will sway bar help with wheel stuffing?
Old Jun 27, 2006 | 03:37 PM
TX-BLKRUNNER's Avatar
i am currently running with out the rear sway bar, and since i have done the spacer kit and larger tires the drivers side, rubs the gas tank nozzle cover, will the sway bar prevent the tires from stuffing completly?
Old Jun 27, 2006 | 04:14 PM
KyleT's Avatar
i took my rear off and it drives soo much better on road. the off road performance isnt that bad either but it is limited. i dont rub on the back, but i have the daystar bumstops that Steve Schaefer sends with his lift kit.
Old Jun 27, 2006 | 04:23 PM
snap-on's Avatar
is that an indication that you need a panard bar drop to go with your lift? (if im thinking about that right?)
Old Jun 27, 2006 | 05:30 PM
KyleT's Avatar
hmm, yeah i would assume that the panhard bar would help with that,
here is a pic of it with the swaybar and without.
with:
without:
i did not notice any rubbing so if it did it was barely any. not close to the gas tube or anything like that. i dont have a pic of it flexing hte drivers side without the swaybar. but it flexes pretty much the same.
I have 265/70r17's which is like a 32.2" or something like that
Old Jun 27, 2006 | 05:33 PM
AH64ID's Avatar
When I pulled the sawy bar off my 95 I didnt noticed a whole lot of change, so I left it off. Its a very small sway bar, I'd leave it off, it will be slighty better offroad...
Old Jun 28, 2006 | 11:58 AM
well i put the sway bar back on, and it was just enough to keep the tire off of the gas tube. thanks for the input
nvdesertrunner
May 11, 2020 08:18 PM
4.34runner88
Aug 11, 2018 10:44 AM
andrewtexas123
Jul 6, 2016 01:49 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
