2WD A340E Question?
Old Jun 20, 2011 | 12:36 AM
traxxi2003's Avatar
Exclamation 2WD A340E Question?
Can some tell me, Is there a bushing or bearing on the A340E tail housing behind the tail housing oil seal? I have what appears to be a drive-line vibration and the only thing I have not ck or replaced is the transmission. After new U-joints, new gears the vibration still there. It only happens while coasting or slowing down. I was thinking, either, I have a worn out driveshaft slip yoke or a bad transmission output shaft. There is some play on the drive shaft slip yoke while inside the trans. I would say about 1/16th" +-. Is this play normal? Or it should not be any play at all?
4x4-runner
Apr 18, 2017 09:08 PM
landrunner
Aug 5, 2015 09:18 PM
makemusic116
Aug 2, 2015 05:23 PM
colasurdo
Jul 16, 2015 11:32 AM
hexrain
Jul 12, 2015 01:13 PM
