Need help finishing manual hub swap
Old May 26, 2011 | 05:57 PM
pkt1213's Avatar
Well first off. Until I get everthing can I still drive my truck, just bolt the hubs on without using the 4wd. Leave on the spacer, snap rings ext. Just bolt the hub body and cover up.
I also need some part numbers cause toyota here drives me crazy sometimes.
Snap ring x 2
Both gaskets x 2
Bolt/washer that go in the end of the CV shaft x 1
Or if someone on here has all these available
I was trying to find some pics of a 3rd gen manual hub swap and I can't seem to find any. I seems like there are 2 pieces that look like the spacer, I'm assuming is the washer that matches the splines. One of them is on what would be the outside of the hub body. I want to make sure this is right also.
I also now have 2 good CVs and auto hubs for sale.
Old May 27, 2011 | 12:26 AM
fishingorwishing's Avatar
Noticed you have a sonoran steel lift did you look up their mannual hub write-up on there site?
Old May 27, 2011 | 06:55 AM
pkt1213's Avatar
yeah. I found the part numbers except for the bolt that goes in the end.
Old May 27, 2011 | 07:24 PM
crolison's Avatar
Don't need the bolt in the end, just need the snap rings
Old May 28, 2011 | 07:28 AM
team_gforce's Avatar
http://www.toyotapartseast.com/compo...-03-11939.html
i am at the same stages of wrapping up the project
Old Nov 6, 2014 | 04:33 PM
pollaccia's Avatar
Parts needed for manual hub swap
Hi, I hope I am posting this right. I have a 1996 Tacoma, 3.4 liter 4wd. It has the ADD and no ABS. I want to install manual locking hubs. I have the bearings, spacers, inner and outer seals, and the hub's, non ADD. Thanks in advance Do I just use the stock CV axles for the 1996 Tacoma with out add, and is there any gearing that needs to be changed? I
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
deepmarsh
Aug 6, 2015 03:44 AM
KBar
Jul 13, 2015 06:01 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
ItsJustD
Jul 7, 2015 07:49 AM
