any 3rd gen w/ HID lighting?
Old Jun 19, 2006 | 09:03 PM
profuse007's Avatar
any 3rd gen w/ HID lighting? im ordering some toyota ballast and d2r bulbs for ~150 shipped from ebay.
anyone that retrofitted this, plz give me some tip.
ill use the plate that hold the actual h4 bulb to rebase the d2r bulbs to fit teh housing.
Old Jun 20, 2006 | 05:12 AM
Rock Slide's Avatar
I know there are guys on this board who have done so. You might want to do a quick search for HID on 3rd Gens as well. Here's a couple threads on it that I found when searching:
https://www.yotatech.com/forums/show...HID+Conversion
Post some before and after pics when your finished. Good luck!
Old Jun 20, 2006 | 06:02 AM
ebelen1's Avatar
Iceman also did it. I've seen Iceman's in person and it looks OEM...
Old Jun 20, 2006 | 09:47 AM
profuse007's Avatar
thanks for the search rock slides, but ive seen that in the past and the bi-xenon not a good idea for me due to time and patience. however having the high-beam is pretty critical sometime and ill just have to live w/ a low-beam.
hey ebelen1,
was his setup similar to mine or what?
ill be sure to give some details abotu it w/ pics.
Old Jun 20, 2006 | 11:56 AM
ebelen1's Avatar
hey ebelen1,
Iceman did the retrofit w/ Mercedes parts. I'm not familiar w/ all the terms but he cooked the headlights, pulled them apart and inserted the Mercedes "part" that houses the HID bulbs. PM and find out.
Old Jun 20, 2006 | 12:04 PM
iceman601's Avatar
Yea I have tried the casper shields with the D2R and D2S bulbs and still wasn't happy with light pattern, it still emits some glare. The setup I have now uses E55 Bi-Xenon projectors and Hella Ballast which gives me a clean wide spread pattern with no glare and still have functioning high beams. I can provide some pics of it later if you want.
Old Jun 20, 2006 | 01:00 PM
Rock Slide's Avatar
I've heard guys say the best way to go HID retrofit was w/ Bi-Xenon.
Iceman601, I'd like to see some pics when you get a chance. Maybe some low and high beam shots as well to see the light spread.
I've thought about doing the conversion, but always found another mod to do instead.
Old Jun 20, 2006 | 03:55 PM
KyleT's Avatar
i modified the casper shields, still too much glare. need to do some more tweeking. it will glare like mad with no casper shields.the e55 or any other hid projector setup is the only way to do it safely.
Old Jun 20, 2006 | 07:05 PM
profuse007's Avatar
thanks for the inputs everyone. i was afraid of the flare, too. i will get a friend of mine to help me tune the lighting.
hey kyleT, can you post up some pic of the light pattern of urs?
whats ur setup?
Old Jun 20, 2006 | 08:58 PM
KyleT's Avatar
yeah. here is a kinda bad one, ill try and get a shot against a wall.
it flairs hard to the upper right. __/ __/
Old Jun 21, 2006 | 04:46 PM
iceman601's Avatar
Heres a couple shots of mines...
Low Beam cutoff pattern
High Beam
and the headlights
Old Jun 21, 2006 | 07:33 PM
KyleT's Avatar
iceman you did it the right way. i did it the ghetto way.
kawazx636
Oct 6, 2021 03:03 PM
some drunk guy
Aug 3, 2021 06:09 PM
39 Thieves
Jan 6, 2017 01:08 PM
clok
Nov 19, 2015 01:09 PM
AkitaDog
Sep 1, 2015 08:05 AM
