Way of MAKING the check engine light come on? Need to test it
Old Feb 19, 2012 | 02:50 PM
jmfranc's Avatar
With the problems I've been having lately I should have seen the check engine light but never did. Anyway of testing it to make sure that it will come on when it needs to?
Old Feb 19, 2012 | 02:55 PM
rworegon's Avatar
Go into USER CP and add your rigs specs to your signature line. It will help for answering questions.
Plug a code reader in....you may have a stored code.
Your fuse or bulb on the dash may be burned out if you don't see it come on for a second or two when you turn the key to start.
Oops.....I see James already cover this last item below.
Old Feb 19, 2012 | 03:06 PM
James Woods's Avatar
It should come on when you turn the key on with the engine off for the first few seconds.
Old Feb 19, 2012 | 03:24 PM
xxxtreme22r's Avatar
^^^^ THAT. No code reader needed. Each and every vehicle's CEL will come on with the turn of the key and engine not running.
Old Feb 19, 2012 | 05:25 PM
jmfranc's Avatar
Yea. Good point. Duh!
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
Dr. Evil
Jun 7, 2002 09:19 AM
