Clicking when a/c is on
Old Jun 26, 2006 | 08:42 AM
JEDI87's Avatar
Whenever I turn the a/c on in my 99 runner I notice that there is a click that happens avery few seconds and it's coming from the passenger side floor board by the computer.Is it supposed to do that or should I check something.
Old Jun 26, 2006 | 09:45 AM
eric-the-red's Avatar
There is a relay for the a/c compressor clutch around that area, that's probably what is clicking. Don't know if it should be doing it every few seconds though. Possibly your system is a bit low and the low pressure switch is causing it to cycle. Maybe try a can of the refill stuff, you can get one with a gauge attached so you can check the pressure. They're about $20 so it's a cheap place to start.
Old Jun 26, 2006 | 11:58 AM
rimpainter.com's Avatar
I have owned 5 4Runners and a Taco; all have done this. And yes, I use AC a lot here!
Old Jun 26, 2006 | 04:00 PM
Mikey's Avatar
I don't think its any issue. Mine does it all the time.
Old Jun 26, 2006 | 04:19 PM
Ringmaster's Avatar
Just the AC cycling on and off.
Davebarbier
Nov 3, 2015 03:28 PM
Badlander
Oct 10, 2015 08:05 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bryan34w
12
Sep 30, 2015 02:50 PM
JPV
Sep 28, 2015 03:15 PM
