High RPM Vibration
Old Apr 24, 2011 | 10:06 PM
NwRunner's Avatar
High RPM Vibration
1999 3.4 Auto 4Runner. 50k on Engine, 200k on everything else.
I am getting nasty RPM based front end vibration that starts at 3.5k and gets progressively worse until it peaks at 4.5-4.7K then it usually shifts. I just swapped a new motor in and everything seems to be secure. Motor mounts and exhaust are all tight, and i marked every bolt on the flexplate/spacers so the weight should be dead on.
I just took it out and the vibration was so bad that it started to rattle the dash before it downshifted. Its pretty much narrowed down to flexplate for me, but i pulled the cover and everything looks fine... help!
Old Apr 24, 2011 | 10:09 PM
vital22re's Avatar
totally a bro
did you pull the drive shaft? have you checked the u joints? put it up on jack stands and i'll come over and watch the driveline spin.
Old Apr 26, 2011 | 01:15 AM
NwRunner's Avatar
Turns out it was an out of balance fan??
It blew up today, atleast i know what the problem was!
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
