Rear light help.
Old Jun 27, 2006 | 02:55 PM
lanai's Avatar
Rear light help.
My tail and brake light on both sides dont go on. I checked the bulbs (left side only) and they look okay.
The third brake light on the roof, the reverse light, and the turn signal is working okay.
I looked at the fuse and I cant tell if it is good or bad.
Thanks
Alex
Old Jun 27, 2006 | 03:06 PM
BajaRunner's Avatar
Just replace the bulbs. Guarentee thats your problem
Old Jun 27, 2006 | 06:01 PM
Elton's Avatar
replace the fuses and the bulbs and see if that works
Old Jun 27, 2006 | 10:19 PM
bigacuralvr's Avatar
or replace the fuse first..beings that it is pretty rare that both tails would go out at the same time....
Brett
Old Jun 28, 2006 | 03:41 AM
Rick F.'s Avatar
From: Far western Kentucky (transplanted from central PA)
An inexpensive continuity tester would answer a lot of questions here, as would a VOM to check for voltage at the sockets...
Old Jun 28, 2006 | 08:00 AM
Ringmaster's Avatar
Exactly, a fuse can look good, but sometimes they will break at one end and you'll never see the problem. Same with bulbs.
Old Jun 29, 2006 | 11:30 AM
lanai's Avatar
I changed the fuse and all the bulbs and everythings okay now.
Thanks for your help guys.
Old Jun 29, 2006 | 11:40 AM
Elton's Avatar
good to here it was a easy fix and not a short somewhere
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
bryan34w
Jul 6, 2015 05:53 PM
