Which torque value is correct for caliper bolts
Old Jun 29, 2007 | 05:36 PM
GhostriderTx's Avatar
I havea 2001 4WD 4 Runner. I have seen two different numbers posted. Most posts show 90 ft pounds for the caliper bolts but I thought I saw that the 4WD was only 65. Anyone have a correct answer if the 4wd is different than 2wd
Old Jun 30, 2007 | 12:37 PM
Yoda's Avatar
My Mitchells program says 90 ft lbs
Old Jul 1, 2007 | 07:03 AM
toy_tek's Avatar
This is from the 97-98 FSM
TORQUE SPECIFICATIONS (4RUNNER)
Application Ft. Lbs. (N.m)
Brake Hose-To-Caliper ...................................... 11 (15)
Caliper Mounting Bolts/Slide Pins ......................... 91 (123)
LSPV Mounting Bolts ........................................... (1)
Master Cylinder Outlet Fittings ............................ 11 (15)
Rear Axle Retainer & Backing Plate Nuts .................... 48 (66)
Wheel Lug Nuts ............................................ 81 (110)
INCH Lbs. (N.m)
Brake Bleeder Screw ........................................ 97 (11)
LSPV Adjusting Screws/Nuts ................................ 115 (13)
Master Cylinder Piston Stopper Bolt ........................ 89 (10)
Master Cylinder-To-Booster Nuts ........................... 115 (13)
andrewtexas123
Jul 6, 2016 01:49 AM
garagespace
Oct 11, 2015 10:59 AM
rustym
Aug 7, 2015 10:39 AM
129Creepin
Aug 5, 2015 10:12 PM
Snort
Jul 9, 2015 03:58 PM
