PDA
View Full Version : 95.5-2004 Tacomas & 96-2002 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 [141] 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222
  1. torn head rest
  2. Clifford RSX 3.5 Alarm
  3. Hub Question
  4. Moisture Buildup in Silverstars?
  5. Tire Fitting
  6. Big Problems
  7. front pics of 3VZE
  8. Polyurethane body mounts
  9. Need help with an engine diagnosis...
  10. Anyone know what this is?
  11. Has anyone painted their bed extenders?
  12. torsion bar crank?
  13. Bilsteins or Edelbrock IAS performers?
  14. 22r Head differences.
  15. Steel breaded brake line 3rd Gen
  16. Roofrack advise needed!!!
  17. What was the worst throttle body you've ever seen?
  18. 4Runner starter
  19. Air Lift, Air Ride, whatever you wana call it...
  20. locks on fog lights
  21. Tie rod end
  22. 9inch Lift Tacoma on Ebay (not mine)
  23. 97 Cup Holder Removal
  24. L.E.D interior lights?
  25. 85 4runner questions
  26. 33" bfgs with a 2" Downey Lift?????
  27. Torsion bar question
  28. Daystar front end swaybar-endlink bushings
  29. Scored a 3.8 Torus fan
  30. aftermath of getting broken into
  31. Used oil storage containers: I need one that works!
  32. OBD-I Codes
  33. E-locker wiring success!
  34. About a million and three questions (loooong)....
  35. Basic Fuel Filter question...
  36. Engine swap gurus- I have parts car ??
  37. Towing a popup camper
  38. Just wondering...
  39. 4Runner SAW on a Sequoia?
  40. Oil type for rebuilt 3.0
  41. Fuel pressure reg...Hold vacuum??
  42. god darn it. Dented my bumper.
  43. Cold Starting Woes
  44. trade my 4 wheeler for 1990 4runner sr5 4wd:pics
  45. Good Deal?
  46. Help! I need to buy an E-locker Fast!
  47. rear diff
  48. Need help finding a tire
  49. 1G Fiberglass Cap w/ Thule + Kayaks=BAD
  50. I went mall crawling today....
  51. ABS light after carwash, any ideas?
  52. Isn't Someone here an Amsoil Vendor?
  53. Flexible Air Hose to Air Filter Question
  54. Help..! Wheels?
  55. True Passion
  56. pickup sliding back window latch
  57. Exhaust leaks
  58. Help????
  59. SAS'd Tacoma on Ebay
  60. Flex-a-Lite Cooling Fan 1st Gen
  61. replacing fuel filter on 95 4runner?
  62. Revtek or OME??
  63. Anyone have the stock numbers for rear wheel hp on the 3.4L?
  64. is my problem the tranny or something else?
  65. Gasket
  66. Wet Okole Grey Color Match # ???
  67. How many different belts?
  68. hottttt
  69. Loud Creaking Sound when turning
  70. Woe is my Runner
  71. heat?
  72. Towing question
  73. loose tierod jam nut
  74. Can someone tell me what this is?
  75. E-brake light on while driving
  76. Newb- Do I have manual hubs?
  77. Bore spacing question...
  78. opinion on shop!!
  79. Brake! warning light
  80. Tranny prob
  81. Add Mod
  82. Tire history thread
  83. 22r overheating problems
  84. Sway bar end link bushings?
  85. Anyone have JL 12W7's?
  86. Fuel Injector Cleaners
  87. Removing rust spots from chrome grill???
  88. Which wheels should I use?
  89. what does the ECT button do?
  90. Frankenstein Helppppp!
  91. Another 1st gen question
  92. Disabling passenger side airbags on '03 Sport Edition
  93. New member, small problem
  94. check engine light when i halfway floor it??
  95. Aisin Manual Hubs
  96. 3rd Gen Side Step Bars
  97. Where can I find JDM parts for my '00 4Runner?
  98. 91 4Runner idles @ 4k??
  99. Rear hatch latch..NEED help BAD
  100. 95 4runner only
  101. Anyone make a flush mount hard tonneau
  102. How often should a O2 sensor be replaced??
  103. Stock 22RE Specs?
  104. 3.0 rebuild questions....
  105. CV's Shot ?
  106. Actual Old Man Emu, 881 & 891 springs
  107. new to forum.....vibration question
  108. 99 SR5 - How do you know if it has a locking diff?
  109. 4Runner ABS rear axle vs. Taco no ABS axle
  110. un even tire wear, BAD
  111. Aftermarket Cats, Who's running 'em?
  112. Iridium or Bosch 4 spark plugs?
  113. Panhard relocation bracket
  114. Why is my runner so sloooooowwwww?
  115. Air Shocks
  116. Cross Country 2nd gen trip- 1800 miles
  117. Just got a 86 xtra cab, and have some small questions.
  118. Swaybars chunking...!
  119. wheel spacers
  120. Body mount bushing question
  121. lc engineering header?
  122. Ome 882
  123. Quick Throttle Body Question
  124. Help deciding wheel for my tacoma
  125. 4Runner Dilemma
  126. what tire size should i run w/ this...
  127. Need a new synthetic winch line?
  128. Vafs?
  129. Need help with speedo calibration
  130. Hello New Toyota owner here.
  131. Yet another OME rear install question
  132. JAOS, aux lights mounthing brackets ?!?
  133. Figures and numbers, 1st gen oil leak
  134. MOUNTING WARN X8000i
  135. who has diamond plate?
  136. Videos
  137. 3rd Gen. Revtek Owners
  138. Changing the interior
  139. Alignment with Revtek Lift
  140. Please Read if you have installed a 3rd Gen PanHard/Trac Bar drop bracket
  141. Hitch Strenght/Differences?
  142. K & N Filtercharger
  143. Thinking about selling my truck for T100 need help!
  144. 4th gen...V6 vs. V8
  145. Help me out with tire rub!!!
  146. Strange noises from inside the vehilce
  147. Tierd old runner
  148. Black Alloy Bead Locker Wheels...
  149. problems after wheeling.
  150. Toyota Carpet Kits
  151. 2 questions about shocks for a 95
  152. LOCK ASSMBLY & CRUISE/SPEEDO STOP
  153. Hosed bottom end?
  154. Toyota transmission help desperately required
  155. 2nd gen car cover
  156. Why was the 2nd gen I drove so slow!?!?
  157. Long Drive Home
  158. My 4runner (as of now!!)
  159. Performance Products HELP
  160. O2 sensor question
  161. Just wonddering ...
  162. rear end noise
  163. can I remove my running boards? look
  164. Speed sensor replacement early 90's 4 runner?
  165. what is the fastest mph you have done with your 2nd gen with 33" tires
  166. Cut Vanence
  167. strang noise please help!!!!!
  168. check out this 1970 Hilux on teh Bay!
  169. Speedometer not working
  170. Diff lock not engaging
  171. noob alert! 89 sr5 v6 p-up
  172. Installing air conditioning in 2nd gen without AC?
  173. Winch install questions
  174. what oil for 22RE?
  175. Tune-Up Kit?
  176. Trail Master Lift/1G 4Runner?
  177. Broken clutch bracket repair
  178. Final Vac Gauge Question...
  179. Rebuilt my CV's today
  180. Suspension Help
  181. Mr. Clean Auto Dry Carwash!!!
  182. bolt size????
  183. 2001 4Runner questions
  184. 22r/20r hybrid auto tranny questions.
  185. OME Front and Sahara bar Do I Need Spacers
  186. Surco Safari Installation
  187. taking off tacoma dash
  188. Finally learned how to post pic of my truck...I think
  189. /mud /flaps
  190. Hippo Liner Completed on my '02 taco
  191. My new wheels and tires!
  192. Fog Lamps
  193. Brown Body Lift...
  194. trusted shops
  195. supercharger
  196. Rear Flex
  197. throttle body
  198. Clicking / Rattling Sound?
  199. Auto theft investigator needs help!
  200. will these fit
  201. Free flow cat converters noisy? Heat wrapping?
  202. Locker/Bumper, lights/ C02 system
  203. 1993 4runner Headgasket Or Two Blown
  204. Where are u 05 4Runner ???
  205. Torn inner CV boot. 3rd gen writeup anywhere?
  206. Can anybody recommend a welder in Virginia
  207. 2 Skids... $60
  208. New Member with a few questions
  209. TSB EL010 -- No more!!!
  210. Install kit
  211. Magnaflow cat back
  212. O2 Sensor
  213. Pro Camshaft?
  214. "Good Sounding" Filters?
  215. do i have to remove my TJM to install BL?
  216. Benefits of exhaust mods?
  217. TRD 7th Fuel Injector Kit
  218. K&N 4 Cylinder FilterCharger 22RE!?
  219. Anyone paint their 2nd gen? (have it painted)
  220. Check Engine light - Dirty air filter
  221. R-12 to R134A AC Swap
  222. 22RE Airbox Mod Writeup Please?
  223. 2005 Frontier V6 vs 2005 Tacoma V6
  224. What air intake system?
  225. 03 Debadged and JDM Taillights (PICS)
  226. PCV is easy, my eye!
  227. Bed hitting cab on Tacoma?
  228. What do I need to know about...
  229. cd player problem
  230. 99 dash mod
  231. Which engines w/Year?
  232. Hard Start 3.0 Urgent
  233. Does low idle=more power & high idle=less?
  234. Lift Suggestions Pls....
  235. Rear Drum Brake Shoes
  236. Skid Plate....
  237. fair price for labor?
  238. where to get 3rd gen starter cheap??
  239. New Pics and Such
  240. Did TRD make a wire set for the 90-92 3VZE?
  241. Spare Tire
  242. What is the biggest 18 inch A/T tire that I can fit?
  243. Sagging door gaskets on an 02
  244. Cargo Storage Write-Up - Pics
  245. ok, 02' Tundra 16" wheels are on the 4Runner, pics
  246. 1987 4Runner
  247. Body work started
  248. Help on Hitches
  249. Rim pics
  250. Window help
