- Rough Start Up
- Turn Signal Troubleshoot
- Need Locations for 1997 4runner Cat and back O2
- Sleeve Yoke lost it's freeze plug, how would you replace it?
- That little spot under the cig. lighter, I found the solution!
- Trekmaster shock harsher w use?
- squeaky squeak under carriage
- Problems with the windows
- Fuel Injector Experience.
- 3RZ threw rod at 150k - Need replacement Engine
- newb tranny swap - with a question
- Change your spark plugs every 30k
- "Cylinder 4 Misfire"
- good write up on timing belt on 3.4?
- 1st Gen Supercharger Question
- 4runner a/c fan no low speed
- Rear Diff Question
- Need help diagnosing noises
- 3.4L TPS not registering 100% throttle
- Do body parts for 95-00 parts fit on a 01?
- ATF - To Flush or Not to Flush. That is the question.
- 97 Runner 3.4 Runs rough
- slider question
- NY emission problem
- frnt end out of align?
- Grill Trim problem.
- Head gasket replacement question
- 1996 4Runner making strange noise(s)
- Newbie Hello
- ARB bumper help (not your typical what do I cut off thread)
- 3rd Gen Transfer Case - are they interchangeable? Auto to manual?
- 2WD A340E Question?
- AT cooling: Here's what I've got, how would you do it?
- Rough Idle - But Inconsistent
- 5VZ-FE... What is the best Intake??
- Sonoran steel 1.2 install problem
- Weird Jerk/Thump 04 Tacoma.
- Do Tacoma and 4runner Hitch Receivers Interchange?
- 04 tacoma rides kinda rough
- 1997 Power lock/window fuse or relay location?
- Here's the game plan! Thoughts?
- Rear Window
- Replacement for Securikey Alarm
- 2nd gen axle in a 3rd gen?
- Coolant leak help - 2000 4Runner 3.4l
- CB Install/antenna tuning Issues
- Died at stop sign.......?
- Starter problem with my 98 Tacoma
- push button 4Hi testing
- Rear Axles bent!!!!! HELP!!!!!
- Need advice on the right seat belt
- rough idle like misfire (but no codes)
- Race Runner coilover rebuild
- extended front sway bar links??
- power brakes/ power steering problem
- got this for 4500 bucks: 97 4runner Limited
- Replace engine on 99 4Runner
- Front Brake Rotor & Rear Drum
- 2000 4Runner Radiator Swap
- 5vzFE noise
- I got a great deal on a Taco!
- Fabtech sway bar set up???
- fab tech dirt logic 2.5 on my 04 tacoma
- Back From My Land Rover Affair With A Few Questions About My New 4runner
- 1998 4Runner parts interchange question
- Recommend a shop in/near Las Vegas to rebuild my 5VZ-FE
- Looking at aux/bypassed transmission cooler
- Need Part Number/Help!
- Once again, 3.4L Engine Noise
- Overheat but not!? 98 2.4 2WD Tacoma
- 99 4Runner Auto Passenger Window issues?
- Maintenance question
- 3RZ-FE occasional stalling on start up?
- New '02 T4R Sport 4x4 - have questions
- Trekmaster and OME 880/906
- Another "Locked up" caliper question
- 96 4Runner Erratic A/C Problem
- 99 4Runner Shaking!!
- 96 EFI 3.4 temp sensor locations?
- P0171 Code ??
- Rear Control Arm Mount Skids
- Rotted Rear End
- Removing 99 4wd auto trans
- Axle shaft bearing?
- Help troubleshooting idle issue....
- O2 sensor whoops! Need help
- 5vz-fe oil and cooling fluid diagram
- Advance auto rear 99 springs
- Help! Front driveshaft needed today. Phoenix
- OBX Headers on 1997 4Runner 3.4L
- torque droid app.
- 96 3.4 4Runner white smoke on start up
- Timing Belt Kit - Amazon - thoughts?
- I need your opinion on these!
- Non-gen3 4runner front seats: Retrofit?
- Rattling under acceleration
- 01 4runner 3 inch lift too much sway
- Rear Shock Stud size
- 3.4L Transfer Case Drain Hole CRACK
- Throttle Body A/T vs. M/T
- 3RZ Alpine/TRD Supercharger!
- Buying a '00 T4R - Does this intake look right?
- 3rd Gen low profile sleeper platform and cargo drawers
- 23mpg! 45hrs straight driving, 2245mi!
- 99 4runner hard time starting and dieing out on road on fly
- P0120 and P0755 High rev on 1st gear 99 4runner 2.7
- 3rd Gen Steering Wheel Swap
- Axle ID problems
- Oxygen sensor gone bad?
- Front Pass. Side Turn Signal Not Working - Replaced Bulb
- Removed front seat, trouble getting it in
- 1998 4Runner Cargo Door stuck
- 2001 Tacoma w/ Supercharger.....Help!?
- I need help with Lockright Locker
- Sticky door switches
- Making A Sleeper?
- Supercharger Fuel Question
- Dead rear hatch/keyless entry problem solved!!
- Need help finishing manual hub swap
- spark plugs i can get locally for a trd supercharged 3.4?
- Engine will not stay on after being cranked
- erratic shifting
- Can someone with a supercharger measure something for me?
- Strange electrical problem
- Help with Lockright Locker 1620
- 3.4 with no Fuel Pressure Regulator vacuum
- 2wd Automatic Capabilities?
- Toytec Coilover settling/sag
- Possibly a stupid question regarding spark plugs...
- 1997 4runner rear interior light not working with lift gate
- Truck won't start - testing distributor
- Locker Installation question!
- RIP Blackness 1999-2011
- How Many Miles on Your 3rd Gen 4runner Timing Belt?
- Misfire worse after new wires
- P0420 and p0171 code please help!!
- 96 4runner muffler
- Tacoma/4runner 2wd Auto Tranny Question
- Update
- Digital Climate control issues
- Transfer case bearing shot???
- Body color
- Turn Signal Problems
- 1998 SR5 Blower Motor Noise
- What are the part numbers for these 2 pieces?
- What year 4runner gave you the strawberry milkshake?
- OME 880 and 906 with Bilstein Shocks
- What size rear shocks?
- New to me 2000 Tacoma 4WD Xtra cab SR5
- threw a rod
- axle hub removal
- Adjustable panhard
- 97 4R motor mount replacement
- Alignment Off - What to Check?
- What is the odd looking piece welded to the pipe directly behind the muffler?
- 3.4 overheating
- HELP!! 96 Taco CV Axle will not come out
- 1st Gen TRD Supercharger Rebuild
- Denzo or Matsu's knock sensor???
- Front Passenger Side Jingling
- 4wd Fully-Fabricated Spindles for Taco/Tundra/4Runner Models
- 96-98 4Runner Limited Owners - Headlight question
- Grill and headlights
- How To: DIY Retrofit Elocker Wiring
- Sporadic Temperature Gauge and Engine Stall
- 1999 Tacoma FabTech Lift Question
- Anyone near dallas, fort worth, or Grand Prairie, TX?
- Rear ABS Sensors
- New here, rare 86/01 4Runner
- Rear Wiper, Defroster, inside switch dead, and then the remote problem
- Jarring ride question.
- Summer Project .:Back up sensors on runner:.
- 255/85/16 photos
- Clutch Troubleshooting help
- O2 Sensor lead length
- high milage taco. supercharged?
- Satoshi/PIAA Mod In-Progress!
- Crazy Clutch Problem
- Joined the 3G club - Q' about Coils/Springs/Struts
- U joint lasted a week.
- Finally changed my fuel filter at 110,000...
- Searching for Custom Rear Bumper Builds...
- Rusted Axle Housing write up
- Rusted out rear Axle Housing PICS
- Automatic Up Window Switch
- Removing Old Gasket Material
- New bumper - What to do with washer resv and other trim work..
- Preparing a New OEM Rear Bumper ?
- Rusted Shock mount...Ideas??
- SS1.2A & toytec Ult. pricepoint/performance
- Just installed S/C problems, wildly erratic idle
- aftermarket tranny cooler temp gauge install
- ABS Light, Worst Case Scenario (Cost-Wise)?
- Doors Wont Lock!
- 275K and finally throws frst "code"
- 1998 4runner ltd 4wd with noisy tranny
- How many quarts in trans after flush?
- cooling problem
- Water Temp Gauge Sensor Part #?
- Big 3 Upgrade on 97 4Runner Questions
- Exhaust bolts and bolting problem
- Death or Resurrection?
- Steering Tight & Won't Return To Center
- 97 4runner loud throttle
- Is my LSPV broken?
- Engine swap info needed
- HELP Rear Diff ARB problems
- Replace Suspension Bushings...worth it?
- 3rz engine interchange
- New or salvage calipers?
- Stock Bumpers
- 3 RZ operating temperature
- Engine Knock 3.4L V6
- U Joint ?'s
- What shocks do I need?
- 97 4runner suspension popping
- Corner Light Bulb Blown
- Any ways to repair an A/C line with a small crack in it?
- 98 5vzfe no fuel pressure after hg
- 99 4runner front diff seal Help
- Muffler and tailpipe Replacement-Walker
- URD 7th injector 911
- Tapping Cranking Noise in Rear
- Car wont start after job at the shop
- Help with replacing a clutch in a 97 4Runner
- Monroe Quick-Strut 171351 for my '02 Limited 4Runner
- Boom! I had a tire blowout
- New (to me) 2000 4Runner, what maintenance would you recommend
- Help figuring out Axle type & Ratio
- Will this TRD Supercharger work?
- Replaced Tumbler, Won't Start
- 02 4Runner Will Not start!!
- Need help! Oil milkshake! even after new headgaskets.
- daystar 4runner tacoma bushings
- Frame end modifications for winch bumper
- High RPM Vibration
- Electrical Issues after Gutting 4runner.
- Throwing a P0135 code
- Are all Hood Scoop Bulge Assemblies the Same?
- Exhaust Out location
- Tire size help
- Complete Strut Installation Question
- Rear Axle Assembly Questions
- Replacing my worn out suspension not lifting 01 4Runner
- Steering wheel off center after ball joint replacement.
- 2nd gen s/c confusion
- My story 01 4unner
- Sick of drowning. Went and built myself a snorkel!
- ome run3/1.5" adapters 33s still rub
- Your sunroof expertise, please.
