- Where to buy Tacoma hood weatherstrip seal?
- 4wd not engaging
- Failed CA emissions check
- Help me spend my money on my 3.4L
- 3rd gen valve gasket replacement
- Abs
- Drain & Fill of Radiator Not What Expected?!?!
- advice? cracked bellhousing...
- Starting problem
- Power steering troubleshooting
- Headlight restoration
- 16" spare tire rim width?
- Colour Matching Limited Flares
- reg. pwr. windows to auto. pwr. windows
- Group buy: Doug thorley headers 3.4L
- Broken sensor near oil filter
- Rock Slider idea, Couldn't find info.
- Tacoma shocks???
- 97 4runner heat not working very well???
- Wheelers Rack bushings 2000 Tacoma 4 WD, big difference
- 4runner led lights????pics/info etc
- Replacing time belt on 3.4L.
- **** 99' 4-runner not running so well HELP!! ****
- new clear lights check em out!!!
- Snow
- 01 Tacoma equipped with Toyota factory alarm but no remote?
- 2000 stock radio amp
- drop bracket lifts
- fog lights
- 3.4 Troubleshooting help please
- Help!!! Breaks caliper won't release!
- 2000 5 speed whats it worth?
- Help w/ 2000 Interior Light Replacement
- 99 AC-Heating Controls
- New lift and shoes for the Taco
- Trd header question
- Bracket Lifts.
- The difference between the two?
- 3inch sus and 3 inch body lift 2000 4runner
- 1000hp Taco *video*
- Body lift removal.
- MAF cleaning
- single DIN gauge pods?
- need HELP finding a place to install my lift in LA
- 1135 Error Code for 01' Runner
- ABS computer module differences with elockers
- 1997 4Runner problems to look for?
- 99 runner ......maintenance pictures
- Installing supra maf into 98 4runner issue
- Auto V6 with 35's, What else should be upgraded for mileage/reliability?
- Hopefully a CV problem
- Rear Axle Seals Replacement?
- What makes Brembo rotors better for a 99 runner?
- Automatic Transmission slipped today...
- As long as your driving a 4Runner, a workout is never far away!
- Sirius artist alert and traction control sound the same?
- 4Runner ecu??
- Looking for a part..Anyone?
- Looking for Fender flares
- Check this lifted van!
- 01 4Runner-transfer case noise
- 2003-04 Tacoma - CA emissions - 50 state legal?
- Weird OBDII code... please help diagnose
- 1998 4Runner 3.4 -- Timing issue?
- antenna problem
- 5Vzfe question ?
- my 18.5 Gal Tank only fills to 10 gal. '97 T4R
- Diagnostic Port Under Hood vs. OBDII Port Under Dash?
- best writeup for 3.4 V6 spark plug change?
- 2000 ltd grey wire mod questions
- Will it fit!
- Looking at 03 taco lim. trd 4x4
- Bud Built Skid bolt sizes...?
- what tranny do I have?
- Should I buy
- Question about VIP RS3000 Alarm
- OEM Mudflaps for 4Runners w/o flares
- P0300 code. Bad gas?
- Computer question
- 99 SC - What is this?
- Got a cold air intake on your 2.7 Tacoma? Post pics.
- ARB Bumpers for us... I know I'm missing something here!!!
- 99 runner front brake pad question
- Tire Size compared to MPG
- Anyone herculined thier Limited trim panels?
- Calling all ARB Bumper Owners on a 3rd Gen
- Need help for a friend
- Can you disable drive by wire?
- is this really possible?
- Flat towing with a 4Runner?
- parking break problems need help
- Anyone else with front diff problems?
- Help! I did something stupid... Break Lights/Shifter problem
- Hayden Install w/ radiator trans cooler bypass
- 98 Tacoma "whine"
- Bug deflector
- Japan Spec Parts for 4Runner???
- Lifting back bumper after 3"body lift 98 Taco?
- Steps to Replace a Broken CV Joint on 98 Taco?
- Toyota says I need to replace both Catalytic Converter
- My 99 Tacoma story....with pictures
- toyota e locker
- Good price for my 4Runner?
- First interior rear mod
- Interior rear mod
- 97 taco elocker conversion
- Pro Comp 8069s
- Front Bumper with winch
- OME 890's: Driver and passenger side specific??
- how much power?
- wheel spacers w/ trd fj rims?
- Just bought my first toyota
- 95 Tacoma wants to stall in R/D Stumbles on Accel!
- CB mount in 3rd Gen.
- 4runner fog light splash guard mod, MacGyver style
- i want more power!!!!!
- Question about a bumper......
- What a noise! 3rd gen rear end
- Did coolant kill your transmission? Report it to NHSTA
- Is this model tacoma reliable? Pics inside
- Steering Rack and Pinion and Shocks
- TRD tundra springs?
- 99 4runner timing belt ?
- Got my 33 MTR Installed
- ABS computer swap
- My drive shaft went bye bye, how much will this cost me?
- Timing fluctuates at idle
- 99 runner rear spring recall info needed
- 98 LMTD 4wd light doesnt illuminate
- 2RZ Exhaust Manifold Question
- New to YotaTech but have a queston on lifting
- comments on lift idea??
- 3rd gen Limited Interior trim
- Converting from 2wd to 4wd
- Brake Light on
- grey wire mod oops?? HELP
- doing maint on my sisters 96
- Belt squeal? which one to replace
- jaos spoiler + led tails = abs light?
- 99-02 console in a 98? any ideas?
- 3rd gen vs 4th gen rear axle assemlies question
- 2.7 maintenance Q's
- Adjusting rear seat backs, 3rd gen
- Model number help ????
- Keyless entry problem
- HELP PLEASE! P1300 code and dead truck!
- Reporting Problems to Toyota
- 1997 4Runner Auto Transmission Rebuild - $2,100-2,900?
- Windy City starting woes
- ? about VSC
- 95 4runner antenna cable replacement
- The Age Old debate TRUCK VS SUV
- These Repairs and Maintenance from dealership seem sound to ya?
- Antenna Problem - Need Solution
- 2" bodylift issues on 3rd gen 4runner
- New pics of my rig.
- colored grille
- 2wd bed question?
- Need with O2 sensors
- Offset for MT Classic II's
- 2001 Taco 4wd ECU help
- Help please 3.4 injector removal
- Just a thought
- 4Banger Vs. v6 Prerunner. NEED ADVICE
- P0450 code
- lift help!
- add a leaf or longer shackles
- Is it worth it?
- backspacing
- Question about Prerunners
- VSV pretty loud
- Let girl drive truck, now it clicks
- Misfire!
- 4Runner vs. Curb
- 98 Tacoma Questions
- 2wd to 4by ?
- Picked her up on the weekend????????????
- How common are 3rd gen standard shift runners?
- 3.4 power adders
- Qs on supercharger
- Maintenance on 99 runner
- Going to the Dyno on Thrusday, anything easy ya'll want me to test?
- 97 Ltd 4wd -- front struts or shocks?
- 99 4runner needs help
- Havent posted pics yet of the lift and tires so here they are!
- 170k = too much?
- Disconnected Battery, now 5VZFE idles LOW!
- 3rd member help
- Coil Pack
- Potential Newbie, several tech questions??
- Mega Warrior Installed
- Factory power steering fluid ?
- Found a rear locker in the junkyard yesterday - Graham WA
- Trailmaster lift help
- Vibration when clutch petal is pushed in...
- 4Crawler 1.5" Body lift installed! (pics)
- How many 4unners do you own
- The official 01-04 Tacoma Clip conversion thread!
- On-board air on a 3rd Gen (Pictures)
- Vehicle pricing: kbb, nada, etc?
- Can a broken PCV valve cause a P0171 code?
- Looking for advice on which generation 4Runner to buy.
- Cat Replacement
- 6th cylinder misfire
- 4Runner- Dual battery/Alternator Q's
- Transmission Solenoid Question
- What brand of lift would you use.
- I really wanna buy a supercharger !!
- headlamp question ?
- battery ground ?
- Osram Night Breakers
- 4 runner / tacoma rear locker??
- Old vs. new(er) Tacoma ride quality question
- fitment of tundra 199mm calipers in Procomp7089's???
- Owners Manual downloads???
- '95 4Runner bad crankshaft???
- Air/Fuel sensor
- 3/4" d-ring shackles
- ‘98 4Runner – Headlights go completely off when switching from high to low beam
- Chicagoland Taco mechanic needed
- rusted out floorboards!!!! Please help!!!
- Rough running and clicking
- How do you adjust the idle speed?
- newbie with a strange vibration/noise
- Thoughts on TRD Package?
- Questions for Mechanics for Price on what they said wrong with my car.
- alternative to rock sliders??
- Clear DEPO Corner Lights
- Clear Third(3rd) Brake Light and Hood Scoop
- Anyone want to change my clutch out, 2000 Tacoma v6 4x4
- 3rd gen. 4runner front diff removal
- Need help!
- Lots of steering/suspension parts cheap!
- Way OT 4x4 Van
- Cel p0500
- New lift wheels and tires
- 880/906 Today!
- Put my DP on my Kennesaw Mountain Accessories rear bumper last night!
- Can someone please post a writeup of installing an Arb taco bumper on a 3rd gen pleas
- '97 Limited locked me out
- grinding hub while in "free"
- Can somebody please post their dome light T4R?
- Supercharger belt routing diagram
- What brand of CV joints are you using?
- Front passenger break locks up on ice and won't release
- Factory Parts Cruise Control install on 2001 Taco
- 2000 4runner - aftermarket stereo install question
- the proper way to service a tranny?
- Vibration after Clutch Replacement
- Advice on towing my motorcycle...
