Rattling under acceleration
Old Jun 1, 2011 | 09:02 PM
wormhole's Avatar
Under acceleration I have a rattling noise coming from somewhere under my car and the pitch of the rattle varies (sometimes its louder than others). Once the cruise control is set the noise goes away or more less can still be heard slightly but once you give it gas it's back.
It does not make this at idle.
I originally thought the exhaust was loose but it has to play to it.
Any ideas what it might be.
Old Jun 2, 2011 | 05:05 AM
Bighead's Avatar
The last time I had a similar problem it was my exhaust hitting the body near the spare tire location...basically right under the cargo area. The rubber part on the rear-most exhaust hanger had shifted when I drug my exhaust coming off a rock ledge. I had to rotate the rubber part and tweak that exhaust hanger a bit with a pry-bar to get some clearance between the pipe and the body to get rid of my noise.
Old Jun 2, 2011 | 05:07 AM
waskillywabbit's Avatar
Might be a busted cat.
:wabbit2:
Old Jun 2, 2011 | 05:36 AM
WestEnd's Avatar
definitely... catalytic converter issue... or maybe the vibration dampener in front of the muffler is missing?? (my 4 runner made that same noise after I changed out the exhaust and didn't put the vibration dampener back on...)
Old Jun 2, 2011 | 06:03 AM
tj884Rdlx's Avatar
Can you get someone to fluctuate the gas pedal while you get underneath the truck? maybe someone can get the vibration to occur while you're under there. then you can poke at some parts with a screwdriver and see if you can isolate the sound. i usually check for the heat shields at the cat and manifold first.
Old Jun 2, 2011 | 06:32 AM
TheDurk's Avatar
Yeah, I've had to replace several heat shield bolts (I have two cats). They just disappear.
Old Jun 2, 2011 | 04:28 PM
wormhole's Avatar
That's what I originally thought when I did the same thing in the San Rafell Swell but I had that all fixed up a few months ago but the problem didn't go away.
It doesn't do it at idle; you can hit the gas all you want but it doesn't do it. It's only when moving.
Old Jun 2, 2011 | 05:30 PM
wormhole's Avatar
Video, hopefully, you can hear the rattle
http://www.youtube.com/watch?v=hX8-AAvpGc4
Old Jun 5, 2011 | 08:22 PM
PitbullRescuer's Avatar
If it's only while moving would bet it's a slightly bent or twisted somewhere exhaust.
ashamsuddin
17
Jul 22, 2024 03:59 AM
gibbonsballer10
Oct 26, 2023 07:13 AM
zytra
Jan 24, 2019 03:16 PM
Corvoid
Dec 11, 2015 11:21 AM
Flightguy
Oct 2, 2015 05:34 PM
