A343f Transmission Solenoid #1 Fault Code 62
Old Sep 5, 2021 | 09:20 PM
bowlink's Avatar
I have a kzn130 (gen 2) surf (4Runner) with a 1kz and A343f auto transmission that's giving me a fault code 62. The fault is for a faulty shift solenoid #1 which gives me the symptoms of not selecting 1st gear unless done so on the shifter manually. I have replaced all 3 shifter solenoids with aftermarket solenoids and reset the ECU but I am still getting the same symptoms. I have also tried three different ECU's with the latest one being checked over professionally twice so I think I can rule that one out!
The two wires, R-G and W-B, have continuity to plugs beside the ECU and don't actually join the ECU directly (unless they change colour somewhere along the line). R-G gets 12v and W-B gets 0v when the truck is in D and I have compared this to a Prado with a A340 series auto and get the same results.
Any ideas on what to do next?
samwell121
Mar 29, 2017 03:56 AM
some drunk guy
May 24, 2014 11:40 AM
andersej
Oct 2, 2013 09:45 PM
dragr1
27
Nov 17, 2009 04:37 PM
~racnjsn04~
Dec 31, 2005 12:39 PM
