Tranny prob
Old Aug 18, 2004 | 06:02 PM
Mudfreak's Avatar
Tranny prob
I have a question about my 4-speed tranny. In order for me to go in reverse, I have to hold the shifter in reverse and go real slow, or itll pop out and bang gears. Whats going on with it?
Old Aug 18, 2004 | 06:36 PM
is this a manual? if so maybe the shift lever seat
here is a thread on it
https://www.yotatech.com/forums/show...ift+lever+seat
Old Sep 10, 2004 | 08:10 AM
Mudfreak's Avatar
Anyone else have a clue?
Old Sep 10, 2004 | 08:17 AM
mt_goat's Avatar
Is it an auto or manual?
Old Sep 10, 2004 | 08:40 AM
Flamedx4's Avatar
Roadtrpr is correct. That's probably it - either the seat or the piece at the tip of the shifter. Otherwise the answer would lie in in worn out shift forks etc, which is fairly unlikely. Pull your shift lever out, it's easy, and see if either or both of the plastic parts need replaced.
Old Sep 10, 2004 | 08:43 AM
Mudfreak's Avatar
its a manual
Old Sep 10, 2004 | 09:29 AM
Mudfreak's Avatar
How do I take the darn shifter out?!?!
Old Sep 10, 2004 | 10:31 AM
Probably somewhat similar to this writeup though your truck is older
http://www.off-road.com/toyota/tech/shifter/index.html
Old Sep 10, 2004 | 02:14 PM
Flamedx4's Avatar
I *think* those were different - the newer ones you just unbolt four bolts and lift the whole seat assembly and shifter out, or you can 1/4 turn twist just the retainer out and lift the lever out of the bushing either way, but I think the old four speeds had some kind of clip dealie you undo and lift out the lever. Too many years have gone by... or too many beers.
Old Sep 10, 2004 | 02:19 PM
Flamedx4's Avatar
When I get home I'll scan the exploded view in the manual for you and post it here. Hows that?
Old Sep 10, 2004 | 07:16 PM
Flamedx4's Avatar
see if this helps...
Old Sep 15, 2004 | 01:31 PM
Mudfreak's Avatar
dang it..the little plastic thing on the end of the shifter was in good condition, and I replaced the seat but it's still not working right
Old Sep 15, 2004 | 02:19 PM
toy283's Avatar
You might want to call Marlin and ask him. Seems to me that there is a common problem with the old L-series trannies bending shift forks. Sounds like this may be what happened to you.
Old Sep 20, 2004 | 03:20 PM
Mudfreak's Avatar
any other ideas?
would a 5 speed bolt up to my BH? or would I have to get another L45?
Old Sep 20, 2004 | 03:41 PM
toy283's Avatar
L series trannies have an integral bellhousing so no. But, you can bolt up a L52 trans to your engine quite easily or a G52 or W56 with a little bit more work.
Old Sep 20, 2004 | 06:29 PM
Mudfreak's Avatar
And how much for a L52? is it a 5 or 4 speed?
Old Sep 20, 2004 | 08:44 PM
toy283's Avatar
L52 is a 5-speed that was offered from '81-'83.
FWIW, thats what the first digit in the tranny model number refers to at least on L,G and W series trannies. Not sure what the "1" on a R150F refers to, but again the "5" designates a 5-speed.
Old Nov 8, 2004 | 06:42 PM
Mudfreak's Avatar
Anyone else? Id like to get this fixed still. When I drive it I have too much fun, but I need reverse!
Old Nov 10, 2004 | 07:54 AM
Mudfreak's Avatar
No one?
Old Nov 10, 2004 | 08:59 AM
hilandfrog's Avatar
just because I don't know ˟˟˟˟, ON my 76 cj-5 I was having simmular problems, I rebuilt the tranny and that included new syncro gears. I don't remember if reverse has syncro gears (the soft brass gears between the hard steal gears) but maybe someone with a clue could respond if these gears might be your problem????
good luck
VR
Repo
