PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. A/C Compressor and hissing sound
  2. 1999 4runner engine noise
  3. Starter good, battery good, still wont start...
  4. Valve cover gaskets
  5. What size torx bit do I need
  6. TPS? Maybe?
  7. Brake Fluid Leaking from Wheel
  8. How much can a 4cyl Tacoma tow?
  9. will my 4runner trailer hitch fit on prerunner
  10. Strengthen you factory roof rack, add another elevated crossbar!
  11. 1996 tacoma lift
  12. Engine change from 4Cyl. 6 Cyl.
  13. shaky only when weather is warm..then P300 and P306
  14. More f-150 spring stuff
  15. Coil Overs ( yes I searched)
  16. 1999 4runner DRLs / Reverse Lights / illumination for HVAC controls
  17. 99 4runner won't start
  18. 13 1/2 years old, snowbank smasher since day 1...hitch rotted
  19. 98 4rnr ltd clunk when turning
  20. a good old suspension question!
  21. Antenna Question
  22. Bad Transfercase???? (videos)
  23. 231 mm Brake Upgrade PROBLEM on 01 Taco
  24. Possible replacement 4Runner!
  25. Cat Converter - CA v. Fed question
  26. 4runner rear control arm bushings
  27. Just bought '97 4Runner with 200,000+ miles and need advice on upgrades
  28. 12 years & 121K later......2000 Sport, pic heavy.
  29. Error Code: Insufficient Coolant Temperature...
  30. Mysterious cut lines
  31. Is a cool air intake worth it? 00 Toyota Tacoma
  32. VSV for EVAP (purge) - interchangeable?
  33. Motor Exchange or Head Gasket
  34. 1997 4runner 3.4 auto flex plate nightmares
  35. Need help with ABS system!!!!!
  36. Anyone mod a Hella DE to OEM/Factory Fog Bracket?
  37. Coolant Reservoir/Overflow Tank
  38. Chasing an EVAP code
  39. Finally In New Zealand
  40. First year of (EDR) in 4runner?
  41. To roll bar or not to roll bar? That is the question.
  42. Synthetic oils in power train, DYNO
  43. Valve cover cracked but should I worry?
  44. Is my suspension shot?
  45. Anyone done a 5 speed swap?
  46. New 4Runner, torque converter issues?
  47. INFO: Drive patterns to reset OBD-II readiness monitors before state emissions test
  48. where can I get a Longer Brake cable?
  49. 99 4Runner ABS issues?
  50. stock tcase swap ?'s
  51. Tundra rears on a tacoma??
  52. '97 4runner auto tranny not wanting to go in reverse?
  53. 3rd Gen 4runner Overheating After Rebuild
  54. ARB Locker, 4.88s & Compressor - DONE!
  55. No tail lights, dash lights, or cruise control
  56. 96 Taco 3.4 auto random engine skip or buck.
  57. Front ABS Ring Spinning Freely
  58. extending my drive line in my 96 taco
  59. Time to replace some suspension parts - suggestions please
  60. 3.4 Supercharged and headgaskets question
  61. CA SMOG HELP... Im lost '01 3.4l
  62. Random vibration Issue?
  63. 00 Tacoma TRD kickdown cable
  64. Finding Wrecking Yrds in New Zealand
  65. how to reduce muffler noise?
  66. Differential question
  67. OME N86C vs Stock Shock Length
  68. Looking for some engine swap info. 1999 3.4 into a 2001 4runner
  69. Replacing CV axles and wondering about re-greasing wheel bearings
  70. 3rd brake light staying on
  71. 2000 Tacoma clutch issues.
  72. Will 2010 Taco rear shocks fit an 02 ?
  73. 285/60/r18 severe tire rub!
  74. Another Wheel Fit Thread
  75. 3rd gen 4runner- Clicking from transmission oil pan
  76. 97 4Runner front strut replacement troubles
  77. 3RZ swap question
  78. 3rd Gen 4Runner, diff / tranny / plugs lack of replacement
  79. 96 4runner run ruff under load
  80. high idle after tb cleaning
  81. Radiator R/R
  82. Electronic locking rear diff not engaging
  83. 1998 Toyota Tacoma Stuttering Problem
  84. Check Engine Light
  85. Bridgestone Fuzion Touring on a 99 4runner 4WD?
  86. Can a 99 4Runner Limited run without instument clustrer?
  87. vibration at 45+ sometimes...
  88. what makes a clunk sound in the rear quarter panels
  89. Rear rattle at stop sign. In N no rattle
  90. New muffler major leak
  91. Heavy Fuel/Emissions odor from rear of 4Runner
  92. 2002 4Runner Shock Replacement HOWTO (Front & Rear)
  93. New ARB and Warn M8000 (pic)
  94. 99 4runner cat back exhaust systems?
  95. Turbo install on Trucks! show
  96. F1 Clutches?
  97. Just totalled my baby :(
  98. 2002 tacoma rust, help.
  99. Hilux Surf Field Monitor Currently For Sale on Ebay
  100. 2000 4Runner Hesitation Traveling Central America
  101. Grinding sound in transmission after manual hub install
  102. 2.7 Tacoma engine makes chugging noise and feels week under load HELP
  103. Axle housing breather fitting question
  104. 3rd gen 4runner rust, under carriage
  105. Looking for a spare 3.4 harmonic balancer
  106. 2002 4runner 4wd sticks, help!
  107. New rear bumper / New OME coils in back....Help
  108. Alternate method for replacing steering rack bushings
  109. What's this connector on front timing cover
  110. 01Taco Driver's Side Door Won't Open
  111. 1997 4Runner Instrument Lighting Upgrade
  112. Bearings
  113. Exhaust system question
  114. Lift feedback.
  115. Which gears to get? 4.88s or 5.29s for my 2.7L 5-speed Taco
  116. Can anyone give me alternator plug number?
  117. My 231mm Tundra brake upgrade
  118. Anyone With UWS TBSND-60 Deep Toolbox?
  119. whinny noise when braking? HELP
  120. Is your engine supposed to be level?
  121. Need help with headers
  122. lunchbox locker in 7.5 ifs????
  123. Electrical Problem Tail Lights Flashing with Turn Signals, no Brake lights
  124. rebuilt head
  125. Interior Parts
  126. Different running boards?
  127. Daytime Running Lights stay on when Vehicle off
  128. 1998 Limited rear window issue
  129. 99 4runner front parking lights keep blowing
  130. Rough ride & braking
  131. Mystery Vac lines
  132. 3.4 blue coolant hoses
  133. got my lift installed on my D cab
  134. 2000 4RNR Oxygen Sensor issue
  135. Air conditioning trouble
  136. Mystery Vibration
  137. Meth/Water injection on a turbocharged 5VZ
  138. 96 tacoma rear add a leaf and lift block kit question?
  139. 1998 4runner headlight retrofit hid projector write up / review
  140. Clutch Master Rebuild
  141. 2000 4Runner Sr5 idle issues
  142. Need help with part numbers for IACV water bypass hoses
  143. Rear axle swap headache
  144. Cluster/Speedo issue in 1997 3.4 4x4 Taco
  145. rooftop cargo rack that mounts on factory "T" slots?
  146. Way of MAKING the check engine light come on? Need to test it
  147. General motor questions with pictures.
  148. 2000 4Runner running rough after new plugs, new wires, and a roadtrip
  149. 1997 4runner v6 sr5 2wd overheating problem help!
  150. 2001 4runner New Suspension install questions
  151. Actual transmission temperatures
  152. 95.5 Mini Taco spindle swap
  153. 2002 Taco/starting problems..
  154. Ticking from engine - only in morning - ticks faster as I rev
  155. Power steering Squeal
  156. Wrong T-case??????
  157. 5vz-fe running warm after timing belt. (pictures for pleasure)
  158. Rear differential stuck in locked position.
  159. 3rd Gen Front Door Panel Removal
  160. Transmission Problems!
  161. 04 4wd issues!!!!!
  162. heat&ac control unit replacement
  163. Parasitic Drain '02 4Runner SR5
  164. External transmission cooler (again!)
  165. Request for 3rd Gen 4Runner front door panel rough dimensions
  166. Swapping Original 1997 3.4L 4runner Engine For JDM
  167. Auto Trans Type and Should I Change Filter?
  168. Euro Landcruiser Prado poly rear suspension bushings will fit 4runner?
  169. 3rd gen supercharged from the factory?
  170. Help Finding the ABS Diagnostic Pins...
  171. Replacement Grill Options
  172. Aisin ABS Controller?
  173. '99 - Loose steering, strange horizontal slipping on turns, and squeaky hinge sound
  174. My Old Man's New 3rd Gen With A Surprise!
  175. removing 3.4 engine to replace freeze plugs - what else should I do while its out?
  176. Back of Dash Wiring Harness Help Please
  177. What is wrong with my truck
  178. turn light problem
  179. Xtra cab Quarter Window Latch Repair
  180. Tundra caliper - part number question
  181. Battery Light On/Off.. WTH?!
  182. 35" Pitbull Rockers and Cumburg UCA's en route!
  183. 05 Tacoma 17" rims on a 97 4Runner?
  184. 4Runner Seats
  185. Drive Shaft Sounds Like Death *Videos*
  186. denso 02 sensor part numbers?
  187. 2000 4runner engine swap?
  188. Fried Instrument Cluster?
  189. Help! My drive shaft is coming apart!
  190. 97 heater core replacement
  191. transfer case refresher
  192. LC engineering headers not fitting right on my 3rz
  193. Reinforcing the Roof of our '98 4Runner
  194. Tundra brakes and perhaps 15" wheels..........
  195. Installed new hose, have concerns
  196. (TRD) 7th injector fitment
  197. Gasket question
  198. Black paint
  199. Antifreeze leak from pipe below sending unit
  200. What would happen if O2 sensors were switched by accident?
  201. Cyl 2 and Cyl 3 misfire, not P0420
  202. t100 crossover steering on a 3rd gen 4runner?
  203. Tundra Brake Upgrade JUST ONE QUICK QUESTION
  204. Misfire driving me nuts
  205. Steering shaft spline & airbag connector plug
  206. A340F transmision problems
  207. P0120 TPS issues 2.7 & 3.4
  208. What seals to replace while doing clutch?
  209. Prepping a Supercharger for Powder Coating.
  210. Things I did this weekend...with photos
  211. Interior LEDS installed (pix included)
  212. Fitting a 35 into the spare location.
  213. Starter problem?
  214. Do I need longer shocks for LX450 springs?
  215. Pic request, 3rd Gen 4Runner with black hood
  216. Rear differential issues or something else?
  217. 96 3.4L Timing Belt Change
  218. Air horn upgrade
  219. I need help please!!! 2002 t4r PO171 CEL
  220. Opinion on OME Nitrocharger vs Rancho RS9000
  221. Standard vs. Auto.
  222. '96 Tacoma Gas Mileage
  223. Power Steering Pressure Hose
  224. Brake lights
  225. Hmm I wonder...
  226. Is my speedo going out?
  227. tacoma body lift
  228. Issues with ESC1
  229. 00 4runner auto trans problems (tranny question)
  230. found a 4runner rear tire swing, need help with mounting
  231. Wheel, backspacing, brakes
  232. AC mag clutch plug
  233. Weak Inertia from Stop
  234. indeed, a 97 4runner mirror fits a 2000
  235. 98 4Runner P0300 Only
  236. LC coils lift questions
  237. rough idle new plug wires and coil pack
  238. Grill guard for 2000 4runner ... recommendations?
  239. Emergency Brake
  240. clunk in reverse
  241. Heat blowing cool air
  242. Love the strawberry shake!
  243. HVAC Question
  244. Oil Pressure Switch 5VZFE
  245. one free 300k sticker left to give away
  246. 1996 4Runner ECU - have to reprogram?
  247. 99 4runner hard to crank especially when cold
  248. how do I change power steering fluid?
  249. Fuel pump wiring
  250. Antenna
