Boost Dynos
Originally Posted by dfoxengr
does anyone have any turbo or superchaged 3.4L dynos?
please post setups and whatnot.
also why dont we see more people with turbo. i assume ease of install for the 5vz TRD charger?
https://www.yotatech.com/forums/f2/another-dyno-run-69945/
https://www.yotatech.com/forums/f2/300-rwhp-trd-s-c-barrier-broken-63604/
https://www.yotatech.com/forums/f2/very-impressive-dyno-run-48934/
https://www.yotatech.com/forums/f2/urd-install-finished-results-80739/
https://www.yotatech.com/forums/f2/new-dyno-numbers-track-times-61635/
http://www.gadgetonline.com/4Run.htm
There are many more if you search the threads.
Turbos are getting more popular, but on street trucks. Are you on CustomTacos.com? It's mostly a street crowd and there are a LOT of turbo systems over there.
no im not on there but ive been browsing.
what do you mean interesting?
Some of the earlier attempts put the turbo way low to get it out of the engine compartment. That creates an issue when doing water crossings or someone's running around trying to get a recovery cable on you, or you're trying to dig yourself out of the mud.
The other thing is that generally having fun in the dirt requires low end torque right _now_, and low on the tach. Often times you want a good amount of torque to show up below 2500 RPM, preferably at 2000-2200 or so.
I know that there are lighter, smaller, and higher speed units out these days, and as such, the low end torque thing is getting to be less of an issue. That's why they're starting to show up more...
Of course for max performance you want to run an intercooler. THAT can be a huge issue on a truck that's been rigged for off-road and yet still street legal. The space that you would "normally" put an intercooler is usually eaten up by a tranny cooler, sometimes a power steering cooler, or an electric fan system.
Many people want to run body lifts, and that causes issues with things like relocating the radiator up from it's normal mounts, which again starts eating into space that you'd normally put a cooler.
also i believe i could do the turbo setup im thinking for less than the SC.
SC would consist of it, and headers
Turbo would be it, manifolds made by me=cheap, oil lines, some piping and BOV/WG.
both run on similar if not the same management.
right smaller IC cores can be found though, and mounting the turbo where the stock intake is wouldnt be so bad.
And there's still the "every install is custom" issue (a lot of the off-roaders are bolt-on only guys); and custom = $$$; and the intercooler location; and the tradeoff of tuning at the higher WOT boost versus being able to idle...
The street world has woken up the past year or so and thus the market is getting bigger which means more engineers are looking at making a turbo system better which means new designs are coming out which solves old problems which makes more people interested whcih lets more people sell systems which creates competition on the market which reduces prices while breeding more engineering which...
It's happening, but it's not really here just yet.
I think the thread got flooded with people in under 3 minutes.
It'd be awesome if you could do it. The market's here for it, but there's nothing here to choose from right now.
and engineering is what i do, and the street car world is where i came from...err am still. splitting both down the middle, lol. whichever of my cars runs i drive :-)
so ill look into it, research, and see what i come up with.
the purpose for the dyno is to see the torque curves of whatever turbo, and compare with the TRD.
i doubt ill ever sell a "kit" but you have me thinking now. i should expand my website to 4x4. maybe keep an eye out.
-derek
-derek
Originally Posted by midiwall
There's an old thread laying around here, I'd have to guess from early 2005(?) where someone came forward and said... "Hey, would you guys like a turbo system for under $3000 including management and it'll get you more power than your S/C yet have really quick spool times?".
-derek
-derek
Gregg (Greedy, who's just above here) is heading for a dyno this weekend or next, he's got THE current KILLER turbo system going into his truck.
I'll be on the same dyno possibly the 2nd week of July. I need to get tranny work done, and that's currently slated to start July 8th when my son gets out here from Chicago. I'm gonna let HIM get a pan full of ATF down his back!
Gregg... I've pointed Derek to your install before.
The issue with it (I think) will still be one of what happens with low RPM torque and in the dirt. Maybe not, it'd be awesome to see work out for both venues.Where'd Ricky end up putting the intercooler?
Yeup... I knew your background from other threads. I was just overstating that a street solution isn't an off-road solution.
The intercooler is located right behind the opening in the valence where the licence plate goes. I am going to just bolt up the licencse plate to the bottom two holes with some spacers to clear the 99+ fat lip if that makes any sense. I'll let you know if we make it by this saturday - let me know when you'll be next door and i will come and meet you and your rig!!
ChiefTetlow
Aug 10, 2015 04:19 AM
