- Tach swap not working
- Camshaft/rocker arm question...
- First mod...hmmm
- US Navy Chooses 4Runner
- 03 Limited Stock Radio
- Hey,... I have a couple of questions about lifting a truck.
- Finding accesories for my truck
- Any florida 4runners out there???
- Is $29754 a good deal for 2k4 4Runner 4x4 v6 Sport Ed.?
- Mileage and the 7th Injector
- shocks
- What does this mean???
- what lift is on these?
- Replacing my driveshaft wrenchathon?
- ECU location on 99 4runner
- fanclutch affecting gas milage ??
- Anyone tried Sylvannia Sealed Beam Units ?
- Questions about super chargers
- Questions About 4th Gen: V8, Towing, S/C, Third Row Seats...
- Is anyone running the TRD 16X8 wheels?
- Anyone add a CD changer to stock radio?
- Exhaust leak.....
- Tranny Problems
- what to look for in a 1988
- more gear questions?
- Tire Size for 1st Generation Runner
- 2004 Prices NorCal 4Runner?
- Loose drivers seat
- elbo hose leading to nowhere under the intake
- ? for those who change their own oil
- newbie needs 88 manual trans HELP
- climate control cluster
- Questions on 3rd gen price and options
- 3.0L starter troubles
- Front & Rear Swaybar bushings
- What's different here? (pics)
- 1st gen runner Paintjob
- ARB IFS/E-locker Retrofit Combo Installed This Weekend!
- Anyone know how to remove to remove,...
- eBAY: SUPERCHARGER $1 - 1 DAY LEFT - No Reserve
- Before and after pics (New)
- I'm thinking about getting these seats for my truck...what do you guys think?
- 18" or 19" Wheels...Any ideas?
- NICE--1UZ-FE Lexus V8 in a 2nd gen 4Runner :-)
- Please help if you can....
- addapting a cummins turbo to a runner ??
- What lift for 01 TRD Tacoma?
- Cheapest source for Classic IIs?
- Bad vibrations after wheelin :(
- New alarm what to buy
- 22-re blowing white smoke....
- elocker
- Rear Seal Leaking
- PCV valve replacement on the 22RE
- Site w/ Toyota part #'s?
- Electric (Taurus) Fan Cooling indicator
- Disable DRLs on 3rd Gen.
- 900Lb Payload
- center consols
- Power Window Problem
- 2nd gen TJM??
- mud bogg in va pics
- Fixed the clunk from the spare!
- Buy a 4Runner or not?
- Free annual Hella fog replacement for life?
- Supercharging 4Runner
- 89 4runner
- Stubbs slider pics
- 22 pairs of PIAA, Raybrig & Koito halogen bulbs @ eBay
- Wood kits for 2003-2004 4Runner finally installed. Some pics...
- Rockware front bumper.
- Curious
- Taco's Window track
- Washington State, California,Miami = getting you 4runner stolen
- Landcruiser Power Antenna Switch
- differences between 2nd & 3rd gen hoods?
- Where to buy a totalled tacoma?
- 4th Gen Surefire light "mod"
- lifted 03vs04 stock
- toyota red and prestone green antifreeze mix
- 2003 4 runner possible trouble
- Passenger side autolock not working
- Larger Gas Tank?
- 4th Gen Front Diff Breather
- SAW spanner wrench
- Finally Lifted!!!!
- For all SC 4runner in CA, wut octane ?
- Rock Sliders Installed with PICS!
- Creeking sound from Front Susp.
- stuck rear window: regulator or motor???
- need some help...(86 toy clutch)
- How to bridge amp channels?
- Bodylift for 4th gens??
- Can the seat sensors be turned off?
- New Pics of the rig with winch!
- how do I get the check engine light off?
- Question about the LC Header
- Perfect solution
- Weird idle problem on 22r...
- San Diego Salvage Yard
- SAW Help!
- Will I screw up my suspension w/ 2" lift?
- 4Cylinder 4Runner
- 4runner SC under 5k!
- Tires
- Fuel Smell.....need Help
- I need some fender flare help..
- 90's Pickup & 4Runner bumper question
- Yota 7.5 diff broken???:help:
- Will the Taco's rear billsteins fit the 97 runner
- Motor Rebuild and such
- Fabtech Lift?
- Would a JDM ECU increase HP?
- 15x7 or 15x8?
- New 4Runner
- NOW AVAILABLE *for testing* R-SAK's
- My runners leaking from somewhere
- Speaker Depth in a 3rd Gen?
- ok so I made the list of parts needed for 4" lift, anything else I will need?
- Beadlock wheels or simulated beadlocks
- Just ordered clear corners!
- Calling all car audio Gods, HELP ME!
- so easily pleased!
- Repair Manual Question
- Which CB would you choose?
- 4th Gen DRL disable, update.
- superlift vs pro comp I know this was already discussed but..
- Someone keyed my 03
- Replacing Rotors & pads on a 97 LTD 4x4 Runner
- E-brake Light randomly comes on
- Pics of a 3G truck with 3G Runner wheels
- clicking noise in engine
- sorry for the n00b question...but what is a deckplate mod?
- Welllp, looks like this might be the last straw..
- Let there be light!
- 3"Bod lifts with auto trans?
- Think This Is A Good Idea?
- Strange smell from gas tank
- A Very Different 4Runner...
- 98 4runners rule!
- Why does my 3.0 idle low
- 285/75/16s on 16x7s?
- Supercharger specials?
- 2nd gens with lifts
- alarm question
- Carry a spare shaft!
- Help! In trouble with the Po!
- coil over 2nd gens
- Check engine light on
- San Diego brake shops
- Need Surco roof rack info for 2003
- photoshop experts needed please
- Bug deflector for '97 Runner?
- Rino Liner Paint Job
- is this a good buy?
- North Alabama and UltraSound Cleaning
- Where to put extra sunglasses in '04.
- TRD Apparel
- Hassled with Mudflaps Off?
- Shifting from 2H to 4H...
- Forum announcement
- Code Alarm
- Mirror Replacement???
- 2000 Stereo Wiring Harness?
- Ebay Warning - WHoa! $30 Heater face plate, up from $3
- need help!!! Place to install my lift in LA,CA area!!!
- Buying a head unit today...need your advice on the following decks
- Free O2 Sensor
- 3.4 L Super Chargers for $1950.00
- 4-HI Exceeding Recommended Max. Speed?
- Want to get rid of ADD?
- Best disco's and where to get?
- Brighter dome light?
- questions about a LIFT
- new to 4runner land
- Need steps to program Securikey+
- Scuba Tank
- Underdog Performance Fuel Kit!!!
- SAW/OME Install
- Conic Filter on Tacoma - Impossible?!
- valve cover baffles.
- Ceramic coating provider in the PNW
- 4Runner rollover cockpit
- removing headlights
- Leveling out 95 4runner
- FJ-62 Land Cruiser gets a new front bumper. Not ARB or TJM
- jardine exhaust
- New 4.0 oil filter placement-about time
- 1999 Front Bumpers...Aftermarket suggestions
- Gimme a broken 84-89 4r center console switch!
- Need lift opinions please!
- reciever hitch (dumb question)
- Fan under passenger seat?
- 2nd Gen lift Question
- Supra Swap in Seattle
- Alarm for 4th gen required?
- exhaust??
- Trd
- Thanks to Yotatech - new Hayden Cooler Installed
- Oil Change in 03 4Runner
- Weird starting problem!!!
- Brighter Back Up Lights
- RTI ramps?
- Newbie with 4th gen question
- Undercoating suggestions?
- Suspension Swap Possible?
- just installed FRONT GRILL
- 6x9 mounting
- How to remove the brass plug in the boost port?
- Interest in onboard air group buy?
- softopper to fit an older truck?
- ATS a-arms
- Cheap Trick of the Day! Late model 4Runner ground clearance at factory hitch.
- New 4Runner complete high performance suspension kit in the works!
- Please help with CB tuning
- battery dome light for cap
- front and rear diff swap
- Air Suction System noise
- Supercharger and Headers??
- Transmission flush...
- TJM vs ARB Bull Bars???????
- Stereo Questions?
- V8 SC and 7th injector, discounted
- 2003 Climate Control and Rear Defroster
- Changing Gears
- Downey 2" Lift from Toyota
- New some Ideas on parts :)
- gas fill up ?
- Need your opinion on tire/wheel combo
- Big time trouble putting factory stereo back in
- sudden ticking sound...is this the valves?
- Weird Idle problem...300rpm?
- Respiratory problems; any suggestions?
- instrumentation
- measurement from rim to fender - 1st gen 4runner
- Which generation 4Runner has the best resale value?
- Flat spot at 3000 rpm
- Did something really stupid
- automatic tire balancer
- Can I get rid of this thing on my vacuum line?
- $5600 for the V8 SC
- Pics of Lights Mounted to TJM-17?
- Another Hella 500 mounting question?
- 22re-LCE header and Hooker muffler review
- Gen II 4Runner Overheating
- Things to look out for in a used Tacoma
- Has anyone tried these keys?
- Death vibrations
- Trans leak on 96
- HELP! Brake peddle sinking to floor...
