Dash Rattle...
Old Jul 4, 2006 | 05:35 AM
KyleT's Avatar
Dash Rattle...
I have a dash rattle in the passenger side somewhere behind the glove box and the airbag. i cannot see or feel anything that is loose, i have already cleared out the glovebox thinking that was causing it, it sounds like hard plastic wacking metal. it has been getting worse lately too.
any suggestions to where i should continue to look would be greatly appreciated.
Thankyou,
Kyle
Old Jul 4, 2006 | 06:16 AM
Godzilla's Avatar
http://www.customtacos.com/tech/file...rattle_tsb.pdf
https://www.yotatech.com/forums/show...ise+tsb+tacoma
Heres some helpful reading. It was tsb's for the taco's but im sure it can help with the runners
Old Jul 4, 2006 | 06:34 AM
DOT3's Avatar
If you have a handbrake on the center console, check for slack in the cable by slightly pulling up the handbrake when the noise is present. My cable was resonating because it was loose. Sounded like something around the airbag.
Old Jul 5, 2006 | 08:45 AM
taikowaza's Avatar
passenger side dash rattle
I have the same issue in my 2nd gen- dash rattle, behind glove box.
I have tightened all screws that I can find, taken everything out of the box...
are there any other possibilities? there is nothing worse than listening to that rattle all the time...are there any damping fixes without taking the whole dash out?
Old Jul 5, 2006 | 09:03 AM
Buck01's Avatar
Do either of you have a BL?
If so check the brake lines in the engine compartment.
When I lifted mine the plastic clip holding the lines to the firewall broke and caused a rattle that sounded like it was behind the glove box.
good luck
Old Jul 5, 2006 | 06:23 PM
KyleT's Avatar
nope no BL and holding the handbrake doesnt do anything.
Old Jul 5, 2006 | 08:25 PM
Godzilla's Avatar
does it happen just over bumps? or when you hit a hard part in the road (like a split). Is it like a sharp tap? I had a noise kinda similair and what i did to cure it was with 3, 1inch pieces of that weatherstripping type foam. I placed it between the plastic front defrost section and the window. One at each side and one in the middle. It may have been the clips that hold that seperate section down or it was tappin the glass..either or it worked.
Old Jul 5, 2006 | 08:52 PM
KyleT's Avatar
its a hard rattle. like "dat dat dat..." over harsh bumps. its not a vibration, my brother was listening close today and he said it sounds like metal on metal. all i know is that it is loud and annoying now. it has gotten worse the past week. im going to i guess take the glove box door off and see if i can see anything up there that might be loose, im hoping that it isnt behind the ac blower and stuff.
Old Jul 5, 2006 | 08:55 PM
Godzilla's Avatar
ya try the foam first.. the noise i had was for sure a "DAT"..another way to do it is to pop off the center console area to access the cd player and such..you have a good visual with a flashlight from there to some components above/behind the glove box.
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Jdgarrison
Oct 1, 2015 05:22 PM
toyotasaurus
Sep 24, 2015 03:30 PM
