Rear ABS Sensors
Old May 13, 2011 | 06:17 AM
scrpydoo8's Avatar
Rear ABS Sensors
Installing a new rear axle assembly and was wondering about the rear ABS Sensors on a 4Runner. Is there any certain way they are supposed to come out, they have a bolt in them that i have taken out but i can't seem to pry them out after the bolt is removed. I don't want to damage them trying to pry them out.
Any wise words from anyone?
If I can't get them out i might just cut the wire and splice in the extra set that came with my axle.
Old May 13, 2011 | 06:47 AM
Nelsonmd's Avatar
Yeah, they get really stuck in there. The sensor body is round, so you can hit the spot where the bolt goes in to spin it a little bit, just to break it loose, then you have to press it out. I used a socket and a big C clamp to press mine out. It wasn't easy, but it eventually worked.
I wouldn't cut the wires. It can be pressed out with about $15 worth of tools you probably already have.
Old May 13, 2011 | 07:33 AM
scrpydoo8's Avatar
Cool, thanks!
Old May 13, 2011 | 09:01 AM
Nelsonmd's Avatar
The best thing might be to use a socket just under the size of the ABS body on the inside, then use a really big one on the outside (like a 36mm or similar) that will fit around the bask side of the sensor. I didn't have a 36mm at the time I did mine, but after swapping my steering rack bushings, I do.
How far along the swap are you?
sandyota
Feb 4, 2021 11:16 AM
88yodabasket
Jul 13, 2015 01:32 PM
87turboPA
Jul 12, 2015 07:49 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
