Throttle Body A/T vs. M/T
Old Jun 1, 2011 | 10:51 AM
1996Tacoma's Avatar
Hello,
I am purchasing a new throttle body for my 1996 Tacoma as mine is worn out.
From viewing this website: http://www.woodfins.com/Parts/1996-T...le%20Body.html
It looks like you can order an a/t or m/t throttle body. I was unaware that there was any differences?
Is every 5VZFE throttle body the same for the same year?
Thankyou
Old Jun 1, 2011 | 03:52 PM
swampfox's Avatar
If I remember right the m/t has a dash pot on it and the a/t doesn't.
Old Jun 2, 2011 | 08:29 AM
TheDurk's Avatar
That's interesting. My stock 5sp TB has the dashpot, but also has the empty third cable wheel for the A/T kickdown which is obviously not needed.
Old Jun 2, 2011 | 09:15 AM
coastal runner's Avatar
wait... toyota parts wear out?
Old Jun 2, 2011 | 09:19 AM
1996Tacoma's Avatar
haha.. unfortunately my butterfly valve has a gap from the cylinder bore allowing extra air thru increasing my idle. Yep I guess metal on metal does wear out eventually even if it is yota!
Old Jun 2, 2011 | 09:39 AM
4x4climber's Avatar
guess it's time to rebuild, bore it and get a bigger flapper... =D
Old Jun 2, 2011 | 09:43 AM
thats an interesting idea. idk about the 3.4s, but on my 3.0 TB theres an idle adjustment scew. maybe you could turn yours down and save some $money$
Old Jun 3, 2011 | 02:45 PM
turbo8's Avatar
I made the mistake of cleaning my TB, which caused it to idle high.
I fixed it by filling the gap in my throttle body with high temp silicone.
Old Jun 3, 2011 | 02:49 PM
1996Tacoma's Avatar
turbo8 sometimes the high idle after tb cleaning is caused by all the junk and cleaner running down into your IAC which is underneith the TB. Thanks for the high temp silicone tip. Do you see any problem with the silicone wearing off and going in to the engine?
I am getting another TB from the wreck yard for $60. Hopefully that should fix it.
Old Jun 3, 2011 | 07:38 PM
turbo8's Avatar
I tried all the tricks to fix it, including a new IAC. Silicone can't be worse than the gunk build up that was already in there.
Jun 1, 2021 01:51 PM
Blamalam
Aug 16, 2015 12:29 PM
mtc1105
Aug 4, 2015 08:06 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
