threw a rod
Old May 17, 2011 | 06:41 PM
jdl25's Avatar
threw a rod
New here and what a great forum! A wealth of information for sure.
I threw a rod in my 2003 V6 4x4 Tacoma. My block took a good lick and I feel it is beyond repair. I have a good engine out of a 96 4Runner. I want to replace all the gaskets and will pick the best heads, and manifolds to use out of the two engines. I think I will use my throttle body.
Question...why do the "complete engine overhaul gasket sets" have different part numbers? Do I need a 96 or an 03? More than likely I will only use the block from the 96 because my heads look great as well as all other components. I will have a machine shop check them and possibly resurface them for the new head gaskets it will get.
Again great forum here, Ive been reading for a long time and realize this is the place to ask.
Thanks
Old May 17, 2011 | 06:54 PM
DeathCougar's Avatar
The long blocks are exactly the same. I would use the gasket set from the 2003, since you will be using your Intake. wiring, injectors, and exhaust from the '03.
Whatever you do, do NOT use the intake/wiring/exhaust/injectors from the 96. You will have nothing but problems.
Old May 17, 2011 | 08:16 PM
jdl25's Avatar
sounds like a plan thank you for the response. Will the dealership gasket set supply a MLS head gasket?
Old May 17, 2011 | 08:57 PM
jdl25's Avatar
Some pictures... I change my oil every 4 to 5k miles with Pennzoil 5w30 yellow bottle. Truck has 125k miles, I put the last 75k miles on it. Ran like top until the failure never a minutes problem.
My heads
My least favorite rod
Old May 17, 2011 | 09:04 PM
jdl25's Avatar
Looks like I uploaded pictures of the same head twicebut you get the idea...
Old May 18, 2011 | 11:28 AM
tunnelmotor99's Avatar
Damn, that sucks man. I haven't seen carnage like that since we did the "cash for clunkers" blowups at the dealer...now THAT was fun!
Old May 20, 2011 | 05:15 PM
Texas_Ace's Avatar
Wow, don't think i have seena rod shatter like that before.
Old May 20, 2011 | 06:15 PM
skoti89's Avatar
welcome to yota tech, sorry it was under those circumstances.
And what the hell were you doing to brake a rod that bad? lol
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
primordialbeast117
Dec 19, 2015 12:23 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
