218. vibration and clunking!
  219. preparting for a new life in the desert
  220. OEM Shackles? Loaners?
  221. Anyone know how many grease fittings there are
  222. toyteclifts and tire sizes
  223. SES light!! 1998 4runner limited 3.4
  224. 3rd and 4th gen parts interchangable???
  225. Time for New Bumper
  226. Pics of my 98 4runner
  227. Highlander Help - strut tower brace
  228. 99 4runner auto trans
  229. Pic Request: 3" Suspension + 1" Body Lift?
  230. Drive shaft questions (broken cardan joint?)
  231. New to 3rd gen...lift options
  232. Close to buying a 98 4Runner, help with price and carfax please!!
  233. 2001 T4R Brake Job
  234. Ingen Intakes - 5VZFE
  235. Changed back to stock wheels, white letters out
  236. door handle parts help
  237. just installed Tundra brakes - questions:
  238. Recently Lifted
  239. Auto Trans diagnostic help request.
  240. Aluminum Dash Trim Kit
  241. 99 coils!!!
  242. overnightautoparts.com sucks!!....rant
  243. Seat Swapping
  244. goodyear mt/r on 3rd gen?
  245. Cooled Seat Covers
  246. How Much Does a 5vz-fe Weigh??
  247. 97 runner seat covers
  248. Modifying wrangler flares for my runner?
  249. Installed lift-reversed rake! (L@@K PIC)
  250. Changing Spark Plugs on 1998 V6 Tacoma
