OME Front Trim Packer...Where does it go?
Old Jun 25, 2007 | 07:42 PM
k_southman's Avatar
So I have OME 880's in the front and would like a bit more lift in the front before I put on my 285's. So I purchased these online. I guess I should have read a little closer cause I thought I was gettine a Bamachem style spacer that would go ontop of the strut under the upper A-Arm. So my question is Where do these things go on my strut? OME PART # 95PF5
Thanks
Old Jun 25, 2007 | 07:57 PM
eric-the-red's Avatar
They go under the lower spring perch, you have to disassemble the strut to get them in.
Old Jun 25, 2007 | 08:09 PM
brazos609's Avatar
I thought the trim packers went on top of the spring, between the spring and the top plate?
Old Jun 25, 2007 | 08:25 PM
One_96TR4's Avatar
I believe that's the OME 10mm Lift Enhancer Kit.
Old Jun 26, 2007 | 05:00 AM
aviator31's Avatar
The trim packers definitely go inside the coil assembly. Top plate spacers go on TOP of the coil assembly. Do you have a Body Lift on there? Just curious how 285s are going to fit with only the 880s on there?
Old Jun 26, 2007 | 05:53 AM
k_southman's Avatar
I already have a set of 285's on 17x8 rims (4.75" backspacing.) I put them on last week and they seem to fit fine. I think I will have to trim the front bumper lip, but that seemed like the only place where there may be interference. So the trim pack I thought might give me an extra 3/8"-1/2" to help level me off as I have a 3/4" rake (front lower) on my truck now with 890's in the rear.
I kinda figured that they must go under the lower spring perch. I am going to try and put them on tonight.
I was thinking that I might try and take to strut apart by leaving the top plate bolted on, supporting the truck in the air on jackstands, floor jack under the bottom A Arm to hold the weight, then unbolt the middle strut bolt and SLOWLY lower the Jack releasing the trucks weight off the strut causing he strut to release tention. I have used this method to get struts off cars without having to use a coil compressor, but never on the front of a truck. Any one ever used this method? I have coil compressors, just thought this might be easier then unbolting the whole unit just to slide on these rings.
Old Jun 26, 2007 | 06:39 AM
The theory sounds OK, I don't know if the lower arm will go down far enough though. Let us know if it works.
Old Jun 26, 2007 | 06:47 AM
toy_tek's Avatar
This sounds like much more work and potential for injury than just removing the strut. You can get the entire unit out in 5 minutes, 3 nuts on the top, one bolt on the bottom.
With the method you're talking about, I think you'd still have too much spring preload on the bottom mount bolt, even at full droop. When you knock the bolt out I think all hell would break loose... then good luck getting it back together like that. Even with the entire strut assembly together, I had to have my buddy push down on the LCA to line up the lower strut mount bolt.
lledwod
Aug 30, 2016 01:03 PM
garagespace
Oct 11, 2015 10:59 AM
Road Bull
Oct 10, 2015 04:55 PM
skebe22RTE
Jul 31, 2015 02:03 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
