PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. Low fuel light?
  2. OME, ARB+winch, BUD, Mod pics.
  3. Swap Idea
  4. Problem. 4WD in reverse
  5. Technical size of 3rd gen fogs
  6. sparks plugs help
  7. Gear Question
  8. Hi I'm new!
  9. Icon or Fabtech
  10. rough grinding, trying to pinpoint
  11. small coolant leak by the top radiator hose going to the engine
  12. 2000 4Runner 5speed 4x4 5vz-fe
  13. 3rd gen 4runner suspension questions
  14. Cooling Fluid LL vs SLL
  15. Lost Keyless remote
  16. Sunroof jammed
  17. 2000 toyota 4runner drivers side floor soaked when it rains
  18. IFS (clamshell) regear question)
  19. Part number?
  20. 24" Magnaflow is on!
  21. 03 Tacoma will go into 4 low but not 4 high
  22. Aussie Locker INstall IFS Help
  23. Auto or manual transmission?
  24. 5 speed swap
  25. '02 LTD issues
  26. engine spins effortlessy
  27. Tacoma Overheating! And its Super Charged!
  28. Custom rear bumper's Tacoma
  29. SolidWorks bumper design begins...
  30. Bad Solenoid?
  31. Side step for rock sliders
  32. Looking for Re-manufacture recos
  33. Rear Deflector Install -- Any Tricks??
  34. How to install a block heater (with pics)
  35. Rear window...is this possible?
  36. Guide on How to Combine Both Front & Rear Antennas into One on an Aftermarket Stereo
  37. have a 2.7 toyota 4cylinder motor, 90k, dont know how much its worth
  38. Code C1207 and C1234 Help VSC TRAC related
  39. 1998 4runner PVC Valve Replacement
  40. 99 Runner Limited - howling in the rear
  41. Bumper Mounted Foglight Question
  42. 285's on stock wheels....again
  43. Another Lift question
  44. 5VZ Remooval
  45. Antenna Mast
  46. 1998 4Runner manual tranny - Lives for how long?
  47. Power Steering Pump: Leak
  48. Gauging Interest on pocket style Bushwackers
  49. Field Monitor & New Pioneer HU working Against each other?
  50. Yet another "squeak" thread....
  51. 97 intermittent 4wd problem
  52. So Many Broken Bolts, Need a Little Help
  53. flashing 4wd indicator -NOT trying to use 4wd!!
  54. What springs w/ Bilsteins for my '99 Runner?
  55. Tacoma Tranny Fluid Flush
  56. transmission shuttering at cruise speed
  57. Clunking is back
  58. Transmission fluid flush Prerunner 99
  59. Timing belt marks?????
  60. Bent tow hook mounting
  61. 03 manual tranny
  62. Poser shots and new wheels
  63. K&N off ebay.. No air box insert??
  64. OME LIFT- Comfort or Normal shocks?
  65. Mystery Misfire
  66. My next mod... Headers...
  67. Mystery Misfire
  68. Rear Diff Breather
  69. '96-'98 Front Bumper Install on a '99+ ??
  70. Crashed! $4K of damage on a 96 with 130+ miles
  71. 4pin to 7pin taco
  72. CBI Rear Bumper group buy???????
  73. need FSM pdf Trans pages
  74. A/C gets loud when on full blast -- common?
  75. mpg chaser
  76. Thicker exhaust gaskets?
  77. OME Lift but problem with bowing tires
  78. Body Cutting Worries
  79. Upgrading to Tundra rotors/brakes still optimal?
  80. 99 OEM Power Outlets retrofit into 97??
  81. my excuse for modding my 4runner
  82. what is the charcoal canister?
  83. tundra brakes
  84. another "wont start" thread
  85. 3rd gen tube bumper almost done...
  86. a340e torque converter install.
  87. Another LOCKER help thread
  88. Leaky front diff...can I get by?
  89. Engine Misfire.. Please Help
  90. Pioneer 4100 HU Installed with Cameras
  91. Hydraulic Clutch Problems
  92. Check engine light MAF
  93. 35' Tires speedo recalibration?
  94. whinning sound
  95. Width of 4Runner roof
  96. Warping Rotors
  97. Anybody use POR15 for rock chips?
  98. ARB bumper installed
  99. Hot, Burning Rubber Smell....2000 4Runner
  100. Yaw Sensor Location Help
  101. kickdown cable?
  102. clock wiring??
  103. Lift Is Installed
  104. Completely new exhaust syetem (pic heavy)
  105. Fuel filter change, now it won't start
  106. Redline Gear oil
  107. 4:88's and 33's a good conbo?
  108. Kragen HID Offroad Lights Installed
  109. Rear Axle
  110. New England weather = RUST
  111. 02' Ball Joint Recall
  112. IFS/manual hub ideas
  113. 4runner under headlight air inlet panel
  114. Rear lower control arm bushings?
  115. if you had 8,500 what year truck would you buy?
  116. Stange noise from driver's side
  117. Another 3rd Gen Bumper Option
  118. Rusted Differential Options
  119. Check Engine Light
  120. pulling engine on a 1998 tacoma 4x4 2.7
  121. changing belts in a 02..
  122. 4Runner rear deflector
  123. Lifting my 4Runner questions
  124. Transfer Case Leak 2002 Taco
  125. keyless remote programming problem
  126. replace head or new engine
  127. 3rd gen 4Runner transmission questions?
  128. Anyone still use Tundra Coil/OME 890 Setup?
  129. Wheel weights
  130. heater controls
  131. Fried Converter Box- Trailer light hookup
  132. 2000 4runner heat issue
  133. C.B.I. Gen 3 4Runner REAR BUMPER Build
  134. have a question about my 02
  135. No power in dash, windows, etc.
  136. Diagnose?
  137. Driver side fenderwell
  138. which plugs for supercharged 3.4L 5VZFE?
  139. How do I install a block heater?
  140. wow this 02 is rusty underneath (pic heavy)
  141. A340E pretty much shot. Need some advice.
  142. The best clutch for 3rd gen 4runner 3.4?
  143. My engine fan is running all the time. Normal?
  144. Oil Filter Help
  145. hub nut removal cv axel
  146. Heater and A/C problem
  147. custom rock sliders finished!
  148. 2002 4Runner Suspension/Bumper options
  149. Help, my engine has a hard time starting!
  150. warn m8000 or mile marker pec8
  151. My "Newest" HID Project...
  152. Bilstein 5125 shocks w/ 99 coils??? Doable?
  153. 3Rd gen 4Runner transfer case
  154. Got my arms back on! :)
  155. Brake issue
  156. Remanufactured Clutches
  157. Ignition Coil Comparison
  158. Poly Steering Rack Bushings?
  159. time to take care of corroded rear heater line
  160. TOTALED! - Part Out Question?
  161. Driveline Vibration and Noise at Highway Speeds
  162. u-joints 99 2wd runner
  163. Knock Knock Knock Rattle It Goes
  164. Rough Idle when Cold/Ok when warm
  165. Adjustment of the tps
  166. 97 4runners or 3rd gens with HIDs.
  167. a/t to m/t swap 96 tacoma
  168. Introducing my 3GT4SCLT
  169. A340E Transmission replacement
  170. Help With code P1135
  171. 3rd brake light
  172. Jaos Rear Roof Spoiler (LED Replacement)
  173. FRNT wheel studs 2001 4runner
  174. Custom Bumper Fit Help
  175. 4Runner...the modding saga....(PICS)
  176. trimming fender well help.
  177. 97 4Runner 3.4L Aisin water pump question...(gasket)
  178. Axle Oil Seals Keep Leaking
  179. Seriously Toyota? My differential housing rusted out?
  180. 5-spd/35" tires - gears feedbacks please
  181. More supension Q's
  182. Next step in my build...gears?
  183. 96 4runner brake engaging on own
  184. Which OBD II Reader/Scanner to buy
  185. Tall 1999 4Runner Rear Spring P/N
  186. CV Replacement
  187. Baja Rack is on...
  188. Which winch on your 3rd Gen
  189. toyota service records
  190. Ball Joint Replacement
  191. 3" lift on 32" or 33" tires
  192. Cheapest place to buy an arb bumper?
  193. Brush Guard
  194. Whining after putting timing belt on.
  195. Power Stearing leaks when engine if off?
  196. Front wheel lean
  197. Manual clutch pedal play....
  198. 2003 4x4 Tacoma double cab
  199. Help! No ac, power windows or gauges!
  200. help, my lc coils dont fit at all
  201. Major Help! 99 4runner. Rod through the block
  202. 255/85R16 fitting under without hitch?
  203. 97 5spd shifter problem
  204. Please help code po171
  205. Power Steering Gear Box
  206. Replace Headgasket or New engine?
  207. Transfer case breather
  208. Where do you have your interior light mounted
  209. Towing with a hitch rack, motorcycle and travel trailer over 11K pass possible
  210. Does it sound like I need a valve job?
  211. Low idle problem
  212. Metallic Rattle - Heat shield/Leaf Springs/Driveshaft??
  213. hilux suspension
  214. 2wd 4wd drive shaft
  215. Driveshaft lubing help needed
  216. removing side mirrors on 02 SR5 4Runner (stuck!)
  217. quick help on 97 4runner
  218. Magnaflow 14" or 18"
  219. Headers (or options?) for a '97 3.4 T4R
  220. All good, but bogging off start
  221. Found a Cheap E-Locker...need help with repair estimate
  222. Idle Control System CEL code and IAC?
  223. 2002 SR5 fender flare pad issue (blacked out flares)
  224. E3 Spark Plugs - Hype or Hot Stuff?
  225. Confirming clearance
  226. 1999 4runner sr5 2x2 factory manual
  227. Brakes - What to replace with?
  228. Rough Idle, Check Engione Light
  229. Where to buy 4.10 Ring and Pinion Set?
  230. Auto VS Manual transmission throttle body on 3.4
  231. Ltd Rocker Panel retrofit onto a SR5?
  232. Taillight's
  233. Back with Newer Yota
  234. 02 4Runner Millenium Edition Throughing Codes. Your help appreciated!
  235. 99 A/C condenser replacement
  236. Is NGK spark plug wire set 4412 direct fit ?
  237. water pump question
  238. Airbag Light On!
  239. Running light's problem
  240. 1999 sr5 4runner log lights
  241. Quick Shock Question.
  242. The "new" ride!
  243. How loud is your Super Charger?
  244. Air Intake (cheap on Ebay)
  245. Do we need to replace "ALL of coolant hoses" ?
  246. 05+ bench swap?
  247. 98 4Runner Vibrating
  248. aussie locked prerunner?
  249. Start up smoke
  250. CV Boot Failure
