A340F or 30-40LE question
Old Jun 17, 2006 | 05:40 PM
mt_goat's Avatar
Do I have a A340F or a 30-40LE or are there 2 tranny numbers for the same transmission? It's in a 2001 Tacoma 4x4 V6 with auto tranny.
I'm pulling the valve body out to send to John @ IPT and the FSM drawings of the VB bolts don't match what I have. So I looked at the model # on the tranny and it says 30-40LE.
Old Jul 5, 2006 | 02:54 AM
BrettM's Avatar
I'm fairly certain they are one and the same. The AW4 found in a couple million Jeep Cherokees is also labeled 30-40LE on the transmission.
Old Jul 5, 2006 | 03:54 AM
mt_goat's Avatar
Oh that's interesting. I still can't find a Toyota FSM that has this 30-40LE in it. Maybe I should try a jeep FSM
Old Jan 5, 2009 | 06:20 AM
Gato Richy's Avatar
a340f and 30-40le are the same.
Old Jan 5, 2009 | 07:20 AM
mrdoug's Avatar
Hey Dale, I found a post over on Pirate when looking for some info on my auto-tranny... it might be of some help to you http://www.pirate4x4.com/forum/showthread.php?t=587521
Old Jan 5, 2009 | 07:32 AM
97ltd4x4's Avatar
Look at the sticker in the drivers door jam.It will have the trans number,and diff code...
Will look like this
A/T:........-........
Old Jan 5, 2009 | 08:07 AM
mt_goat's Avatar
Thanks Doug, that is a good link.
Thanks LTD, but I sold that door jam about 2 years ago along with the rest of the cab. All I have now is the engine, ECU and tranny.
Thanks for the confirmation Richy, even if it is 2.5 years later
Old Jan 5, 2009 | 01:14 PM
dairyjato's Avatar
the F stands for 4wd i found an E for a $100 and did some searching only to find i couldn't use it. i have a 4wd and the tranny was out of a 2wd
Old Jan 6, 2009 | 04:53 AM
Gato Richy's Avatar
E into and F
You're right, in my case I found and E and made it F. The core are the same except for output axle, so I changed the axle.
Old Jan 6, 2009 | 07:10 AM
mrdoug's Avatar
HAHAHA.. I didn't even notice the date on the original post when I replied.
hawks7106
Diesel Swaps
May 16, 2016 05:44 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
