HELP P0172 code won't go away bad ECU???
Old Jun 13, 2007 | 02:33 PM
mbeck's Avatar
Hi Guys, I have read all the threads regarding CEL P0172, and to date I have replaced both O2 Sensors, have had the enjectors cleaned, and 600.00 later, no change in performance. I have hestation on accelleration.
The weird thing about my situation, is that when the mechanic puts the tester on my truck, no values change immediatly. That is, when he steps on the gas pedal, all the readings stay the same for a period of time, which coinsides with the hesitation of the engine.
The TPS position sensor, RPM, MAF all of them stay put. Any ideas? Could the ECM be bad?? Trying not to take it to the stealership.
It stalled 3 times on the way home from work after replacing the 2nd O2 sensor
Any help is appreciated.
Old Jun 13, 2007 | 06:42 PM
profuse007's Avatar
clean the MAF and see if it helps. then reset the ECU.
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
raptor510
Feb 17, 2017 07:11 AM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
