Funny Sell - Not sure where from
Old Jun 26, 2006 | 10:25 PM
chadbobb's Avatar
Funny Smell - Not sure where from
Ok, I have a 3.4l 1996 toyota 4runner with auto transmission. I was at the beach and put was trying to climb a pretty steep sand hill and put it in 4low and started to go up the hill and finally got stuck almost at the top in about 2 feet of soft sand.... but anways I could smell something funny. I went back down the hill and it didn't seem to come from under the hood.
You couldn't really smell it from the outside, or under the hood, but could smell it inside the cab.
Earlyer i drove over some weird hill thing and had it in 4low, and when I was taking it back the transfer case shifter kinda grinded. I don't know if that could have any problem with why it smelt bad. I had plenty of oil and transmission fluid.
Is this normal or do I need to worry about something?
Old Jun 26, 2006 | 10:58 PM
Ringmaster's Avatar
Anyone riding with you?
Old Jun 26, 2006 | 11:00 PM
chadbobb's Avatar
yeah.... what does that mean?
Old Jun 26, 2006 | 11:08 PM
Ringmaster's Avatar
Thought maybe you scared the chit outta someone.
Old Jun 26, 2006 | 11:13 PM
1985 4Runner's Avatar
Old Jun 26, 2006 | 11:15 PM
photoleif's Avatar
hot clutch.
Old Jun 26, 2006 | 11:30 PM
rocket's Avatar
It's normal.
Old Jun 27, 2006 | 01:26 AM
MorphiasX's Avatar
Originally Posted by photoleif
hot clutch.
He stated it was an automatic. Would the torque converter get hot and cause a smell though?
Old Jun 27, 2006 | 04:19 AM
MTL_4runner's Avatar
Might be gear oil, that stuff smells like dog poo when it leaks.
Old Jun 27, 2006 | 05:44 AM
photoleif's Avatar
sure did! doh.
Old Jun 27, 2006 | 08:43 AM
chadbobb's Avatar
so what could it be? i don't think its leaking? is it bad if its leaking gear oil? that doesn't sound normal to me
Old Jun 27, 2006 | 08:56 AM
cootees's Avatar
Sounds like it may be gear oil. Check around the rear pinion seal for leaks. That is a pretty common place for leaks and a cheap & easy fix.
:pat: It is not good if thats what you mean. If you are leaking gear oil then it is something that needs to get fixed right away. I can't really think of anything that it smells like to give you an idea but it stinks. I imagine if it is leaking even just a little then you can smell it pretty well.
Old Jun 27, 2006 | 09:09 AM
chadbobb's Avatar
ok, where is the "rear pinion seal" ?? I am really new to all of this stuff if you can't tell
Old Jun 27, 2006 | 09:24 AM
cootees's Avatar
It's underneath the pinion yoke in your third member. You should be able to get under your rig and tell if it is leaking. To replace it yo uwill need to disconnect the driveshaft and take off the pinion nut which reguires a 30mm(I believe) socket. Then pop the old one out put the new one in. Look all around the rear axle housing and under the body as the gear lube will get thrown all over the place if leaking from the pinion seal.
Old Jun 27, 2006 | 10:22 AM
chadbobb's Avatar
didn't seem like that was the problem... I felt some stuff that seemed like really old grease further up around the transfer case but around the differential it was dry
Old Jun 27, 2006 | 10:27 AM
jct61765's Avatar
Old Jun 27, 2006 | 06:37 PM
chadbobb's Avatar
Any other ideas? Could it have been something other than some type of oil?
Old Jun 27, 2006 | 06:42 PM
Jimmeh's Avatar
Body odor?
Did the smell start after hard acceleration? Did it smell similar to exhaust? Was it a burning smell? Did it smell minerally?
If it smelled like exhaust, and your back window was open, that could be it. If it smelled like burning grease or oil, you could have an oil leak. If it smelled minerally, it could be a coolant leak...well, maybe minerally isn't the right word, but I can't really describe the smell...
Old Jun 28, 2006 | 12:52 PM
chadbobb's Avatar
it didn't really smell like exaust at all... I have smelled the exgaust before, with my back window open, and this wasn't at all the same. This smelt a lot more like a clutch or oil burning. My neighbor said it could have been my torc convertor... is this true?
Old Jun 28, 2006 | 09:35 PM
chadbobb's Avatar
Hmm... today I went back out there, and I tried it again once and got stuck just the before.... so i lowed my street tread tires to 20 psi and tried again... It worked great and plowed right through the sand. Anyways..... after climbing it a few times a realized that it didn't smell bad this time..... seems weird it smelled before but not this time.... Anyone have any new ideas?
