Rear light help.
My tail and brake light on both sides dont go on. I checked the bulbs (left side only) and they look okay.
The third brake light on the roof, the reverse light, and the turn signal is working okay. I looked at the fuse and I cant tell if it is good or bad. Thanks Alex |
Just replace the bulbs. Guarentee thats your problem :)
replace the fuses and the bulbs and see if that works
or replace the fuse first..beings that it is pretty rare that both tails would go out at the same time....
Brett |
An inexpensive continuity tester would answer a lot of questions here, as would a VOM to check for voltage at the sockets...
I changed the fuse and all the bulbs and everythings okay now.
Thanks for your help guys. |
good to here it was a easy fix and not a short somewhere
