- some new pics with 1 inch body lift
- 2.4L oil level question
- OME/spacer combo lift & 1" BL installed *pics*
- Flat Towing '99 4Runner
- Rear Window Rolling Down With Key
- Another TRD SC Question
- Where to buy Tokico TrekMaster Shocks?
- revtek lift on 265/75/R16
- 3rdGen Slider Build-up :)
- A/T Fluid Loss on 98 4Runner
- Something new at URD
- Billstein question
- Urgent Help Needed...Spark Plug
- Tundra setup with a winch = a lot of rake...suggestions?
- Thats disgusting!!!!!
- PICS: 2000 Tacoma mini build-up
- Radiator Leaking
- stall speed of stock A340?
- Air suspension
- Want to remove running boards - No where to buy mud flaps
- It's Supercharger time!
- 4cyl Fuel Filter
- A/C duct Problem
- Can't Afford Tundra brakes... Upgrade to bigger?
- How do I replace an upper ball joint boot on 3rd gen?
- Why didn't I get a manual tranny?
- condenser cooling
- what can i do for a smoother ride??
- Looking for a 97-01 4Runner, I think
- California Law about turn signal lights
- P0 420 Oxygen Sensor Before or After Cat???
- Seats
- What is this wire for?
- How much lift w/landCruiser springs?
- Infrared Themometers
- rough idle after warm up
- Upgrading my sound system (subwoofer)
- Headlight conversion
- split second products
- Hi-Flow Catalitic Convertors?
- No power from trailer harness on '00 4Runner SR5
- New brakes don't stop as well as old...any ideas?
- Front brake stopped working, dealer quoted $2500 to fix
- u joint replacement questions
- both passenger windows and front passenger window have stopped working
- New product announcement. Manual control for your automatic transmission.
- temporary window fix for tapping noise---permanent solution?
- cat vs budbuilt skid
- outside temperature sensor
- 97 4Runner - 166K Miles - What to look for?
- bolt snapped?
- Dash Rattle...
- Help with Wet Okole Headrest Covers
- How often and how to change oxygen sensor on 96 4Runner?
- Brake lines...
- Steering Wheel Removal - '98 4Runner
- Hard start when engine warm/hot (long/detailed)
- possible 99 to 98 center radio console retrofit
- Abs
- Clockspring or Spiral Cable?
- 4Runner 3.4L at 150K miles.. what to refresh?
- pro comp SS brake lines for taco?
- @#$#@ Timing Belt install (3.4L)
- Request for Information: Downey Adj Coil Overs?
- isr mod: would pvc pipe melt?
- Bank 1: PO420 vs. PO430 > Defect
- 4Runner + Motorcycle hauler
- Best Soft Ride Lift?
- Took the door off my 3rd gen.
- A/C pressure switch location
- Torque specs on oil drain plug: 5VZ-FE 3.4L V6
- Broken Wires In Steering Column
- TRD Supercharger question?
- 9psi Supercharger pulley for TRD 3.4L Supercharger - brand new -
- '00 3.4 How many teeth ...
- Radio Works... but no power???
- So i got a bad feeling in the depth of my heart (window problem)
- A/C blowing uncooled air
- Catalytic Converter Replacement
- Calling HID Experts...
- Wheel Travel Facts?
- Stock Exhaust Pipe Size 3rd gen
- Clutch pedal gets stuck!!!
- How do I get the crankshaft pulley bolt to the correct torque?
- How do I keep floor jack from interfering with jack stand placement?
- Finally cleaned my skidplate PIX
- Driver Door Dorked by Wind Gust
- ISR mod 3rd gen - NEED HELP PLEASE!!
- I've got a 3 prong power cord in my engine compartment?????
- What's ytour average 21' skiboat weigh with trailer?
- Oil Change Advice
- Swapping a 3.4L into a 2.7L/3RZ - Is it worth it?
- help me find a strange cargo rack
- 3RZ Headers
- Installed '05 Tacoma "TRD" Decals to my '02 4Runner *PICS*
- 4runner starter remove removing removal replace replacing - contacts - tips & how to
- Crankshaft bolt felt out -- bye bye crankshaft
- My Alignment Saga and Thanks
- lower ball joint
- will sway bar help with wheel stuffing?
- Rear light help.
- Are AirLift bags trail worthy?
- bed mounting question
- Looking for ideas on new pedal pads
- 3rd Gen Strobe Video
- Carpet and pad WET under Husky mat!!
- 3rd Gen 4Rnr Rear Brake Proportion & Pressure
- Powertraxx Noslip Locker in 3rd Gens
- Land Cruiser coils installed with pics!
- Bought my first 3rd gen!
- Funny Sell - Not sure where from
- My 2000 4Runner w/ HID light ****pic***
- Anyone got Flowmaster 40 series?
- Cost to fill up your Tacoma's fuel tank?
- Sagging leafs
- Cost effective code reader ???
- Clicking when a/c is on
- Rotor / Wheel Clearance for 95.5-04 Taco
- Cheap Laptop Mount
- burning tranny
- Crank pulley holding tool
- Crank pulley wobble?
- Does anyone have experience with Powertraxx
- Clutch/ MC Woes
- My Turn...Engine bay and Amp pics
- Look at my new shoes...
- Replacement Catalytic Converter
- detailing question
- Location for Escort Passport
- Help diagnosing P0401 Trouble Code, VSV?
- RPM sweet spot for gas milage
- best price on oem pads TUNDRA
- 95 4runner water leaking behind intake ???
- 4x4 wont engage
- rattle somewhere inside the steering?
- Ivan Stewart TRD Wheels
- Need Pic of Center Cap for '99 4Runner Rim
- 3rd Gen 4R wheel lug nut torque specs
- Can I adjust my clutch?
- Mudflaps for D-cab
- Bug deflector causes massive rubbing
- Tansfer case output seal help!!
- What are some possible reasons for a bumpy ride?
- Tacoma Overload Leaf Tossed?
- V6 EGT Probe Location
- click/clunk coming from front right side when backing up ONLY
- Hard rad hoses
- 3.4L conversion won't start!
- Nicely Modded 4R on eBay for $5K - Seems Like A Steal
- URD kit thermostat question
- which shocks are the smoothest!! HELP
- Timing belt change - Is our motor an interference or non-interference?
- Vent selector switch not working
- Boost Dynos
- 4Runner chip help?
- Transmission flush, lubegard ?
- Alignment issues with my GF's Tacoma...
- 3rd gen T-shirts
- tire problem
- 285/75/R16 BFG MT's on a 96 4Runner
- feeler for a 99 4runner grill $$$$
- A/C idle
- 3rd Gen 4Runner the best SUV for me?
- Anyone know if... running boards????
- Towing with a 1997
- my issues with overheating
- Strut Replacement - 96 4Runner
- CD player wiring harness
- Any 3rd Gens with a Full Size Roof Rack?
- any 3rd gen w/ HID lighting?
- Suspension issue? Do I need new coils/springs?
- 16x10's on the 4Runner
- 90k tune up worth it?
- wheel spacers recommendations? Yay or nay??
- hood
- Wrecked 4runner w/TJM
- Spare Tire solutions?
- 1998 4 runner limited skippe CD player
- Engine light coming on, then off, then on again...
- Help with CD player
- Fitch Fuel Catalyst?
- Fatty Fender Flare Mud Flaps (Pics)
- Radio Help!!!!
- Check engine light on '00 4Runner SR5?
- A340F or 30-40LE question
- How to check 3.4 tps?
- salvaged elocker and axle housing
- Coolant/Overheat problem, HELP!!!
- SR5 fender flare questions
- CB Install
- Quarter mile time for 97 tacoma
- Transmission cooler install without taking out grill
- Stuck fuel guage
- No Headlights
- NHTSA Defects Investigation - NHTSA Website
- Adobe files for Urd install??
- taco 4x4 ingage problem
- Just mounted my tranny cooler (pics)
- Wheel and Tire Opinions for Taco's.
- Can those of you with LX450 16x8's post pics of your rig?
- Steering wheels gets stuck
- Okay... Need Advice on a Street Queen Build Up
- Clutch hard to press?
- Finally can't stand it anymore - the clock doesn't work!
- Exhaust Questions for My 04 3.4 Tacoma
- Lifting an 04 Double Cab Prerunner 2WD
- 97 3.4 stalling at stop lights--problem solved
- Fuel smell
- Will 285 75 16 fit?
- Grip Force Disc Brakes?
- Looking for pics with TJM bumper and Limited flares
- Clutch goes squeak, squeak, squeak like a hamster wheel
- need opinions on ventvisors?? what do u have?
- What's the best price on TRD headers?
- front running lights and dash lights
- Rear diff ?
- 96 tacoma supercharger
- Just bought a scooped hood
- which year is the most DESIRED??
- TRD e-locker 04 taco to 96 runner swap
- Upper Ball joint mystery? PLEASE HELP!
- CA Smog Issues - 95 Tacoma
- Q replacing O2 sensors. (Replace both?)
- fiberglass plate to hold ipod in cubby hole above cupholders
- Rear liners that cover rear seat also...
- Timing belt on '00 4Runner SR5?
- new stiffer coil springs vs. coil spring spacers
- what kind of batteries in your 3rd gen
- Lift and other work is done.
- How to restore faded aluminum?
- Clear corners and bumper lights
- Concern about bigger tires
- Please help me I am at a loss, My 4Runner bogs
- East Coast Fabricator?
- What is the deal with the wheel bearings 96 Taco ADD?
- Cleaned engine, now it idles badly
- Turbo Tacoma... Need help!!
- gel light covers
- I changed my 5 speed dope... have a ?
- used trd exhaust
- Intake and Throttle Body Upgrades
- Hesitation at 2500-3500 rpm?
- Help with 2004 Tacoma 2.4L plug change
- took off running boards
- Post your MPG gains after removing your aftermarket roof racks
- What is this on my windshield
- Trying to replace my o2 sensor
- Cost for retractable antenna
