Vafs?
Old Aug 17, 2004 | 01:09 PM
Back40's Avatar
Vafs?
I suspect the VAFS (Vane Air Flow Sensor) on my 92 4x4 3.0 xtra cab is sticking? I am experiencing engine hesitation upon initial acceleration(like lifting my foot on/off the accelerator). I removed the top of the air filter box and moved the flap with my fingers. It moved freely. I removed the 2 screws that secure the wiring plug to the air clearner lid but found several attached connections within the air cleaner lid that I could not disconnect. Any advice is appreciated.
Old Aug 17, 2004 | 01:25 PM
Marc's Avatar
I think you undo the wire clip to remove the connector.
Old Aug 17, 2004 | 03:12 PM
nunsa's Avatar
I don't believe it's your VAF, but here's some info that might help:
http://www.celicas.org/mods/afm.html , WORD OF WARNING: If you accidentally screw it up it will cost you!!! I believe that you have other problems other than your AFM. Did you check the usual suspects: tune-up, tps, vac leaks...?
Good Luck!
* Harry *
IronsmanMedic
Jul 9, 2014 08:57 PM
rjfortuna
132
Jun 22, 2014 06:24 PM
qcabra
Dec 25, 2009 04:27 PM
mojoman
May 1, 2009 01:43 PM
