Fuel Smell.....need Help
Old Oct 24, 2003 | 03:57 PM
jzdoit2's Avatar
OKAY HERES THE SITUATION,
I SMELL GAS ALL UNDER THE HOOD. CANNOT PINPOINT WHERE. HOSES LOOK FINE. NO LEAKS ON THE GROUND. WHILE DRIVING I SMELL GAS COMING OUT OF THE VENTS. TAKES TWO TRIES TO START. FIRST ONE SOUNDS LIKE NO GAS GOING THROUGH. SECOND STARTS NORMAL. I COME OUT THE TRUCK AND MY CLOTHES SMELL LIKE GAS. ANYONE KNOW WHAT IT MIGHT BE.
FACTS:91 4RUNNER, 112,700 MILES. NEVER CHANGED FUEL FILTER. LOCAL MECHANIC SAYS POSSIBLE FUEL LINE LEAK. i HAVE APPOINTMENT WITH TOYOTA. BUT I KNOW WE HAVE PLENTY OF KNOWLEDGEABLE PEOPLE HERE. PLEASE REPLY. THANKS.
Old Oct 24, 2003 | 04:09 PM
its2slo's Avatar
it IS the fuel pulse damper.
lose the caps please
Old Oct 24, 2003 | 05:52 PM
mtnfreak's Avatar
I second the notion. Possibly also a leaky injector. While you're in there, at least have the injectors cleaned, change the PCV valve and the valve cover gaskets (V6). Time for a valve adjustment too? And chnge the fuel filter - it's time.
Old Oct 24, 2003 | 07:46 PM
jzdoit2's Avatar
Talking thnks for the replies
thnks for the responses..Should I go through Toyota dealership service center. Or to a local mechanic that ive been going to for my 100,000 service and other things. I do know one thing it will cost probably much more at the Dealership than local mechanic. question is: Is the quality of the job done worth the extra $$$$$$?
sorry about the CAPS fixation..LOL
Old Oct 24, 2003 | 08:36 PM
Fink's Avatar
IMO...the only reason for ME to go to the dealer is for getting big things done. Like actually replacing big parts...that way I am SURE that they will use Toyota parts. I would just base it on what you are having done. If it was me, for that kind of a problem (leaking hoses possibly) I would just go to the local guy. Then after that if you are still having problems then take it to the dealer and they will most likely find it.
Let us know what happens man!
Fink
Old Oct 25, 2003 | 02:12 AM
ByThaBay's Avatar
I would check the charcoal canister.
Old Oct 30, 2003 | 03:50 PM
jzdoit2's Avatar
UPDATE
Looks like its the O-rings. All 12 of them. Inner and outer..according to mechanic. Also the intake chamber gasket.
The total comes out to about $350. I guess thats not too bad. I probably should put some of those high performance fuel injectors while were at it. hehe.
Old Oct 30, 2003 | 03:58 PM
its2slo's Avatar
you should send them out for a cleaning. just when i get cocky im wrong he he.
wafoogalla
Nov 2, 2016 11:02 AM
daddio
Aug 9, 2015 07:17 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
shisha1999
Jul 13, 2015 11:09 PM
