Driver Door Dorked by Wind Gust
Old Jun 28, 2006 | 06:30 PM
Pipsisiwah's Avatar
As the title states, a strong gust of wind yanked the door out of my hand while I was getting out and jammed it forward - hard!
Now the door is slightly misaligned such that the jamb side raises up slightly upon closing, and upon opening the door feel like it has a spring assist. I looked at the big hinges and the top and bottom ones both show broken paint and are maybe 1/16 inch forward of where they used to be. Past experience tells me once I loosen the hinges the door will drop and I'll probably never get the dang door properly aligned.
Is there a trick or better yet, a procedure to bring the door back to where it was?
1998 Tacoma
Old Jun 29, 2006 | 10:40 AM
eric-the-red's Avatar
No trick or procedure, you just have to loosen the hinges and move the door back to where it should be. It's a lot easier if you have someone else hold and move the door while you loosen and tighten the bolts. Try doing one hinge at a time.
mussy01
Dec 13, 2016 08:20 PM
theking11863
Mar 19, 2016 09:36 PM
britishdudes2dr
Jul 25, 2015 06:47 AM
94yotaky
Jul 23, 2015 07:50 AM
coryc85
Jul 6, 2015 04:07 AM
