Rear differential stuck in locked position.
Old Feb 16, 2012 | 12:59 PM
Ryanmill21's Avatar
My '01 tacoma won't unlock the differential with the button in the cab. Any suggestions besides a replacement?
Thanks, Ryan.
Old Feb 16, 2012 | 01:07 PM
Elton's Avatar
e locker ? or
Old Feb 16, 2012 | 03:23 PM
Ryanmill21's Avatar
It's an electronic locker.
Old Feb 16, 2012 | 03:30 PM
Jomoka's Avatar
Did you drive it in an 'S' pattern?
Old Feb 16, 2012 | 06:10 PM
muddpigg's Avatar
One of the benefits of the e-locker over air locker is that it can fail in the locked position. Airlockers unlock not so good if you still need the traction. I've read that you need to pull the solenoid then take a flat screw driver to unlock the diff. Then you can trouble shift the solenoid. Keep the opening covered to protect from dirt and debris from enterring the diff.
Hope this helps, good luck.
Old Feb 16, 2012 | 06:30 PM
James Woods's Avatar
Pretty much what muddpigg says
http://www.pirate4x4.com/forum/showthread.php?t=144148
This one has a wiring schematic
http://www.pirate4x4.com/forum/showthread.php?t=814205
https://www.yotatech.com/forums/f31/...nually-181831/
Old Feb 16, 2012 | 08:03 PM
c0ugar69's Avatar
its bad just send it to me and get a new one!!
Old Feb 16, 2012 | 08:04 PM
c0ugar69's Avatar
pull the motor cover and check there! make sure its getting power.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
icentropy
Jul 14, 2015 10:23 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
AaronM
Jul 8, 2015 07:15 PM
