- No start, no hope
- Windshield wipers stop mid windshield when turned off during cycle
- Won't start
- Won't start
- Airbag control mod hard code reset
- Axle half shaft rebuild
- First Time Toyota Owner (99 4runner sr5) Maintenance Questions
- Rear defog repair
- 3.4L into 95 4runner exhaust question
- Rear driveshaft spins in park
- 5VZ supercharger W/ DC power alternator charging at low voltage.
- 1997 4Runner Slight Slip & Thud
- 4wd limited J shift transfer case
- LED fog / driving lights 3rd gen 4runner
- Should I try saving this head?
- White smoke
- Cylinder Misfire Got me Down in a Bad Way
- What do you run for pistons on a stock 3RZ rebuild?
- 1997 4runner trans not shifting
- 4WD problems
- Chinese 3RZ heads - Are they worth considering?
- Odd vibration/noise
- 96 Taco 3.4 Possible short caused PO340
- 98 4runner hard start advice
- Clutch Slipping - Recent Master Cylinder Replacement
- Low Profile Cargo Box for Winter Camping
- 02 4Runner Mystery Hatch Wires
- 98’ 4Runner surging acceleration
- 1998 4Runner SRS Warning Light/Low Fuel lights issue, Turn Signals on when braking
- 02 4Runner / dies after mile / new battery and alternator tested good
- Wanted: A/C Compresor bolts
- Headliner retaining clips?
- 5VZ-FE overheating
- Sagging left (driver) side
- floating screen stereos 9 inch
- Moisture Inside the Cab
- Preferred Steel Wheel Backspacing to Clear Calipers?
- Ride height
- Lock Cylinder Problem for 98 4Runner
- Hello, needing help please
- Befuddled horn honking by itself after alignment
- Rebuild Top End only? Advice needed
- ECT or not to ECT
- 1999 4Runner with leaking rear seat heater line
- 2001 3.4L low idle, sputter and die
- 99 4wd and wiring woes
- Wheel stud length and par number.
- Dusty Vents
- A Couple Tricks I Learned Doing Drum Brake Shoes
- Operating temps
- drive shaft modification with transfer case swap
- TRD Headers Gaskets - 2000 4Runner SR5
- Clutch won't disengage. Clutch or hydraulics failure? '04 2WD
- Bolt size help (90105-10388)
- 99 4runner v6/4wd/ auto trans fill advice needed
- Rebuilt 3rd member, clicking noises????
- 2000 T4R P0134 and P0141
- Brake Shoe Advice
- 1996 3RZ Swap Woes -- Pinging, LTFT High
- wiring help
- Battery Light - initial tests OK
- 99 4runner auto trans shop needed in S. Phx.
- 02 4Runner cold start issue
- 99 4runner V6/4wd auto trans issue question
- 3.4 V6 Engine Knock
- New noise. Sounds like it's coming from the transfer case. (audio)
- Confused on axle swap possibility from 4Runner to Tacoma???
- Is my starter, my key switch, or other going bad? (2000 4Runner)
- 97 4Runner manual swap
- Tacoma Gen1 4x4 1GR swap
- Best budget lift
- Strange High Idle
- Rod bearing replace
- 2001 VSC help needed
- Is my starter going bad?
- 2000 4Runner Hard Shifting from Park...HELP!
- Driver's side window stuck down
- Radiator Recommendations
- No power but battery is fine
- 3rd member/Clamshell Torque Specs???
- 02 Tacoma 2.7L ignition coils
- Location of VSC buzzer
- 2001 4runner 3.4L tapping noise in gear
- 96 Tacoma 2.7L Warning Light Identification
- Picked up a '96 T4R for my son
- Engine Oil Cooler - 96 4runner - ......slightly panicking
- Running with just one CV Axle
- Throttle Position Sensor?
- ISO: 2.7 engine
- Driver's side mirror loose - 3rd Gen 4Rnr
- Squealing Power Steering After Dust Bath
- 2000 4runner mystery missing issue
- Minnesota Rust Repair Shops?
- 96 4Runner - Rear Tailgate Wiring & Junction Box Question
- Front diff isolator bushings?
- Help! Replacing Rear Diff, WTD!!!??
- Need new struts/shock for 2000 4Runner SR5
- ISO of anyone that works in a shop
- Front ADD actuator
- 3rd gen frame swap OR engine swap....Here we go!
- Hard Start After Timing Cover and Other Work - What did I break?
- Toyota Discontinued Clutch Pedal for 2.7L 4x4 Tacoma
- help from california! need help choosing a cat
- Newbie. Transmission problems. 97 sr5
- New truck
- What is this part that is leaking by oil filter
- Heavy flywheel for 5vz
- 2002 gen3 mystery noise
- Pink Milkshake 01 4runner
- 97 4Runner SR5 no heat from heater
- Flashing FWD indicators and no FWD
- 300,000. And one problem
- How To DIY shim/bucket valve adjustment on the cheap!
- Swapping ECM help
- transmission problem
- Digital odometer miles stored in ECU or cluster?
- Speed sensor
- Automatic climate control diagram
- My Rear Door Handle smashed to Pieces
- looking for machine shop near Spartanburg, sc
- 97 Limited 4wd Issues- No 4H but 4L works
- shock, fire, dead, need help asap
- A340F transmission problems/questions
- Help Reading Engine Code
- Interior trip parts
- I don't know where these wires go!
- 98 5vz-fe high idle
- 4Runner 500,000 mile club!
- Transfer Case clicking
- Stalling at stopsigns/RPM tank during deceleration
- A340F will not shift into 4th
- Valve Cover Leaking on both sides
- Having some starting issues
- Supercharger Rebuild from Toyota
- Clutch replacement
- Check Engine P0420 only when running slowly.
- help resetting ABS light on 1999 4Runner?
- Little Help Finishing Up 5-Speed Swap Transfer Case Wiring?
- What should I look for when buying a 1997 Reg cab, 4x4, automatic?
- OME kit issues
- Front lower A-arm bushing orientation?
- Do I need a new brake Master Cylinder?
- Want to buy JAOS REAR LADDER
- Key Issues
- Strange Braking Issue
- Timing belt
- 96 2WD SR5 275k need to let go
- 99 4runner Charcoal/evap mystery hose
- 99 tacoma with blinker issues
- 2000 3.4 from a 4runner wont start. Help
- The Beat Down Topic
- Lug Nut Question
- ISO 7.5" IFS Front Ring and Pinion 4.30
- Looking to take out my lift. Need help making a buy & to do list
- 1998 3.4L SR5 4WD - Fuel/Starting issues
- 3.4 died after rebuild
- 98 5speed 4x4 code P0500
- ABS speed sensor wiring: tool for disconnecting these clips?
- Truck Feeling Stuck Sometimes Moving Forward
- Rough idle and CEL questions
- Ignition and doors lock cylinder set
- Oil leak above oil pan
- ‘99 4Runner Metallic Clanking/Rattle Puzzle
- 2001 4Runner slips out of 4wd
- Arb bumper hardware request
- ‘99 4Runner 4wd won’t disengage
- ‘96 4Runner SR5 fender flares
- Challenging idle problem - stumbles
- ABS diagnostic help
- 3rd gen 4Runner lift
- Help! Bolt and nut part numbers for 1998 4Runner V6
- Replace connecting rod bolts on 5vz?
- 4runner won't start 30 miles from home
- Manual Transmission Swap: Re-use my auto’s t-case?
- 1996 Tacoma Engine Swap question
- 3RZ with 2TR Block -- Knock Sensor
- 2000 toyota tacoma 3.4 water pump leak
- A343f Transmission Solenoid #1 Fault Code 62
- 2000 4runner limited locked up front differential help!
- 1999 4Runner limited
- 2000 Tacoma engine damage
- Hood Insulation Pad
- Am I looking at new Head Gasket or what ?
- 3.4 knocking p1300
- Flashing CEL cylinders misfiring
- P0172 issue only at idle!
- Heater blowing cold when driving
- Axle Compatability
- Arram Fuel Injectors any Opinions ?
- Injector testing and cleaning write up
- Rough start everytime. Getting worse.
- Air conditioning is stuck on
- Fixing minor coolant leak into engine block
- Intermittent misfire, can't find the cause
- Satan ate my starting circuit!
- Aftermarket bolt on Catalytic Converter for California 97 Tacoma 2.7 4X4
- Need help with a part number - 02 Tacoma 5VZFE Cruise Control Mounting Bracket
- 62 Series LandCruiser headlights for 93 4Runner
- Crosspost - need 3rd gen Panhard bar
- Proper color of rear bumper step pad?
- 98 tacoma knock sensor / cat delete question
- Exhaust smell under load, poor mileage
- 2000 Tacoma 6” lift kit
- AC fuse keeps blowing
- Meth Injection Pump Failures??
- HELP random knocking
- Drive without front diff?
- Strange fuel gauge behavior - 2001 4Runner
- body rust on 98 4runner ltd
- Door ajar light stays on with all door sensors unplugged.
- 96 Hilux / Surf 4x4 issues
- 1997 4Runner V6 Overheat
- painting my 97 4runner advice
- Sending unit
- Payload question
- Thermostat housing stud leaking coolant??
- New vibration and noise 97 4Runner 370,000 miles
- 1996 4runner 3rz-fe swap for 1997 Tacoma 3rz-fe
- Need help need replacement throttle body toyota 3.4
- 1996 Tacoma 2.4L won't start
- Front brake running temp; how hot is normal?
- Starting Woes - Need some guidance
- Restoration of 98 4Runner Limited
- Manual Transmission Mount
- 99 4runner V6 trans fluid exchange question
- Misfire cylinder 1 help
- I dropped something down the defrost vents and it is rattling.
- engine dying while trying to stop the truck
- Wheel Backspacing
- Hard Starting
- Anyone in Nevada or Maryland recognize this green 04 access cab tacoma TRD?
- SR5 suspension different?
- Transmission random shift order
- 1997 power door lock circuit
- Transmission output stud size?
- Broken leaf spring on 97 Tacoma 4X4
- Replacement Leaf Springs for 1999 Tacoma 3.4 4x4
- 96 4Runner brake calipers
- Accidentally drained my transmission fluid instead of oil.
- 1996 3RZ Conversion Engine Bogging Down Under Load
- Shakes and squeals
- Yotatech rear bumpers
- 3rz fuel pressure
- misfire on #2.
- Painting my frame on 1st gen taco
- Need 4 Wheel Drive diagnosing help!
- 99 tacoma won't idle after timing belt change.
- Engine lift points for 3.4 supercharged
